CDW
Everything posted by CDW
  1. The pedals and linkages shown in the previous photos go here. It took some extra cussin’ to get it to fit.
  2. To remove the small fragile parts from the sprue trees a razor saw as shown is an invaluable tool. Even then some breakage may occur.
  3. I reduce Mr Surfacer at a ratio of approximately 3 parts levelling thinner to 1 part paint.
  4. A model like this one has so much detail, assembling and painting it in subassemblies is a necessity. Otherwise I could not get paint on the subject. In this case I am using a very well reduced Mr Surfacer dark primer that will be covered in a Caterpillar yellow in the end. The primer is highly reduced to prevent the paint pigment from obliterating detail.
  5. Did they have a side boom? This D7N would be the basis for a side boom scratch build if I had a good set of drawings to reference.
  6. First page of instruction manual completed. Look closely and you might see some of those small parts. All were used in the assembly shown.
  7. What at first looks like a fly speck is part c36 after it’s cut off the sprue.
  8. Talk about some small parts… See part number c36 in instructions Here’s that part on the sprue with a #11 scalpel blade for reference. Where the part ends and the sprue gate begins is up to interpretation.
  9. Before there were Caterpillar dozers, there were Belgian work horses. As a tribute to the men who mentored me and influenced my life, I intend to write a couple of short stories to go along with this build as for one, I need to write these things down while I can still recall them, and secondly as the building of this model has brought a flood of memories to my mind.
  10. Dad gum spell checker doesn’t like “sprues” and changes it to spruce by default. Apple employs technocrats. 😊
  11. MiniArt does a spectacular job on tooling the parts. Detail is astounding. It’s a shame that equal attention was not given to the sprue gates. The large size of the gates leaves a lot of difficult cleanup to do after the parts are removed from the spruces. The cleanup time required is considerable for most every part. Some parts so small, only the most precise tools should be used for removal and otherwise, broken and damaged parts can be guaranteed. It’s all good and a trade off for a finely tooled, seldom modeled subject.
  12. The biggest problem facing Ukraine is a decimated army with no replacements. Have you seen the video and photos of the older, middle-aged civilians they are putting out there to face the advancing Russian army? It's very sad to see. They have suffered heavy losses of their young men in this conflict.
  13. Next up is a Caterpillar D7N Tow Cat in glorious 1:35 scale. Reminds me of my younger days as a steel worker in West Virginia working gas and oil pipeline construction. We had more than a few of these machines around, used to sit as an anchor on top of a mountain while the “train” of equipment tethered to it hung tenuously on the side slopes of mountains while clearing rights-of-ways, digging ditches, and laying steel pipelines.
  14. Final photos Thanks for the comments, the likes, and for following along.
  15. I may add some streaking/staining on the side skirts, some small amounts of paint chipping overall, a few more detail painting areas such as the Uzi's, head and tail lamps, then give the overall model a flat clear coat and call this one done. Being as it is, I am about ready to move on to the next little project. Considering either something with wings or perhaps a "barn-find" for the next project. The barn find theme would allow for some interesting weathering experiments.
  16. I added a gloss clear coat over the entire model, then gave it a pin wash with some heavier staining in the area of the engine cooling vents. I want to see how it looks before proceeding further.
  17. Thanks gentlemen. This is a recommended company, Amusing Hobby. It's been a very enjoyable build, well detailed, excellent fit, modern and up to date tooling.
  18. Wow, that”s a real sharp-looking scheme. Great job Javlin!
  19. Only a small number of decals and now finished, but a lot more detail and weathering to be added.
  20. Now this is me just thinking out loud...there is no way the road wheel is mounted in any fashion on the battering ram as "a spare road wheel". it just doesn't make any sense to me given the fact a battering ram is meant to batter. The road wheel will get battered, too. I believe in a true combat situation where the battering ram was in use, the road wheel would be one that was probably already battered and not worthy as a spare and would provide some value as a battering tool. PS: I have not found a photo of an IDF Centurian (Sho't) carrying a spare road wheel. Don't think they carried spare road wheels. This further gives me the impression the road wheel on the battering ram if definitely not intended as a spare. However, I could be wrong. 😄
  21. The Uzi's and 30 cal's are for shooting around corners.
  22. Thanks OC I straightened it with gentle persuasion, by controlled brute force. Straight as an arrow now.
