shipcarpenter
About shipcarpenter
  • Birthday 05/05/1980
  • Gender
  • Location
    Czech Republic
1,492 profile views
  1. Hello, thanks for comments I am back and I have one question. I found difference between plans for cross section and full build (see photo). On main topsail sheet bitts there is crosspiece close to main mast (cross section) but in full build plans is on the opposite side from mast. Can somebody tell me what is correct?
  2. Hello, nice color combination and very clean work. I bought my barrels for cannons but turned your own it is a different level - yours look super.
  3. Thanks Dupree for your words. Thanks for likes too.I am now working on the "second floor" or gun deck and then I will add some photos again.
  4. masterpiece-Meisterstueck-chef-d'œuvre thanks for sharing this
  5. Thanks Pete, its maple wood from USA, they call it Hard Maple. very bright sort of wood hard with almost no grain and with little mirrors on radial cut.
  6. Hello,thanks for your likes and thaks for looking. A little update: lower deck, carriages, planks for wales, deck planking, treenailing...
  7. Thanks Mike. I made some changes in space for main mast, as seen on in ChadB build, thank for inspiration, very nice.
  8. Hello and happy new year. I lost my old computer with all data but I found some pictures on my camera, so here it is:
  9. Hello, little update, here are the wrong pieces I must replaced with better ones. I made building board of old furniture board. Also marked off space for keel( false keel). Glueing keel with false keel together - I used PVA glue with black acrylic paint - It is not so good visible but maybe it come out with coat of varnish. Last thing is unify joints for keel in every frame, I fixed frames on board with rectangular attached pin which fits to the groove for keelson. Then sanding until keel fits perfectly to the rabbet.
  10. Hello super job with framing and very nice explanation. I am just doing the same, thanks for sharing.
  11. Hello, So I printed plans of frames, numbered them and glued them on 5mm thick wallnut sheet. here was important to glue the pieces straight and correct - as I later recognized and must redo 5 pieces, but with 9x11 pieces it was ok. And then made a little dust in my living room with scrollsaw. I enjoyed this work and with my proxxon saw blades it was quickly. I clean up ends of every piece , for this I has no machine, but for this was enough chisel and sandpaper glued on small rectangular wooden stick. I glued each plan of assemly on a small platte 9mm MDF. And then try and adjust the pieces until it finally clicked together. I glued them step by step I let the glue to dry and then added other pieces. Little training with treenails.
