Roger Pellett
Everything posted by Roger Pellett
  1. I am pleased to announce the publication today by Wayne State University Press of my first ( and last) book, Whaleback Ships and the American Steel Barge Company. As the title suggests this is a comprehensive history of the design and construction of the 44 whaleback barges and steamships. The book is based on original design drawings, company records, and extensive examination of SS Meteor, the only surviving example of a whaleback ship. Copies are available from the Press, Barnes and Noble and Amazon. Roger
  2. Howard Chapelle ponders this question in one of his books. I do not have access to my library at the moment, but I believe that it was his Search for Speed Under Sail. Roger
  3. Since you live in the US, why bother to change to metric. At 1:96 scale, 1/8in represents 1ft. 6in is half of a ft or 1/16 in at scale. 1/16 in basswood sheet stock should be readily available at most hobby outlets to be ripped into planks. What about the extra inch? Planking is 7in, not 6in. 1in at scale is 1/96in, about the thickness of a sheet of paper. I personally would not worry about this small difference in order to be able to use readily available commercially available sheet stock. For general measuring, I agree with druxey, buy an inexpensive architect’s scale. The triangular type available at office supply stores will include a 1/8 inch (1:96) scale. Roger
  4. There is a series of posts for a rebuilding of a model of Constitution built from this same kit. The author of this series is Jersey City Frankie. He really turns a derelict into a piece of art. Roger
  5. The design, construction, and history of USS Maine is well covered in American Battleships 1886-1923 by Reilly and Scheina. This book includes a photo and outboard profile of Maine’s Torpedo Boat. The authors state that when the boat failed to make its design speed of 18kts it was towed to the Newport, RI torpedo station and used for a while as a training vessel. Unfortunately, the authors do not attribute this statement. The book’s bibliography includes two references specific to Maine: ”Contract Trial of the Machinery of USS Maine,” ASNE Journal 8 (February 1896) ”The Steel Ships of the United States Navy” SNAME Transactions, Volume 1 (1893) Roger
  6. If I understand your drawings, the ship as depicted with its round bottom and extreme tumblrhome would have had stability problems. While the tumblehome Is shown on the photos are you sure of the round bottom? Roger
  7. Maybe you don’t consider it to be one of your best but it’s one of my favorites. Roger
  8. Where did you find the lines drawing for the torpedo Boats? Roger
  9. Look into easels for children. Places like Blick Art have them. Also Melissa and Doug. We bought these for our granddaughters and while the idea mat sound a bit silly, they are sturdily built and stable. Roger
  10. Here in the US the Naval Institute Press recently published The Life and aship Models of Norman Ough. I assume that this is the same book that you are reading and I really enjoyed it. Although some of his techniques are somewhat archaic by today’s standards he achieved remarkable results. Ough was a master of the diorama type display and I particularly enjoyed his discussion of the many small points, some unique to the Royal Navy that can liven up a model. Roger
  11. Weflak Thanks for explaining this. I stand corrected. Roger
  12. Welfalk, In the case of my Sherline, I don’t agree. First of all, the arbor that the chuck threads on to has a drawbolt that passes through the hollow headstock shaft that securely locks the chuck in place. Without this drawbolt side forces would cause the chuck to come loose. As to the chuck itself the workpiece is locked into the chuck with the chuck key, and the lathe itself is not intended for heavy cuts in hard materials. Roger
  13. Since there has been considerable discussion of lathes, milking machines direct read outs, and CNC lately I thought it might be worthwhile to present some thoughts on the way that I have used machine tools. For a number of years I have been interested in building a series of warships’ boats to a common scale of 1:32. My comments apply to scratch building of these models. If you are say turning a set of identical cannon barrels your needs may be completely different. Almost 20 years ago I bought a Sherline long bed lathe and milling column to replace an ancient Sears metal lathe that had died. The Sears lathe did have two features that I thought that I wanted that the Sherline lacked: power feed, and a tail stock that could be set over to turn a taper. As it has turned out I have not needed either of these features. I have also found that