TomShipModel
NRG Member-
Everything posted by TomShipModel
This is a beautiful model. Chuck has been bringing Cheerful to our meetings and, I've seen the progression. The detailing is exceptional. Great job Chuck. Tom
- 1,051 replies
- cheerful
- Syren Ship Model Company
Jaager, Yes, another god suggestion. When I put in the lower masts for the last time before doing the shrouds, I'm going to insert a very small pointed pin in the bottom to hold the heel of the mast.
Good Day Martin, That is a great Idea. I have Longridge's book, but it has been so long ago that I didn't remember that detail. Thanks for sharing that. I've placed and removed the masts several times, and I'm sure that I will be doing it several times before I rig shrouds etc. The method that you use prevents enlarging the wood. Best regards, Tom
Thanks for the link Frank. I understand that a lead block, or some other way to get the line to come in from the side or bellow the timber head would allow the use of the tugboat hitch. So, if I have a line coming from above the belaying point, I'll put a lead block on the deck. This hitch for sure would work. I'm working with a ship built in 1757 and I'm modeling it as it would be in 1777-1778. AS best as I can find from what I've read, belaying pins weren't in use at that time in the Royal Navy. I have a further question that I think I know the answer to, but I'll ask those who know a lot more than I on this subject. The timber head passes through a rail (as you see on the background plan of Culloden on MSW). I'm thinking that the line would NOT pass under that rail before hitching to the top of the timberhead. Is that correct? Also, I'm assuming, that belaying by simply wrapping the line around the rail would for sure never be done. All the best, Tom
Frankie, A very good explanation. Although I've belayed many times, this is the first time that someone clearly defined the how and why as well as the number of turns etc. Question though: If you are belaying to simply a timber head, that is, no underside, how do you belay? Depending on type of ship, and period, belaying pins might not have been used. If belaying was simply to a timber head, what is the correct way to belay? Thanks all, Tom
I do not use glue when I install the masts or spars. There really is no reason to. Yes, if you broke one, it would be one less problem to get around. Except for the lower yards, everything was able to be taken down at sea. You really don't need to glue anything as the rigging will hold everything together. Regarding the lower masts; I install wedges to keep them relatively tight at the deck. In full scale, there are also wedges where the mast passes through the deck. This allows me to adjust mast rake as I rip. Tom
Druxey, Thank you for that information. Very interesting that there was the forerunner of I guess a dependent care account back then. Tom
Good morning everyone, I am contemplating putting sails on my current project, HMS Liverpool of 1757. The model is 1:96. If I do sails, I'm going to use silk span. Somewhere on MSW, I read a method of using silk span, and printing the tabling and sail plan using an inkjet printer. I did a word search of the forums and did not find it. Frankly, I don't remember if it was a separate topic or a build log. It looked very promising. So, hopefully one or more of you have a better memory that I. Thanks for any and all help, Tom
Good morning all. I've seen this model up close. Very well done as others have said. Tom
- 481 replies
- rattlesnake
- model shipways
Airbrush
TomShipModel replied to Mike Dowling's topic in Painting, finishing and weathering products and techniques
Ron, Thank you for posting the video. I haven't use an airbrush at all up to now but I do have two. At some point I will give it a try. I wish that I had seen this video before I got the air brushes because I had no idea what I have and why they would work or not. Now I do have the guidance that I need, and chances are the airbrushes that I have might not be the right fit. Anyway, this video is a must for anyone who is even thinking about using an air brush. -
Good morning all, As said previously on this thread, I second that you keep both. I have both and do occasionally use the Preac for very fine work, and when I'm too lazy to change blades. To be totally honest though, I haven't used my Preac in a while. The Byrnes saw I use almost every day that I'm working in the shop. Before I had my Byrnes saw, I made gratings with the Preac. The gratings for my current build (1:96) were made with the Byrnes saw. As far as blades go, Thurston in Rhode Island is first rate. I've used them several times and never been disappointed. This is doubly special because most of their business is with professional jewelers and the like. No order is too small. Their customer service is tremendous. I've ordered from them on Monday, and got blades on Friday of the same week. Google their website to access their catalog and request a quote. In a day or two you have a quote and instructions on ordering. They are first class and the blades are excellent. The three most used power tools in my shop are all be Jim Byrnes. The saw most of the time, followed by the disc and thickness sanders. I have sheets that I first thickness as needed and then cut on my Byrnes saw. Best regards,
Toni, The photo appears to be too large a file. Only one loaded.
