CDW
Everything posted by CDW
  1. Your boat is coming along beautifully Denis. Does it come with all the fittings or are those extra? Over the Thanksgiving holidays, I had to replace my hot water tank as well. Good thing my sons were here to help me. That would have been a bear for just me. Had a hard time getting the tank to drain properly and that made it very heavy to get on the dolly and outside of the house. Once we got it outside, draining it was no problem. 🤥 Installing the new one was fairly easy, too.
  2. Learning as I go along here...I added some Tamiya clear blue and I think it gives the look of a little more depth. Later will add a clear coat, then pause until tomorrow when I can go to a craft store to pick up some gel medium. The medium will add improved wave effects.
  3. I learned it from another modeler. Very little white glue really. Bought a pint bottle and used less than a 1/10th of that.
  4. The whole board gets a coat of Mr Surfacer 1500 white. The a light preshading of 2 parts Tamiya medium blue: 1 part Tamiya green: 4 parts reducer Next will play around with some clear blue and clear green followed by an overcoat or two of Tamiya clear.
  5. Next another coat of white glue goes down over the whole base to take the sharpness off the ridges and waves in the foil.
  6. After the glue dried on all the small pieces of foil, I smeared white glue over the top of the entire thing. Next I used one big sheet of foil to press down on top of the freshly applied white glue, being careful to make the sheet conform to the previously random applied wrinkled foil pieces. I have set this aside to dry.
  7. I used scraps of aluminum foil that were randomly wrinkled, then glued to the foam board with white glue. Once the board was covered with these pieces of foil, it was set aside to dry.
  8. To begin the creation of my open water scene, I cut 4 pieces of Dollar Tree foam board to a dimension of 10" x 14" and sandwiched the pieces together using white glue. I used the submarine model to draw an outline of the hull onto the foam board, then hogged out the foam with a scalpel, keeping the stern area a deeper cut and the bow a shallow cut as I wanted the model to sit with the stern under water and the bow raising out of the water as if the sub was surfacing from below the depths.
  9. I read either the same article or a very similar one that told about the Avengers, the sonobouys, and how they sunk her. My goodness, the wreck is over three miles deep! No wonder no one has recovered the gold. Is a recovery from a depth like that even possible with today's modern equipment? It's a fascinating story for sure.
  10. That's years and years of Marine Corps marksman training right there Ken. 🙂
  11. I'm not going to bore you with the construction/assembly of the submarine as it's not very interesting, but will rather try to chronicle my effort to create the open water base where the sub will be displayed. There are more details to be added to the sub before it's finished and I start painting and weathering it.
  12. The new re-released AMT kits come with pad printed tire sidewalls, but the racing tires for the Galaxie were not printed. In the past, I have used a small paint brush to paint the raised white letters, but this time I ordered some white markers with .7 mm tips from Amazon to try them out on the racing tires. It's a lot easier to do with the white marking pens than it is with a paint brush.
  13. You know the old saying...you begin with the end in mind. The box top illustrates the plan, not the outcome. 🙂 Haven't fully researched it yet, but I wonder if anyone has tried to retrieve the gold yet? It's hard to believe no one has, unless it's too deep to recoup the cost to retrieve it. 20 metric tons of gold is quite a large sum of money. More than 1.25 billion dollars.
  14. Will use the 1:350 Ashima I-52 Transport Submarine to jump back into ship modeling. For a long time, have wanted to try my hand at creating an open water ocean scene diorama and have decided to use this sub as the featured vessel for the diorama. In June of 1944, the I-52 was enroute from it's home in Japan to German occupied France, loaded with some 290 metric tons of strategic materials including tin, tungsten, rubber, and 2 metric tons of gold ingots. They planned a trade with Germany for technology. The allies learned of this plan by breaking the Japanese code. They hunted down and sunk the I-52 in the Bay of Biscay.
  15. I believe I've got that Tommy Ivo kit in my stash somewhere. I built it one time when I was young and remember it being difficult to build it right. That car had the old Buick nailhead engines. Another difficult one to build from that same era was Mickey Thompson's 4 engine Challenger, the land speed record car. I think I have both of his speed record cars. The other one is a four cylinder blown Pontiac powered job.
