Everything posted by Chuck
Nice looking rope...a bit fuzzy but I imagine that could be eliminated easily enough. Chuck
To complete the model...the grapnel was painted and rigged. I made mine from scratch using boxwood. I think they replaced the one in the kit with a cast metal version they had in stock, It was added to the model so the rope looked natural. I made some oars and placed them in there as well. They were just cut from a 1/16" sheet and the handles rounded off. Then they were painted. That is essentially the end of the project. Chuck
- 162 replies
- 18th century longboat
- model shipways
Then the stays and rigging were added at the bow. This pretty much finished it up. Last was teh flag halliard.
- 162 replies
- model shipways
Then the shrouds were rigged and I made the chainplates for the deadeyes as follows. Then I added the backstays.
- 162 replies
- model shipways
Rigging for the boom and gaff were completed first. The lines were brought up to the blocks on the mast and then down to the belaying pins on the thwart. I am going to run through these images fairly quickly as the instructions are very detailed. This way the larger images may be useful to those building the kit in the future.
- 162 replies
- model shipways
The bowsprit was easy enough to shape. A few iron bands were made in a similar way to the ones on the mast. However, I drilled a hole and added a small length of 22 gauge wire for one this time. See the pics provided. I carefully marked the locations for these two bands and glued them into position. The one supported by the long extension was secured first. I notched out the back of the thwart so it wouldnt wander around. It secured it nicely. Then the other band was secured into the stem once the proper bowsprit angle was found. There is a sheave simulated on the end of the bowsprit. It was all painted ahead of time before I secured the bowsprit on the model. I also made the gaff and boom. These were again pretty straight forward. I made all of these from boxwood too. The jaws for the gaff were added in two pieces. Then the parrel beads were strung onto it. The boom has a hook in it which is placed in the iron band on the mast. I added the block to the end of the boom and painted it. Now it was time to start rigging....the rig is simple. It follows the NMM model exactly. I had a few examples to research and they all matched the rig shown below.
- 162 replies
- model shipways
Jason that is a great start. Its always great to see another kit get started. I was wondering if you would like me to move this log to the dedicated group project forum?? Just let me know. It doesnt matter to me but I figure it would be easier for folks to look at everyones progress and share tips. Chuck
- 58 replies
- model shipways
Here is a PDF of the friezes. I reduced some of the transom images further and it should be good to go. Remember...if anyone needs a further resizing let me via PM. All of the six transoms are different sizes so hopefully out of those posted you will find one you like. Download it below. longboatfreizes.pdf Chuck
- 162 replies
- model shipways
I started the main mast first. This was made from boxwood on my prototype but the kit has a supplied dowel. The shape was matched to the plans. The ball truck at the top of the mast was left off until the mast bands were completed first. There were three of them. The two that were used for the blocks were pretty straight forward. I used a brass strip as shown in the photos. The one for the boom was very similar but the small extension was twisted so the holes were on top and bottom. I didnt bother soldering the ends together. I just used CA. It was filed smooth and painted. Works just fine. The Sheaves through the mast were simulated by drilling two small holes first and then carving the material out between them. I usually create a stop-cut first with the point of the blade by just cutting a line on both sides from hole to hole. The material between the two lines is carefully removed and filed afterwards. The iron bands were slipped on the mast and painted black. Then the ball truck was shaped and two sheaves simulated on top. Only one will be used and it will be for the flag halliard. Before stepping the mast the two blocks were attached to the two mast bands. The kit does come with blocks but they are the usual crappy ones. I highly recommend that you scratch these. Boxwood is preferred but any wood will do and they will no doubt be leaps and bounds better than the ones supplied. Only a handful are needed for the entire model. Here is a pic of the blocks being made. Because you only need a few...take your time and there is no need to create an assembly line. When they get done- they get done.
- 162 replies
- model shipways
Model Shipways Syren - The new Carronades have arrived !
Chuck replied to yvesvidal's topic in Wood ship model kits
Nope, not me. I have since seen pics of the new ones in position. They actually fit quite well even though there was some shrinkage. Chuck -
Congrats on teh promotion....I am looking forward to seeing the longboat take shape. Chuck
- 58 replies
- model shipways
No thanks....I prefer to use my Uncle Pauly.... If someone posts something that is copyright...we are really good about that. We almost immediately remove it. I am not worried about that. Most folks are reasonable and after talking to the original author we would certainly remove it. Its folks stealing stuff that hard to deal with...But my uncle said its real easy....he starts with the pinkies. Chuck
- 20 replies
- IPR
- right of use
Thats not needed...most folks are good people. They wouldnt do those things. Those that would.....these types of agreements wouldnt matter. If you post anything on the internet...beware of where it may end up. Its really simple. There is no way to protect yourself from crooks and evil people. If you post any documents make sure you list your name and copyright. Other then that...posting is open for all that "suck" to do their selfish deeds. I have seen so many people ripped off (including myself) it is painful. But those that are caught will be banned immediately from this site. Chuck
- 20 replies
- IPR
- right of use
Thank you and yes...link away. I shall be adding more today. Chuck
- 49 replies
- pinnace
- Syren Ship Model Company
Nope...I can only do so much. Chuck -
So your saying that they are not the ones I pictures above??? Those are a perfect fit. Perfect scale and match what a carronade for that period should look like. They are not 42 pounders. they were real tiny 24's. But to each is their own. There was never a screw in the casting...you have to make that part of the carronade assembly. But there could have been shrinkage when they spin cast it. Sorry...but they matched my plans perfectly when I cast them in resin. Send it back Chuck -
US Brig Syren by Gahm - Model Shipways
Chuck replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
That looks absolutely fantastic. Wonderful work. Chuck -
That unfortunately wont happen. I wish they would though. -
Thank you for the kind words Ben....I see one of these kits in your future......
- 49 replies
- pinnace
coloring handmade rigging line
Chuck replied to davec's topic in Rope Making/Ropewalks's Discussions about Rope Making
Yes...see the link from Jays post above. http://www.woodcraft...px?query=stains -
To finish up the hull before the rigging starts, I added the windless. It was cut from square stock but then shaped with eight side in the center and the ends. The two portions that remained square had some holes in them for the windlass handles. These are actually square holes. After drilling round ones, I made them square by inserting a nail that had a pointy end that was square. Pushing it into the round holes reconfigured them as square with a little coaxing. Handles were cut to length and shaped as shown. There were some knees on the sides of the hull which were cut from 1/32" thick stock. They were positioned on top of the thwarts and against the cap rail. The rudder was cut to shape following the plans and tapered as per typical practice. It narrows considerable as it works aft. It was painted and the frieze details added. The hinges (pintles and gudgeons) are just paper. Then the horse and oarlocks were completed with some black wire. That finishes teh hull and its now onto the masting and rigging. I found this particularly enjoyable as its a simple rig. Chuck
- 162 replies
- model shipways
Thanks Pat...yes it was a fun build. I added the front for the locker in the cockpit next. Then I spaced the thwarts according to the plans. The thwarts had scribed grooves down each side as the NMM model showed. The center thwart also has a different shape. Its wider overall and is shaped in the center to support the mast. Around the mast are four belaying pins I turned from boxwood by chocking them in my dremel. The iron work on this thwart was just paper strips. With all of the thwarts in position it was easy to determine the shape and size of the cockpit seats. The seats on each side were added first. Then a thin strip was added between them against teh transom. The locker lid was last to be added. The hinges are just stiff paper card painted black with a piece of wire to simulate the hinge pin.
- 162 replies
- model shipways