that my work has not required a vast assortment of accessories. Chucks and hold downs: For most of my work, I use a 1/2 in Jacobs chuck attached to a Morse tapered shank that fits into the headstock. I also have a Sherline three jaw chuck but have only needed to use it two or three times. I also have a set of fractional collet chucks that are great for machining fractional sizes of brass rod. If I have rod that matches one of these collets I use it. Another highly useful and inexpensive accessory is a set of T nuts and hold downs. While their application to the mill is obvious they can also be used for making fixtures, sometimes from plywood that can be clamped to the tool post. I recently needed to drill a hole longitudinally down an oar shaft to fit a handle. Freehand made a mess of things. I made a U shaped bracket from plywood and mdf, held down to the toolpost with T nuts. A drill equal to the oar shaft diameter was chucked in the headstock and by moving the toolpost was drilled through the two uprights of the U. This hole was now centered on the headstock. A smaller drill equal to the handle diameter was chucked and by feeding the oar shank through the holes in the U bracket a hole concentric to the center of the oar shaft resulted. Drilling: Many projects involve drilling a hole, and for this a tail stock chuck is essential. I also use the sensitive drilling attachment in the milling column whenever I can. Turning: I have a vertical sanding machine with a 1in wide belt ( a linisher to our British friends) that I prefer for grinding lathe tools. I find this to be easier to use than a bench grinder. A parting tool is essential, but I also have a miniature one made from 1/4 in bar stock that accepts a piece of an Exacto blade. While the regular lathe tools are used for turning stock to a diameter or tapering, much detailing is done freehand with needle files. Calibration: For much work, I find that cut and try using simple plywood gages is easier than using the calibrated handwheels. For example I recently made a set of belaying pins. The raw material was 1/16 in brass rod. First this was chucked in a 1/16in collet chuck and the shank was turned to 1/32in, the diameter checked with a 1/32in hole drilled in a piece of thin model plywood. It was necessary to turn a short section of rod to its required diameter, then loosen the collet and to feed out another section until the entire shank had been turned. Otherwise it would have collapsed. The head of pin was then shaped with needle files and the pin was cut off with a razor saw. With some ingenuity there are all sorts of simple gages that can be made to produce work of sufficient accuracy. Roger
  14. Ok, I’ll try to explain. The centerboard is under tension caused by the weight of the board trying to pivot it about its pivot pin. We’ll call the tension T. A rope transmits this tension along its length. By changing the direction of the rope a block or pulley fixed to the boat’s structure changes the direction of T but not it’s magnitude. As rigged the force required to raise the centerboard is still T. In fact it is somewhat more than T due to the friction in the pulleys and blocks. Now, attach the block to the pendent so that it can move back and forth as the centerboard pivots up and down. The force on the end of the block attached to the pendent is still T and while,the TOTAL force on the opposite end of the block must be equal and acting in the opposite direction, it is equally distributed between each of the “legs” of the tackle, in this case Five. The tension in each leg of the tackle including the leg that is secured to the cleat is therefore T/5. We would therefore say that this tackle has a mechanical advantage of 5. There is however no free lunch. Although the force to lift the board is now 1/5 of what it would have been without the tackle it now requires 5 times the length of pull (length of rope) as before. I hope that all of this makes sense. Roger
  15. My book version (hard copy) is well illustrated. Roger
  16. Civil War warship guns are well covered in Arming the Fleet by Spencer Tucker. Another excellent source is Ordnance Instructions for the U.S. Navy. Copies of the 1866 version is available in reprinted form and online. If you decide to buy a reprint, the Michigan Historical Reprint Series by the University of Michigan are “top of the line.” Roger
  17. Frank, A beautiful model of an interesting subject. Well done! A bit of a minor quibble. I don’t understand the centerboard tackle. With the pendant led through the two double bolcks both fixed to the cabin roof the mechanical advantage would be lost. Shouldn’t the pendant be spliced into the end of the forward double block?
