Posts posted by hornet
- avsjerome2003, zoly99sask, edmay and 10 others
- 13
I have the Caldercraft Bounty 'on the shelf'. It will be my next build. I am currently working on the Caldercraft 'Supply'. The second planking walnut planks on this kit were poor quality but the rest of the kit was quite Ok. I have looked through my Caldercraft Bounty Kit and the timber in it is much better than that supplied with 'Supply' - maybe because it was quite a lot more $$$$. It comes standard with copper plates and the plans seem quite good. So as Geoff says, take a look!
Hi Pat,
Any chance you could post more pics of your friend's Chris Craft. It looks great from the one photo you have posted already.
Looks very interesting. His other books on Cook, Flinders and Bligh may be worth investigating as well.
WOW, 0.5mm now that is amazing. The only way I can manage to find the smaller ones I've used when they have dropped onto the floor is with a magnet. I have had about a 75% recovery success rate (that is on a carpeted floor)
I just checked out the cost of these screws on the link provided. WOW!!!!! They are expensive. If you search for 'eyeglasses screws' on EBay you will find a box of various sized miniature screws costs around $5.00. They are stainless steel. I bought a box. There are enough screws (and some nuts) to last the average builder a lifetime!!
A couple more simple ideas
Take a used No. 11 blade and grind it down as shown in pic below:
Slit a piece of dowel and insert the blade so that the square(reverse) end is protruding from the dowel.
Bind with cord.
Because the `butt end' of the blade is `square,' it makes a good scraper to remove excess glue for jobs such as
fitting the second layer of planking.
Pegs screwed to a T shaped base board are good for holding parts for gluing and painting.
Golf tees have a large base which is easy to glue to a board. I grind down the tee shaft to the desired diameter then use them to hold cannon for airbrushing.
As mentioned in other posts on this site, LEGO blocks and clamps work well for squaring a frame. They are, by design, very flexible and perfectly square.
Try reading this, sounds a bit complicated but makes sense.
http://www.austinsms.org/Straightening-Warped-Plastic-Parts.php
No problem Alexey, I think that this machine is well worth the money. The fact that I could pay via payal and shipping was included was great ( postage/shipping can be a BIG issue 'Down Under') I thought the postage was very quick and I also liked the fact that you sent an email with a photo of the package attached when you dispatched it. I get a lot of stuff via mail and this is the first time I have seen it done.
Mine arrived about 3 weeks after I put in the order. I got the serving machine 2.5. The power supply is shipped separately from China because Australia uses a different (240 volt) system.
I found that the machine worked much better after I lubricated all the shafts (where they go through the `posts') with fishing reel grease. This grease is designed to use with small gears and worked particularly well when I engaged the power option which would not turn very well on the very lowest settings before greasing.
I also made an addition/modification to the machine by adding another shaft to hold my seizing cotton rather than having it sitting loose in front of the machine. There was just enough room on the `feet' of the `posts' to add a couple of right angled brackets that I cut and folded from some scrap perspex. I used the same diameter threaded rod as was used in the other shafts on the machine.
Hi, might I suggest copper plating the hull as Russ says, then painting the plates - either by brush or better still an airbrush - the colour that you are trying to achieve. I know that hobby stores such as Frontline Hobbies here in Newcastle offer a mind blowing array of colours in both acrylic and enamel. I'm sure one would match the colour you are trying to achieve.
STAINLESS STEEL SCREWS FOR EYGLASSES HINGES
Available on ebay for around $5.00 per box - enough to last a lifetime.
I sometimes have trouble getting nails holding gudgeons and pintles to stay in the rudder (even with glue)
I have experimented with using these micro screws instead
Screws have CA glue applied to thread. Once in place I file back the heads.
Then paint!!
I'm sure there are other ways to use these micro screws in a build.
I have the proxxon DS 230/E which appears to be the same as the 115. It performs very well.
CONNECTOR SLEEVES
These are used to loop nylon fishing line. They are crushed to hold the line in place but are made of brass and come in different lengths and diameters. Once the protective covering is removed (inside and out) they can be used with brass wire and copper sheeting to make gudgeons and pintles.
They are available at most fishing tackle stores
I cut one in half to produce the `hinge' part of the pintle and gudgeon.
After a bit of silver soldering and blackening, they come out quite well!!
Hi Graham
You picked a tough one to start on!! I have the Caldercraft Endeavour on the shelf but won't start her till I have finished the Supply & the Bounty. I was recently aboard the Endeavour Replica when it visited Newcastle Harbour. While others were taking `selfies,' I was taking about 150 snaps of bolts, ropes, window frames and the like!! I think people thought me mad!! I've included a pic of the replica's bow. It may help your build. If you need any other pics along the way (I photographed pretty much everything) PM me.