- 1,449 replies
- 1,449 replies
Hi Toni, Excellent work on both the stanchions and the Binnacle. Turning very thin brass is a chore. I've been told, that the grade of the brass, and its hardness can be very big factors. The women from Sheerline that was at the last NRG Conference can be a help. She gave me a few very good pointers on turning very thin wooden stanchions. In ant case, the alternate method looks great. I bet that the prototype wasn't turned from one piece but made up of several pieces as you have done. The good thing about this is that you keep trying until you find something that works for you. Regarding the Binnacle; I made one for my 1:96 Liverpool, also from Swiss pear. I will post one or two photos another time. I modeled it from the Binnacle on the Victory and in the Anatomy of HMS Pandora with two compasses flanking a central lantern. For the lantern, I used a plastic bead of the appropriate size with a brass ring as a base. The lanterns are printed compass roses that I downloaded from open source pictures on the internet. I simply copied them and reduced to the appropriate size. All of that is barely visible, but it is visible. Just put "compass" into your search engine. to you all, I've seen this model in person, and it is a gem! All the best,
- 1,449 replies
Lower Mast Crosstree and TrestleTree Snape
TomShipModel posted a topic in Masting, rigging and sails
Good Morning all, I'm currntly fabricating masts and spars for HMS Liverpool. First, as I've known from experience over and over, use the given dimensions rether than scaling from a drawing. The set of plans that I have for the masts and spars are shown on a drawing that was published in Shipwright years ago. While it is generally 1:96, the tops and crosstrees are not drawn to the same scalle as the masts. Hence, two crosstree/trestletrees go in the object lesson bin! Steel defines the following: "SNAPING, reducing the ends of any piece to a less substance." The crosstree has what is called a "snape" at each end. Basically, it is a tapering in the vertical plane with the taper of differnt length at either end of the cross tree. Lee's does describe these in detail as does Steel. I've seen many models with the longer taper on the fore side and the shorter on the after end of the cross tree. However, Steel says the following: "TRESTLE-TREES are sawed or hewed to their sizes thus. In length, they are one-fourth the length of the top-mast; in depth, half the given diameter of the mast; and in thickness, two-thirds of the depth. The insides are trimmed straight, and out of winding, and the thickness set off parallel thereto. The uppersides line straight and square, and the depth parallel. The undersides are snaped at each end, and the edges chamfered the length of the snape. One end to be once and a half the depth, the other end once the depth only, within the ends, and the snapes are lined to half the depth of the trestle-tree, and rounded to a sweep at the ends; the lower outer edge is chamfered along the whole length, and the inside only to the cross-trees. The longest snapes to be at the foremost ends of the main trestle-trees, and the after ends of the foremast trestle-trees." The instruction in the bold text is something that I've not seen before nor described anywhere else. It also doesn't state and instruction on the mizzen mast. This detail will not be visible to the casual observer of a model in 1:96. However, it is very curious. Have any of you run into this previously? Thanks,- 1 reply
- Trestletree
- Crosstree
Mast bands and rope wouldings
TomShipModel replied to DocBlake's topic in Masting, rigging and sails
Good Morning Mark, Yes, I agree with you. Caution is the word. For example, possibly a typo, the length of the bowsprit varies a full three feet between two editions of Steel. Also, mast diameters are a bit beefier in latter editions. I am building Liverpool after her last refit, and between 1776 and 1778 when she sank in Jamaica Bay off of Long Island New York. I have a set of masts and spars that are on the Model Shipwright plan. However, they are of mixed scales so you need to be very certain to resize based on the rules in Lee's or Steel. Also, although much different, David Anscherl's Swan class give clues although you need to go back to the earlier establishment. Very good discussion. Thanks -
Good Evening Dave, Yes, there are rules for wooldings and latter Iron bands. Whether wooldings or iron bands was based on period rather than ship size. If you can get hold of Lees, or better, Steel, there are tabulations of how many mast reinforcements would be required. Basically, it was based on whether the mast was a "made mast" or a single pole. In most instances for both British and American vessels, the reinforcement was for the lower masts and for the bowsprit. Top masts and higher were generally pole masts and do not have reinforcement bands. I just needed to go to Steel for my current build, HMS Liverpool, a 6the rate, 28 gun frigate built in 1757. As others have stated, smaller vessels had pole masts and there was no reinforcement needed. Again, use the available references and you will get the picture. For example, schooners were small enough that the masts are pole masts. SO, no wooldings or iron bands. Hope that this helps, Tom -
