KirbysLunchBox
Members-
Everything posted by KirbysLunchBox
Great success!! I am almost ready for the second planking on my build. I am still working through the paint on the bulwarks. One more coat I think. I have not glued the upper transom piece on. The instructions are very confusing about that part. It looks like it doesn’t really matter the order from your build though.
- 362 replies
- Amati
- Lady Nelson
Looking great! I think you could just add some filler to smooth the transition for that last plank in my non expert opinion.
- 362 replies
- Amati
- Lady Nelson
Looking good!! I know my patience would be tested taking it so carefully!
- 476 replies
- sphinx
- vanguard models
The split hatches really do look nice! Those details make all the difference. Keep it coming!
- 857 replies
- Sphinx
- Vanguard Models
Dave, there are a lot of references you can use here, but I find the best path is the one you choose to take. Do your research, run some tests, and make it happen. If you can build a musical instrument, you can build one of these ships. I doubt many here can do the opposite!
- 362 replies
- Amati
- Lady Nelson
I started at the bow and placed a drop of CA on the first four frames and just held the plank in place by hand for a count of 20 or so until it stayed put and then did the next three frames and then whatever was last. No pins or tape. The frame numbers might need adjusted to your liking, I just remember that you didn’t want to have to lift the plank too much to get CA under it or it would break the previous bond point loose.
- 362 replies
- Amati
- Lady Nelson
Are you using any hot water to soften the strip? I just soaked the bow end to make the curve and then edge bent and used an iron to steam the water back out. I made a jig to do both sides. I would taper and then soak while I was edge bending and drying the other. I just went back and forth. I also used CA gel to glue in place.
- 362 replies
- Amati
- Lady Nelson
Just make sure you check out Chuck’s edge bending technique and you will be fine!
- 362 replies
- Amati
- Lady Nelson
Beautiful work! Also some amazing remembering of stories of lore!
- 857 replies
- Sphinx
- Vanguard Models
I decided to 3D print new cannons for my LN. The kit provided ones are not really to scale. This is just my prototype and no post processing has been done yet, but it is more to scale. I got the dimensions off of this site for a 3 pounder. https://www.arc.id.au/ArmstrongPattern.html i think someone else bought some cannons from syrenshipmodels for their LN. that might be another option for you.
Thank you for explanation. So much stuff to learn and it is all very fascinating to me!
- 857 replies
- Sphinx
- Vanguard Models
I am very much a newbie here in the subject; is the print out a representation of painted artwork or painted carvings?
- 857 replies
- Sphinx
- Vanguard Models
Progress is being made, slowly. I keep bouncing back and forth between prepping the bulwarks for second planking and deck furniture for deck planking. I decided to completely redo the companionway. More details coming, but I decided to model it open with a ladder going down. 😬
- 362 replies
- Amati
- Lady Nelson
I truly appreciate you guys watching in on my build and the likes! I have barely scratched the surface on this thing and I will need your help to get it done right!
- 139 replies
- Lady Nelson
- Amati
Never gonna give up! Just might take me longer than it should!
- 139 replies
- Lady Nelson
- Amati
