![](https://modelshipworld.com/uploads/monthly_2018_05/1526513362495-606996448.jpg.481e1d5455fdc6aa907dcbc1ceb75e2b.jpg)
qwerty2008
Posts posted by qwerty2008
- Elmer Cornish, DSiemens and mtaylor
3
I started work on the ship which is going to be HMS Sophie from Master and Commander by Patric O-Brian. The hull is made from some fine grained softwood I had left over from a previous project, the bulwarks are made from card.
The HMS Sophie changed paint schemes throughout the book so I chose the one that I could make with the paint that I had.
Lextin.
- Gregor, IgorSky, Senior ole salt and 5 others
8
I have decided to build a Ship in a Lightbulb. I have rigged a base to light up using parts from a cheap LED flashlight. The base is an old light fixture. the LEDs push into the light socket which is wired to the flashlights battery pack and on/off button, I have also added a sheet of thin plywood stained with some redwood stain. Sadly during the process of making the base I broke the lightbulb there is still enough of the bulb left for me to be able to size and make the model but I cannot use it in the finished product because it has a large hole in the side, incandescent lightbulbs are hard to get in California but I think I can get a halogen that will work.
I am thinking of making the HMS Sophie from Master and Commander by Patric O-Brian.
Lextin.
I installed the first bit of radio control gear, the rudder servo and the rudder linkage.
I was also wondering if I should ad another gun port on each side towards the stern where I have drawn the [?] I could then get rid of the planed stern chasers by making the two aft most cannons able to be unshiped and moved to the chaser ports when necessary.
Lextin.
- Elmer Cornish and mtaylor
2
- Jaekon Lee, canoe21 and mtaylor
3
I got the hull in the bottle yesterday and will try to get the mast in today.
Lextin.
I added a pin rail and stuns'l booms, unless I think of some final details I missed it is ready for bottling. If all goes well I will take alot of pictures and bottle it tomorrow.
Lextin.
- fnkershner and mtaylor
2
- DSiemens, mtaylor, fnkershner and 1 other
4
I don't know anything about American ships of the line but doesn't the topmast normally connect in front of the lower mast? why is it connected behind the lower mast on the Pennsylvania? or is the pole i'm seeing some sort of flagstaff? if so disregard my first two questions.
thanks.
Lextin.
Daniel I will make a wood cradle that will be glued to the bottom of the bottle, after the hull gets assembled in the bottle it will be glued into the cradle then the mast will be installed.
Lextin.
I did some more work on the rigging (the foot ropes are out of scale but I couldn't get them any smaller) the topmast shrouds are complete the lower shrouds will be attached to the hull and have long strings that will be threaded through a hole drilled in the top of the mast when I install the mast I will pull the strings to tighten up the shrouds.
Lextin.
Once it is in the bottle I will attempt to glue the decks on one by one from the bottom up then cut and remove the strings.
Lextin.
Byzantium by qwerty2008 - Scale 1:20 - RADIO - based on the Pride of Baltimore
in - Build logs for subjects built 1801 - 1850
