Everything posted by CDW
Grumman F6F-3 Hellcat by ccoyle - FINISHED - GPM - 1/33 - CARD
CDW replied to ccoyle's topic in Non-ship/categorised builds
What did you do to solve the riddle of the canopy and frame? Whatever you did, it came out great. If you had not wrote about it, I would have never known there was an issue. Well done. -
M3 Lee Tank by CDW - Miniart - 1:35 Scale - FINISHED
CDW replied to CDW's topic in Non-ship/categorised builds
Mig Ammo has a line of paint products called Shaders, in a couple of dozen various shades of translucent paint. I’m testing it out here for the first time. It’s interesting the myriad of finishing products Mig Ammo has introduced. -
To get the effect I want, used a white grey oil to tone down the heavily chipped areas. Stowage is carried on the most heavily paint-damaged areas and is yet to be added toward the finish of this project. -
Following steps will include chipping fluid then white paint for the winter scheme. Won’t lay down white paint until tomorrow giving adequate drying time for the green paint. -
My photos are out of order. Don’t know how that happened. I fixed it. -
Making sausage in the paint shop. Primer is Tamiya, finishing paints are Mig Ammo acrylics. More to do so will return with more photos later. -
Yes, there are a couple of Thompson sub's mounted inside the tank but it's difficult to photograph them (for me a rank amateur) because of their location inside. Or a scene of massive destruction dio, which I contemplated but decided against until I got one built stock under my belt. -
No matter which way I try to shake it out, a lot of interior detail will be buried inside this model. -
1/200 Trumpeter IJN YAMATO - issued by MRC/Gallery Models
CDW replied to yvesvidal's topic in REVIEWS: Model kits
Got a strong feeling you are right. Not many in the small pool of modelers who would want the kit can find the extra cash to purchase on at this time of economic uncertainty world-wide.- 104 replies
- MRC/Gallery
- Yamato
AVRO Lancaster by Papa - FINISHED - Airfix - 1/72
CDW replied to Papa's topic in Non-ship/categorised builds
Glad to have found your build thread for the Lancaster. This is a brand-new mold for Airfix, along with a new B-17 kit as well. Both kits are well received by the modelers I have seen that built and reviewed them, light years ahead of the old tools. As a matter of fact, Airfix has released a lot of new kits in the past few years. Many are great kits IMHO. I first built the old Airfix B-17 kit in 1967 after buying it at the Smithsonian in Washington DC. I thought that kit was just fabulous back then. 🙂 -
Model will be finished in a winter, Russian scheme. There is a inner 37 mm gun and a machine gun cupola to be finished before I can move on to outer paint. -
That's a beautiful place to be. Happy Father's Day -
Yes, of course that is the way to go. The idler and drive sprockets are not glued on now and won't be until everything is fitted into place. At this juncture, I have to figure out whether 79 is the correct number of links regardless of what the plans say. 79 looks too tight to me. There are ample extra links to add one or two if needed. -
The kit plans call for 79 links per side for the tracks. Once the slack is pulled out of the track, it’s going to be tricky getting that last link cemented into place. The idlers on each side have a cam built in that enable a small amount of loosen/tighten as required to tension the tracks. My links are functional but it’s going to be a tight radius at the idlers. Keeping my fingers crossed for this step. I need to paint before permanently installing the tracks for obvious reasons. -
In the past, I have assembled individual track links using Tamiya liquid cement then shaped the links around the drive sprockets and idlers before the glue totally set. Of course, this takes away any operable links but I didn't care about that feature anyway. In this case, the hinge points for the links are so delicate, they may break off while shaping them around the sprockets. I'll know soon. 😄 -
You'll want some sort of strategy to assemble the track links. Mine was to use masking tape to hold everything in place while link parts are positioned then cemented into place. It's intended the links be operable, but it will require careful placement of cement to keep from fouling each link hinge mechanism. Just took a close-up photo of a road wheel truck to show the level of detail molded into the parts. The trucks carry the serial numbers and the wheels the name of manufacturer and wheel size. Excellent detail. -
The tracks for the M3 Lee consist of 79 links per side. Each link consists of 4 separate parts, a total of 316 parts per side. Just the road wheels, trucks, drive sprockets, idlers, and tracks = more than 800 separate parts.