  16. Locally, this man and his family were my circle track racing hero. Buzzie Reutimann. All the family boys were outstanding builders and drivers in every sense of the word. https://www.google.com/search?q=Buzzie+Reutimann&client=opera&hs=Puq&sxsrf=ALeKk03I4ZRb9KdVtabMvHZ1htCE_2G8DQ:1607871032729&tbm=isch&source=iu&ictx=1&fir=qV2siG4Q2zKx9M%2CAIGKM_pQX0IuoM%2C%2Fm%2F04_0_hj&vet=1&usg=AI4_-kQLFZNWjcj5tuT2vQJyMTeSrkSb3w&sa=X&ved=2ahUKEwjG9_-tmsvtAhVEmVkKHYhEA7oQ_B16BAgaEAE#imgrc=qV2siG4Q2zKx9M
  17. I always remember a quote from Smokey Yunnick that went something like this: "the only thing that beats cubic inches for making horsepower are rectangular dollar bills" 😄
  18. Just like the model, the massive 427 SOHC Ford engine completely filled the engine compartments of the cars equipped with it. https://www.macsmotorcitygarage.com/cammer-the-real-story-of-the-legendary-ford-427-sohc-v8/ Reminds me of a time when I was 16 and found a big Chrysler Hemi engine in a scrap pile. Could have had the engine and transmission for free, but it was so big and heavy, I had to way to load or move it and gave up on that idea. Would have probably cost more to restore than I could ever afford at that time. Small block Chevy's have always been the most economical V-8's to restore or hot rod. The Ford parts cost more and Mopar was out of this world. So were Buick, Olds, and Pontiac parts when compared to Chevy's.
  19. My brother and I restored an old English Ford one time. Came out great and was lots of fun to drive. it was a much earlier model than the ones in your photos. If I remember correctly, an early 60's model, like a '62 or maybe earlier, I don't recall. It had a small, but common 4 cylinder inline engine that was found in many English cars in that day. Might have been a Ford engine in fact, license built.
  20. Oh man, it was more fun than a barrel of monkeys. The exotic car crowd would get pissed when I would blow their doors off with this thing. A lot of people didn't know how good those Buick 455's were. A much different engine than the Oldsmobile 455's and different than the Chevy 454's, too. A better bore-stroke combination in my opinion. Over 400 HP and gobs of torque. The other car I had lots of fun with was a '66 4 door Biscayne that ran a real hot 400 cubic inch small block Chevy engine a friend built for me. Wasn't quite as fast as the Chevelle, but caught a lot more people by surprise. It was a real runner.
  21. The blond haired boy you see in this photo is my son who is now 40 years old. I'm guessing the photo was taken around or about 1994 or '95. I bought the pair of 1969 Chevelles you see in the photos for $1,200 back then, and used the junker for a parts car to restore the better looking one. It was the last American muscle car I owned after a long string of them over the previous years. Still regret selling this one. A friend sold me a Buick 455 cubic inch V-8 that I rebuilt and installed in the Chevelle along with a turbo 400 automatic tranny.
  22. There is so much under the hood that's less than an authentic race car equipped engine bay. One could spend a lot of time scratch building all the details that should be under the hood. But that's not something I care to do at this time. Once I put this all together, the hood will remain in place and the only thing people who see it will notice is the finished model with the hood closed.
  23. Just a few dry fit photos with the interior tub, engine bay (not complete), and the chassis all fitted to the body. I had forgotten how simplistic these old kits were made. Not too great details, this one even has the old steel axles so kids could roll them on the floor after they were assembled. The body car itself is fairly well done so at the least one can get a decent looking race car replica out of it when it's finished. Once I receive those decals I ordered, it won't take long at all to finish this old model. Maybe I should have added a little crash/road rash damage to it to make it look more authentic? In the meantime, I may start another kit while I wait on the decals to finish this one.