Any ideas on what to add to give the slightly cloudy look of glass back then? I have the same problem with the liquid gloss I used - too shiny for that period (personal taste) but this looks easier than doing it with the other stuff.
cheers
Pat
After considering this observation, I attempted to make the two part epoxy more cloudy. Firstly I mixed a small amount of acrylic paint to a 1 1/2 centimetre puddle of epoxy.
On the first picture I used about twice the amount as on the hobby knife below. It came out quite opaque. The second picture I used about the same as on the hobby knife. The acrylic mixed OK but I think it was a little grainy (visible on the second picture only.)
Only a small amount of paint was used
I then tried mixing enamel paint with the epoxy. I used about the same amount as with the acrylic. It mixed in much easier. The pic below sort of shows the result but it was difficult to get a clear shot. The epoxy is still transparent but slightly milky/cloudy.
- WackoWolf, src, CaptainSteve and 1 other
- 4
Thanks for the tip twintrow. I suppose tulle could be stretched between the cling wrap and the window frame then the epoxy could be poured thinly over the top. I'll have to give it a go!!
- CaptainSteve and WackoWolf
- 2
Hi Banyan. There were minute bubbles when I first mixed the epoxy. I have had a lot of experience with the stuff having built many, many custom fishing rods. Often letting the mix settle for a minute or two allows the bubbles to dissipate. You can also blow on the mix which helps, or use a blow drier on a warm setting to get rid of them. I have found that if you 'fold' the part A & B mix together gently rather than stirring furiously, you get less bubbles. As to creating a more cloudy appearance in the glass, you could experiment with food colouring as I did - maybe a very small amount of black. I had a puddle of leftover epoxy about as big as a 5 cent piece (about 1cm or 1/2 inch for Non-Aussies) I used only enough food colouring to fit on the end of a couple of pins to get the yellow colouring that you can see on the epoxy blob on the bottom right corner (almost under the hobby knife) of the 4th picture in the post. The erskine epoxy is about $16 for the two 30ml bottles so you have plenty to experiment with.
In a previous post on this thread I suggested that the two part epoxy that is used to provide a flexible, crystal clear coat to the whipping/bindings on fishing rod guides/runners might be used to create `glass' for ship windows. I decided to experiment with the idea.
The epoxy I used was Erskine Epoxy. I think it is an Australian product but I am sure similar products are available overseas. The epoxy can be purchased from most fishing tackle stores (my second home!!)
I use syringes so as to get a precise (50/50) mix of Part A & B of the epoxy.
I made a `window frame' out of scrap material for the experiment. It was mounted onto a board that had been covered with cling wrap. I hoped that the cling wrap would not stick to the hardened epoxy and that the window frame with its `windows' would come away easily. The window frame was clamped to the board covered with cling wrap to prevent epoxy seeping under the sides.
I applied the epoxy mix to the window frame using my `squadron' CA glue applicator. After leaving overnight to harden, I removed the window from the cling wrap. Happily it came away very easily. The result of the experiment is shown below.
Having succeeded with the experiment, I decided to apply the epoxy to windows and stern lights that are soon to be fitted to my current build, HMS Supply.
I had already used clear plastic backed by black card on the stern lights of the supply so I applied the epoxy directly over the plastic. It worked well, giving a more 3D look to the windows. Because this epoxy is used on fishing rods, it is flexible and will bend and twist without cracking. Another advantage of using it.
The first picture (above) shows the job half done and the second one is complete. I think that the epoxy finish looks far better than the `flat' finish visible in the windows not epoxied in the first picture.
I had not as yet put clear plastic behind the ship's other windows but did so after seeing the results above. The epoxy was again applied directly over the clear plastic and also produced a more 3D effect for the windows.
I had an amount of left over `mixed' epoxy. rather than letting it go to waste, I raided the Admiral's kitchen cupboards and found some food colouring. I added a very, very small amount to the epoxy and was surprised to see that it actually mixed smoothly and evenly with the epoxy. It also dried hard and flexible. I have no need for `stained glass' in this build but will keep this in mind for the future. I hope the results of my experiment are helpful to others.
I would also like to thank `Neek" the ship's cat for her valuable input in this experiment!!
- CaptainSteve, GuntherMT, cristikc and 5 others
- 8
I use a two part epoxy to give a crystal clear protective coat to the whippings (bindings) on fishing rod guides (runners) that I custom build. I see no reason why it would not also work for this application. Sometimes it gets tiny bubbles in it after application, but these are easily removed by blowing with a hair dryer on a warm setting. It is available in a variety of brands at most fishing tackle shops.
Birchwood Casey Brass Black Metal Finish works well. It is available on EBay. See my post in the thread below for more info and pictures.
http://modelshipworld.com/index.php/topic/4815-painting-and-blackening/
table saw opinions
in Modeling tools and Workshop Equipment
The Proxxon KS230 is around $200. I have one and it is ok for general cutting but not accurate enough to consistently rip planks. I'm not sure there would be anything available to do what you want for that sort of money. If there is, I'd be interested to know myself!