Deadeyes versus Hearts for Standing Rigging
TomShipModel replied to TomShipModel's topic in Masting, rigging and sails
Good morning all, Well, thank you all for the replies. B.E. Yes, I will put up a building log soon. Frankly, due to work and other models, I've literally been working on and off for about a decade! I don't think that I'll go all of the way back to the beginning but I wil give a general description of what I found out along the way. An interesting issue that I run into is that I will get a good and precise method for doing something, and then finish that particular aspect and then, years latter, when I have to do it again, I have to rediscover how I did it. Very frustrating. Marc, I will be searching out the best source of serving and seizing line. I have quite a bit of rigging line that I collected over the years, but the really fine stuff is tough to find. I'll get through it though. Henry, I already crazy. You are correct, there is compromise because some actual practices just will not look correct in very small scale. That is whats important. For example, if a line is parceled over worming and seizing, doing all of that in scale would be much too bulky. Druxey, yes, the differences among different sources is a bear. However, I don't think that anyone will be doing that much detail measuring on Liverpool. Of course, it has to look right. For a 28, the bowsprit length in two different editions of Steel varies almost 3 feet! There are other minor differences in spar diameter and length but, a three foot delta would be very noticiable in any scale. Best regards all, -
Thank you. I really appreciate the help. I have a the 1932 Sweetman reprint of that edition. I just finished the lower masts and bowsprit for Liverpool. I have the plans that were published in Shipwright as well as a copy of an earlier Edition. The dimensions for the lower masts as well as the bowsprit differ quite a bit. I'm going to pick one version and go with it. I'm going to put all of the rigging attachments on the spars before I step them permanently. Being only a 28, the stay collars and gammoning etc. are 5.5 inch rope. That's 0.018 inch diameter in scale. At that size, serving line would be .003" diameter. It would be very bad to use seizing that just looks out of scale. I'll see how it goes. I think that now that I have some time, I might just start a build log to get photos up. We'll see. Anyway, thank you very much. Tom -
Attachment of Ratlines to shrouds
B.E. On the same website that you sent me to for the Occupation of Newport, I found a color painting of "Battle of Fort Washington", fought on the Hudson in 1776. It definitely is a White Ensign. Thank you sir, for the lead. Best Regards, -
Thank You BE, What edition of Steel do you have? I need to read it a little more closely. Lee's was lead to the confusion. I'll use hearts for the stays. It is likely that I will also use them for Bobstays and Shrouds as well. They are very small for the bobstays in 1:96. Thank you for your help. I've had a valid reference all along, but alas I believe that I'm being a little bit lax. Looks like Steel replaces Lee's on my desk. Best Regards -
Good morning everyone. Finally I am progressing with my current project, HMS Liverpool circa 1778, 1:96. I have made the lower masts and bowsprit and I am now putting riggind attachment points on each. Now ther question: I've checked Steel, Lee's, and David A's Swan Class to verify attachment of the Fore stay, Fore Preveter Stay and Bowsprit shrouds. Swan class show a heart (open in the case of the Fore Stay. Steel says either or, while Lee's also shows either or. Although Liverpool was built in 1757, she was rebuilt twice. Also, twenty years latter, I'm sure that her rig was updated. If I was into 1800 and latter, hearts would definitly be it. The question would be, in 1770 to 1778, would hearts be used? My guess is that when Liverpool was originally rigged it used deadeyes. But, how about in 1778? Thanks for your comments.
Thank you very much. You simulated some further thought, I believe that somewhere there is a painting of the evacuation of the Royal Governor and his family from Williamsburg Virginia. HMS Alfred was the flag ship of that squadron and Liverpool was a part. I seem to recall that Hahn has it in his book about Alfred, but it is in black and white. I'm sure that I can google it to get a look at the color version. Thank you very much for the input and good advise. Do you have any photos of Pegasus? I will post phots of Liverpool somewhere but I don't think that this thread is the correct place. Best regards, Tom -
Yes, that's the one. The second of its class and the first to have cable gear raised one deck as well as the pumps etc. Sank in a storm in Long Island Sound in a storm. Thanks, Tom
