IgorSky
Everything posted by IgorSky
  1. Hi Piet! I can not find the words! Your work is just incredible! And of course I look forward to your new project in the lamp! Best Regards! Igor.
  2. Hi Patrick! Amazing and incredible work! Congratulations! Best Regards! Igor.
  3. Hi Piet! WOW! It's just incredible! Congratulations!
  4. Thank you for feedback Carl and Daniel! Sextant... Interesting idea... Daniel, do you have any photo?
  5. Yesterday I tried another method of making rings. I used the wire diameter of 0.15 mm and the drill bit 0.4 mm diameter . New rings look a bit better than the old. Cork ... I'm trying to come up with that can be placed inside the cork.
  6. Many thanks Carl, Mike, Bob and all whom is interesting this project for your support and feedback! Oh, Carl, I think it just looks complicated, but in fact it is pretty easy in making Hi Mike! I'm sure to make the good model in 1/64 scale is much more difficult Thank you Bob! I would like to clarify that this is not the model of a particular yacht. I have used the drawings of the hull of the yacht Rainbow. But I have changed the proportions. I also used the photos of the yacht Endeavour to make the deckhouses. Length of the hull of this model is 95 mm and I chose the scale of 1/300, only on the basis of my preferences And a small update. I made a lot of small rings. I'm going to use them as eyelets and clips. (I'm not sure that I correctly translated these terms)
  7. The mast and the boom. These parts have been made long ago. Now I just replaced some of the details (cross-pieces) and have drilled the necessary holes.
  8. Another small detail - it seems that this is winch
  9. The next stage - the production of the steer wheel
  10. First of all I have improved the lattice on the deck hauses and did the loops fastening steering. I have used some photoetched parts for it.
  11. Hi everyones! I decided to give this building the separate log. Some time ago I bought a new material for the making of the sea for one of my current projects. I've never used this silicon, so I decided to first try it with some simple project. Thus, about one and a half years ago, I made this hull for yacht, but at that time I was not satisfied with the result, so that the hull was lying in the drawer of my desk all the time. Now I have decided to slightly improve this hull and use it for this project.
  12. Hi Carl! Please, look at these photos - I can send these and other plans in the large sizes in e-mail. I think there is no need to tie knots on such a scale. You can just use glue. Which threads are you going to use? Best Regards! Igor. P.S.
  13. Hi Carl! My congratulations to you with the starting of this project! If you need I can send to you some plans of Bluenose. I'll be interested to watch this build and I look forward to updates! Good Luck! Igor.
  14. Hi friends! Many thanks for your feedback, support and all your LIKEs! In this project I'm going to use a new material for the making of the sea. So at first, I decided to try to use this material in a simpler project. Best Regards! Igor.
  15. Hi Piet! Let me share some information about the threads. Perhaps it will be useful to you. I often use these threads for rigging on small models. I buy this mounting thread at the store for the fishermen. This thread is thin enough and it can be a different color. I look forward to the next update in your build log. Best Regards! Igor.
