Seventynet
Everything posted by Seventynet
  1. Looking very good Mikki. The walnut is going to make it great. Ian
  2. Thanks very much Rick and thanks to everyone for the likes! I forgot to mention that I’m not going to tackle the inner hull fairing until I’ve planked the hull because then I have a nice flat surface onto which I can rest the topside.
  3. Hi all, thank you for the comments and likes, I really appreciate it. I just wanted to post a quick update. There’s not a lot to tell to this point. My approach to the sweep ports was to mill a sort of plug to position the port with the idea that I could snug the planks right up to them. It wasn’t a perfect approach and in many cases I removed the port after tracing the outline and cut the planks against the pencil outline. However, it is very fiddly work and far from perfect. I built a little jig to outline the gun ports as shown. I have decided that I am going to plank the starboard side with Holly whilst I wait for chapter 3. I will install the second layer of wales before I start the hull because it will be easier to place the lower wale that way. I also plan to treenail both above and below the wales but am in the waiting mode for the fishing line and necessary bits.
  4. Hey Rick, good luck with the knee surgery. Today has been a bad modeling day. Nothing seemed to go right so I’ve thrown up my hands and moved on to something mindless and less stressful.😩 Ian
  5. Thanks Rick, you must be referring to the standard (at least that’s what I think it’s called). After breaking it off for the 3rd time I decided to wait until much further into the build when I don’t need to turn it over anymore. I kind of knew that I would break it and made a few extra standards. I look forward to your next instalment Rick. Cheers, Ian
  6. Thanks a lot Greg, I will try that. In any event I am warming to the idea of Holly planking the whole hull anyway a la Greg and David models. 🤓
  7. Hi Rusty, your work is great as usual. I feel compelled to share my regret in not getting a clean enough fit for all the can’t frames where they join the keel. Another thing that I perhaps should have done is to have removed the char so that it doesn’t show up in that area. I just didn’t pay enough attention as I motored along and now feel that I have no choice but to plank the hull. Although I suppose I could do a partial plank job to cover those areas. Just so you know what I am talking about here is a photo. I am sure I do not even need to mention this to you given your beautiful work.
  8. Your planking is looking really nice and clean. Well done. Ian
  9. Thank you kindly, Mikki. I greatly admire anyone that builds without power tools. So good for you. And thanks for your praise, I really appreciate it. Keep up the good work on your San Martin, it’s looking beautiful. Ian
  10. Thanks a lot Jeff. I have the benefit of being retired so I can spend as much time as I want in the Shipyard. Even so there’s no way I’ve been motoring on this. It’s really just the ease with how everything goes together. Ian
  11. Thanks very much Chuck, I am indeed enjoying this build. It goes together like a dream with all your precision cuts and jigs. Just perfect. Ian
  12. Hello and thanks for all the comments and likes. I have almost gotten to the end of Chapter two. I have the stern framing left not to mention a final fairing on the outside. I didn’t do any of the interior so that will be a hunk of work when I get around to it. Everything fit together beautifully and when there were problems it was always my fault. Most of my errors were corrected but not all but I think/hope I’ll be okay down the road. Following shows where I am right now with pictures of my most used tools. Cheers, Ian
  13. Great accomplishment, Yves! What a beautiful job. Ian
  14. Hi MikkiC, I’m pulling up a chair for this. I got this PoB kit years ago when Dusek was having a sale and I’ve been eyeballing it ever since but it will have to wait until I’ve finished my current build. I look forward to learning from you. Ian
  15. Beautiful work! Your attention to detail is second to none. Thanks for documenting your build. Ian
  16. I would not use anything bigger than a 2 or 3 mm end mill and do multiple passes to achieve the depth you need and always on the face of the joint. A DRO and tilting table make life easier. I just don’t have the skill or patience to do that many joints by hand.
  17. I’m sure I’m stating the obvious but I found that gluing templates to the piece and then cutting to the outline for each piece was the key to getting the tightest scarps joints. I always used my mill to cut the joints, milling right to the line gave me perfect scarps joints (perhaps that’s for others to judge 🤓). Keep up the good work! Ian
  18. Jean-Marc, Some really innovative solutions. Nicely done. I wonder with that mirror sandwich whether you could get a light in there too. I’m using a light table and it is helpful but as you recognized you can’t see the back side. Perhaps some kind of portable light wand would suffice. Ian
