TomShipModel
Posts posted by TomShipModel
I use silk span for sails. At this scale, I use three plies of silk span with each plie 90 degrees to each other. My work surface is glass, and I use dilute white glue at approximately five to eight parts water to one part glue. Too much water defeats the process, too little water the glue is too stiff to spread.
Hope that this helps.
Welcome back
- mtaylor and Keith Black
- 2
Excellent Mike, and very clean. Even the building jig is just perfect.
- mtaylor and FrankWouts
- 2
I meant, a sales brochure for a full size boat. AN interesting fact with photography is that no matter how good your model looks at a comfortable viewing distance, the photograph shows all of the imperfections. The galley on your model looks like it was taken on actual boat. Fantastic!
- JpR62, mtaylor, FriedClams and 2 others
- 5
The photograph of the galley on a model looks like a photo in a sales brochure. Fantastic clean work Michael.
Tom
- mtaylor, FriedClams, Tony Hunt and 3 others
- 6
Welcome to MSW.
- 2
Welcome to MSW.
- 2
Welcome Herby,
You will find great support here. I'm very interested in seeing your Mikassa build.
Tom
- Ryland Craze, mtaylor, Keith Black and 1 other
- 4
Welcome. You will find plenty of support on MSW.
- 2
Welcome to Model Ship World. You will find plenty of support here.
Welcome to MSW. You can build beautiful models as well. There are all levels represented here.
- JeffT, Keith Black and mtaylor
- 3
Welcome, Sam. You will find plenty of support on MSW.
Best to you,
Tom
- Ryland Craze and mtaylor
- 2
Welcome to Model Ship World. As you can see, many good answers to your Ship Model questions.
- Keith Black and mtaylor
- 2
Welcome Pocojo!
- 2
Welcome Pete,
- 2
Welcome. It looks like you have it planned out well.
- 2
Well done, and clean as per the usual. Beautiful.
Tom
- mtaylor, Ryland Craze, FrankWouts and 1 other
- 4
Welcome Vaidas! You have come to the right place. Nautical Research Guild has just had part 1 of a two part virtual workshop specifically for paper and card models. I have been to part 1, and it was excellent. You need to be a member of the NRG to view the workshop. Part 1 was recorded and it will be posted on NRG's website.
Best regards,
Tom
- Keith Black, vaidas, mtaylor and 1 other
- 4
I acquired this book a few years ago when it wasn't so pricey. For many it may be out-of reach at $300+
That ia an incredible price! While the book has been out of print for many years, you can find it for a much lower price from a used book dealer, or from a retired modeler's sale. You need to be a bit lucky, but they are out there. Also, if you can't find Lees, Steel's Elements of Mastmaking, Sailmaking, and Rigging is available digitally. You can likely find a used copy somewhere, although there are very few drawings and you need to puzzle out the 19th century text.
- hollowneck, TBlack, mtaylor and 1 other
- 4
Ron,
I have used Petersson's book as well because of the excellent drawings that make the explanations in other books clearer. That said, you need to use caution with this particular book for the simple reason that it is rigging for a first- or second-rate ship, English, post 1790. For a general explanation of the run of a line, the book is excellent. However, if you are building a smaller ship for a different period, and it is English, by far the best book to use is "The Masting and Rigging of English Ships of War" by James Lees. It is a little tough to go through some of the word descriptions in Lees, but the diagrams help out and you can use Petersson to supplement. The book fully describes how the lead and fixing points for the various lines changed for various establishments as well as where they belayed. It also explains where single and double blocks were used. For example, there are many instances where a double or triple block was used for third rate and above, but only a single block was used in the lower rates. Topmast or Topgallant yards on large ships have double and tripled lifts while smaller ships used only single lift. Also, take into account that belaying pins were generally not used prior to about 1790 depending on the size of the craft as well as nationality. You could also use Lees for Colonial Ships and maybe for latter. However, there are lists of Boatswains Stores of the Navy of the United States that was republished in the Nautical Research Journal. There are also several books out there for other nations ships.
So, Petersson's book is excellent in that it has very clear drawings. However, if you aren't building and English SOL in about 1800 you need to use a supplement to make the rig accurate.
- mtaylor, hollowneck, Spooky spoon and 3 others
- 6
Polyester lays up beautifully. However, several of the rigging techniques involve white glue (such as making fake splices and securing knots, seizings and strops). I also use white glue for getting the catenary droop in foot ropes and loose running rigging. Is there a way for me to get that with polyester line as white glue doesn't soak into it like cotton or cotton covered polyester?
Tom
- Ryland Craze, Dave_E, mtaylor and 1 other
- 4
Is Gutermann E thread polyester or cotton?
I didn't admit that in public did I?
in New member Introductions
Welcome Nate!
