Everything posted by Canute
The polyurethane is the casting resin in most kits. It's a vast improvement over earlier blends. Works much like styrene, but needs CA/super glue for cementing. Use fresh super glue. I had some old blister pack stuff from a dollar store, but who knows how long it sat. I was assembling a freight car with it and all the parts I attached would pop off as I fitted new parts. Went to my local Ace Hardware (it's close) got a tube of Gorilla Super Glue and I was back in business. The resin parts allow making short runs of parts, adding them to your basic kit, as you have here, Dennis. Have fun.
F-86F-30 Sabre by Egilman - Kinetic - 1/32nd scale
Canute replied to Egilman's topic in Non-ship/categorised builds
It'll make you a believer. -
My very first launch was like that. Got pressed into the parachute container and felt like I'd never get my hand up to the throttle for the radio mic switch. It was a real boot in the butt. I miss it. -
Busy looking tank. This from a fairly new company. The fit looks really good. Nice shade of primer, Craig. I'm building a batch of circus wagons for a circus train; since it's Ringling Brothers, they are primarily red, so I'm going to use a yellow primer. Don't think it has a descriptive naming like yours.
In full AB, we could blow both tires holding the brakes too long. We could roll the wheels off the rims. The brakes got a tap if we weren't pointed straight down the runway. We steer with our feet, as do most fixed wing aircraft. I assumed you'd figure it out, Luigi, since we were on the runway and cleared for takeoff. It should be obvious to the most casual observer, no? We just looked like we were in a hurry , cause we could. 😉😁 -
Used to love listening to the Hog's gun when they strafed APCs at our range back in Jersey. I pulled duty as Range Control officer at Warren Grove. Very distinctive sound. And they chewed up the APC's armor. Our targets looked like Swiss cheese after a few weeks. You may want to hang some AGM-65 Maverick missiles on the wings, instead of those iron bombs or fuel tanks you showed in post #3. As a two seater, this would allow them to operate with more standoff weapons, such as the Mavericks.
We were 2 turning and burning, the wing tips were down and the canopies were down and latched. Once that was done, push 'em up, select Afterburners and roll on down the runway. Simple, huh? -
Where did you get that dispenser, Chris. My working time for wood glues is too short. I have a plastic sheet where I squirt some glue, then dip a wire paperclip to pick up a drop or so of the glue. I use Borden's Wood Glue. If I'm cutting and fitting, that glue will skin over before I get the new parts ready for glue.
EG, I hope the drugs don't alter your color visualization. NMF finishes are very cool, but hard to achieve the subtle variations of shades. Fingers crossed for a great outcome. Lou, as far as drooping flaps or setups, it varies by jet. Hard wing F-4s (no slats) were flaps 30 for T/O, 60 for landing. Slat birds only had 30 degree flaps. EG would need to consult the Dash one for the F-86. Couple of things usually missed by model companies is the auxiliary air doors and speed brakes on F-4s. They droop on the ground if no hydraulic pressure in the system. Once the engines start, the speed brakes slam shut (3000 psi system). Maintainers avoid them, but it's easy to do so, since the jet sat fairly low to the ground. The aux air doors stayed open until takeoff. I think they were wired thru the landing gear handle circuits. -
Evergreen Styrene is your friend here, my brother. Well done in fitting that. The RL news ain't great, but your attitude will go a longs ways in beating that diagnosis. You'll be in my thoughts and prayers, too. Nihil Illigitimus Carborundum - Don't let the bas...rds grind you down. -
Beautiful prints. Very sharp looking. The blast bags look like canvas.
- 203 replies
- Roma
- Micromaster
- (and 4 more)
That's the break in the fuselage for removing the engine, isn't it.? Many older jets worked that way. I remember seeing F-105s opened up that way. That shrinkage was huge. Luckily it was only one direction. This plastic glues up normally with the usual Tamiya and Testors glues? Understand the GatorGrip for the strong joint without letting the plastic sag. I sometimes use a gel CA to glue styrene, especially gluing very thin stock. The solvents turn thin strips into bacon strips.😉 Should be a simple fix, but preserving any detail will be fun. -
Nice job setting the dihedral. Be interesting how that affects the fit in the wing roots, if any. Are the tailplanes OK? Many manufacturers miss the subtle bends and twists in the airframes. -
Another Stuka, Dennis? Those Special Hobbies kits look interesting. If you want a big challenge, size and otherwise, this is a new release of a Stuka in 1/35 scale: https://www.hyperscale.com/2022/reviews/kits/borderbf002reviewbg_1.html Has it's pro's and con's, per the reviewer, but overall, he thinks it's a good one. Not cheap, but he sees a lot of aftermarket goodies to fix the more egregious errors.
Good job finessing the back end of the Nose wheel well and the ammo bins. Some injection mold makers make some thick castings. May have to resort to CA to tack that seam. I tend to lay on some spot putty, very roughly smooth it out and leave it over night to set up. Of course, I do the initial patchwork out in the garage and wear a mask, since the Bondo has toluene and who knows what else in it. The chemicals etch into the plastic.
