Everything posted by michael mott
NAIAD 1797 by Bitao - 1:60
michael mott replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
So True, it is the most one of the most valuable lessons we can learn, but at the same time not hold us back. I feel that these challenges are presented for us so that we can progress in our journey, which is after all the most important consideration. Overall the model does look amazing. Michael -
Metal bashing
michael mott replied to michael mott's topic in Metal Work, Soldering and Metal Fittings
I used some English boxwood for the hornblocks with ball races for the bearings. As my supply is now very limited I will be putting all the offcuts into the boxwood cuttings box for future considerations. The rectangular section is the prize this time. After squaring the peice up on the shooting board I milled out the sides. Then turned the section on its face to bore the recess for the 3/8 x 5/32 ball race. and drill the holes for the stabilising rods and the cover plate. As each one was drilled it was sliced off with the exacto saw and reset for the next set of holes. The surface looked like glass.... such an amazing wood. Next I turned up a small button for filing the tabs for the stabilizing rods then hardened and ground it so as to act as a depth gauge as well. After removing the bulk of the material either side of the tab the offcuts went into the boxwood scrap box. ready for the finishing filing The completed hornblock after a little bit of filing to round off some of the edges and blackened with a sharpie pen. The hornblocks were dry placed to check the fit and appearance. The hornblock guides had to be remade today because I made them too long, but the method i used was a good practice for the final ones which I have not photographed yet. Michael -
Metal bashing
Thank you Phil for the links. Michael -
Metal bashing
Thanks for all the comments and likes, Kevin there is a member here who has done a absolutely outstanding job making ventilators like the one you have shown. If my memory serves me correctly it is on a Russian steam yacht, he used a method of electroplating that built up the layers of metal over time. Michael -
Metal bashing
Eberhard, yes I did do the tapping on the lathe. It is robust and I was careful to tap gently and many annealings to keep the silver soft, Plus I only used a leather head on the small mallet. The Castello frames worked out well. Then a lot of small parts made (0x80 hex and square nuts and bolts) and now the frame is all bolted together. and a cameo appearance of the cutter which is sitting patiently for my muse to change. Now to make the axle boxes for the wheels The Penrhyn Quarry used a number of car parts from the Bullnose Morris Cowley, here is another modelmakers interpretation of this loco I am using a collection of photographs that appeared in a special publication of the Penrhyn Quarry details for modelmakers. and preparing my own drawings based on those and some overall measurements of the loco. They basically chopped off the front end of the car chassis and bilted it inside the structural steel frame. Michael -
A huge improvement over the first one, I do agree with Steve about some of the spacing. The eye does like to see good order. I admire your willingness to accept council and then work at doing the work again. When you are old and grey and you pass on this knowledge to younger folk you will often have forgotten how you came by these things. Michael
If you can find a piece of ladies leather skirt clothing at a thrift store, it is really nice fine leather very thin and flexible. it is what I used on my bowsprit traveler You can always tell the clerk that it is a gift for your daughter😉 Michael
Metal bashing
Well yesterday I folded a bunch of brass to form some structural channels for the frames for the bashed silver But it kept nagging at me that the folded channels looked a bit toy like so I spend a bit of time on the table saw and did a proof of concept bit of dadoing on some yellow cedar and maple. Armed with a set of operations that i knew would work I carefully selected a bit of castello and produced an acceptable section. A bit of sanding on the back face and all is well. And so it goes. Michael -
Absolutely lovely, do the saddles have leather on them or are they just metal? Michael
To be perfectly honest I think you are capable of doing a better one. (you did ask) Might I suggest something that might be thought of as completely bonkers. If you were to paint the letters in a straight line on a thin material of the background colour and just paint each letter several times. Then you could transfer all of the best ones to a curved line so that you can adjust the letters so that the (kouerning) Sp? can be tweaked. Sort of like setting out waterslide transfers. Remember how we practiced our cursive writing in school. Michael
Did a little metal bashing to take my mind off stuff around the country. first a bit of maple turned down to 1 inch diameter, the using the ball turning attachment rounded the end. A old bit of silver approximately 1/32 inch thick was wrapped around and clamped with a hose clamp, my finger are not strong enough to hold it and tap with the leather headed mallet. About an hour later after many annealings I had it fitting snugly around the dowel. Another Half an hour of time with some 400 wet and dry. and now it looks like this. I know its not a boat, Ill get around to it. Michael
Kieth it is such a joy to see such fine work. The Mahogany and Brass, well I am assuming it is Mahogany from the texture and colour, Seem to embody a level of craftsmanship that transports one back to a gentler time. Michael
Thanks for the kind words Gentlemen! I have put the model on the track for storage for a while and need to get on with a couple of small commitments. here is the loco finished as far as construction with the large filler valves installed The tiny air pressure valve was a fiddly bit. The hooks were a combination for brass and copper. Regards Michael
Nice work on the booms Keith, I note the clever use of the collet block to ensure the correct right angle orientations, I will file that away for future reference. Glad you had a safe holiday season. Michael
Thank you all for your kind comments, This Project is rapidly coming to a close, here are few picture taken over the last day or so.They include the sanding pipes and the air lines and valves for the sanders. Just a couple more large filler valves to go and a bit of painting and weathering. Then she can become a bit of a shelf queen for a while. I am particularly pleased with the 00x90 square headed locking bolt on the air valve lever hub in the last picture. Michael
Dear Bitao for you kindness, and inquiry. I am well and staying safe with my wife Judy, here in a rather cold chilly winter season. My hand has recovered from the surgery, and I am close to finishing an old project that I have been fiddling with since 2004, I am looking forward to getting back to work on my Skipjack Launch within the coming month[s]. There is a lot of interesting detail to sort out on the launch. One of the things that I am contemplating is to complete the launch in a similar way to the way that some of the classic ship models are presented. One side showing the construction of the internal elements and the other showing the external finishes. Michael -
Bitao, I have just been catching up with your new build! The work that you do leaves me basically speechless, your ability to solve complex constructions using non traditional methods with creative ways is a great contribution that adds to our collective knowledge. Your strive for continually improving your skills is inspiring. I admire your willingness to start over with work that you are not happy with, in order to reach the desired result that seek. All the best in the new year and thank you so much for sharing a greater level of detail in your methods and tooling, How we work is often as valuable for learning as seeing the end results. Humbly Michael