  18. At the Mystic NRG conference in 2015 we visited the Ships' Plans Department at the Seaport their primary storage medium is paper. They will not sell digitally scanned plans in an effort to discourage piracy. Roger
  19. For the past 15 years I have worked part time as a volunteer historian/ technical advisor for the SS Meteor Whaleback ship museum in Superior, Wisconsin. Over time we have accumulated a large mass of information documenting the vessel’s history and studies for future preservation and restoration. A couple of years ago the Executive Director began a formal process to archive this information. I assumed that she would have it scanned and saved as digital information. I was surprised to learn that the museum standard is hard copy paper. A big reason for this is apparently the fear that digital media saved with a particular technology; eg. floppy discs will become unusable by rapidly changing technology. Roger
  20. I have both volumes and of the two I prefer Volume I as much of the information contained is from years before I became a NRG member. Some of the information in Volume I is somewhat dated. For example I doubt that many readers will need to know how to mix Japan pigments. On the other hand, it also includes some real gems like complete frame patterns to build one of Harold Hahn’s New England schooners. Roger
  21. You might want to look into First Atlantic Liners by Peter Allington. This covers early sail steam vessels. Roger
  22. I agree with Frank. For a small, space limited vessel like this the cable would be stowed wherever space allowed. I doubt if hemp anchor cables would have been stowed on deck as they could be easily washed overboard in a low freeboard wet craft like this. I see no reason why the cable could not have been led down through a small opening in the main hatch. Roger
  23. Prior to the mid 1800’s most colors were derived from pigments that occurred naturally in nature. Bright, vivid colors were rare and expensive. For example, the bright colors found on the Vasa are believed to be a deliberate attempt by the king of Sweden to flaunt his wealth and even then they were used only on decorations. Most ships would have been painted much more modestly using common pigments, the most common being dirt, or more specifically earth bearing iron ore. Two common earth tone pigments were a dull red and a “dirty” yellow called yellow ochre. This is still used as a basic artist’s color today so should be easy to find. If it is too bright, try mixing it with a little grey to tone it down. I wouldn’t worry about the colors on the kit’s box as this is more about marketing than historical correctness. Roger
  24. Objectively, the term “best” should refer to how well a ship fulfilled the specifications that its designer attempted to satisfy. In the case of a capital warship this is closely tied to the foreign policy objectives that the Navy was required to uphold. This however ignores the fact that these objectives change over time causing ships to be used in roles not intended by their designers. While it could be argued that the French could afford to build light scantling vessels because they were not expected to remain at sea for long periods of time, 74’s were intended to be heavy weight sluggers and if their light scantlings allowed the British to knock them to pieces in battle then they cannot be considered to have been well designed. Likewise, events did require them to remain at sea for long periods as much of the French fleet’s operation (at least in the 1700’s) was spent defending lucrative possessions in the Caribbean. Speed was also an overrated characteristic in a line of battle ship as their name implies these ship were intended to be an element of a fleet that moved at the speed of its slowest vessel. At the time of the American Revolution the British were able to gain a significant speed advantage over the French by coppering existing ships. This had a significant effect on the American Revolution as during the Yorktown Campaign the coppered British ships sailing faster than the uncoppered French reached the American East Coast first after both sailed from the Caribbean. Not finding DeGrasse in the Chesapeake the British sailed on to New York and the French ducked into The Chesapeake behind them. While by all accounts USS Ohio was a beautifully designed ship, she really served just as a powerful warship, not a line of battle ship as the US Navy never succeeded in establishing a battle line. Roger
  25. This has been on my to do list whenever we visit my daughter., son-in-law and granddaughter in Brooklyn but I have never gone in part as I am unsure of public transport on Long Island. Can this be reached by subway, train, or bus from Brooklyn Roger
