Ian_Grant
Everything posted by Ian_Grant
  1. Just for laughs I worked on a Jarvis brace winch in TinkerCAD. The supplied Heller winches seem too low down to me; it's as if they forgot that sailors need to crank them around too. I drew a winch which provides a crank at the same height as the wheel on the halliard winches, and made the overall assembly about 1.5mm wider (viewed from the sides) after first ensuring that there is clear deck space for this slight enlargement. I kept the width athwartships the same so as to use the same two mounting holes in the deck. Here is a screenshot. It is sitting on a 1mm grid so you can appreciate how tiny it is. The different colours are components I envision as separately printed before final assembly. The yellow represents some 0.6mm OD brass rod. Of course it's one thing to draw it and another thing to successfully print it. Opinions on odds of success, anyone? Haven't shown it to my brother yet as he's a busy guy and I am already waiting for the railing print 😉 God knows how the gear teeth would turn out. And before I receive a flood of messages, yes I know the gears could not mesh with their flanges as depicted; I wanted a circular base on which to print each toothed gear. I could have flipped the central large gear by making it another distinct part, but at this scale why bother? And they may prove to be totally unprintable anyway. I messed around for pretty much an entire day on this, more than I wanted to but the CAD brings out the ex-engineer in me. Gears are none too easy to draw in TinkerCAD as I couldn't find a "primitive" for them. Perhaps there is one in there somewhere but mine are a manual effort.
  2. I've been quiet for a while due to reno jobs; one lady hired me to make her a dresser which was quite fun as furniture commissions are rare for me. I have been working on solving two nagging Preussen problems i.e. Heller's unsuitable ladders, and my ruined stern railing. I've emailed Heller four times about a railing replacement without any reply. The ace up my sleeve is that my brother has a 3D printer so I decided to try to create CAD drawings for these parts. I used TinkerCAD which is a free online CAD tool. After watching a few tutorials (not those provided by TinkerCAD which are useless for a neophyte) I was able to produce some .stl files which I sent to my brother to print. He says the ladders came out clean, though he was laughing at the tiny amount of filament required (3 cents worth for a dozen ladders), but I only just sent him the railing file. Here are some screen captures of the 3D drawings. This is a modified Heller ladder in which I just added some triangular wedges at the ends to orient the miters in the correct direction. This is a ladder inspired by those in the pictures of the Preussen model Miki sent me above. I drew it after measuring the total rise with calipers since Heller's ladders seem a tad short. The upper step is meant to be flush with the upper deck it runs to as in the model. Here is my rendition of the stern railing. Unfortunately I could not get the "torus" shape to work for my tubular rails because when I stretched the torus in x and y to match the non-circular-segment curve of the railing, it distorted the diameter of the actual outer ring; in other words I hoped to enter the desired rail diameter and it would just stay at that as I stretched the torus but the diameter too scaled in weird ways. As you can see I ended up creating the rail segments as individual lengths of cylinders, suitably rotated. Fortunately it was easy to duplicate them once I had one fitting between stanchions. I had to add sphere shapes at the tops of the stanchions to fillet out the butting cylinder ends. I know nothing about 3D printing, not sure how Andrew will print this with supports after slicing. I'm hoping the supports are relatively easy to cut off as the part will be delicate. Can't wait to see how it turns out, and how accurate I managed to be. Not to be overly cocky, but now I'm wondering about making some better looking Jarvis winches 🙂 Other than that I've just been painting some future parts. Anything to put off trying to fashion brass trusses.
  3. Thank you Miki for the pictures of the other model Preussen. Looks nice! I'm not looking forward to tying all the clove hitches for ratlines on five masts! Do you think the lower mast stays shown are accurate, with both sides running separately as opposed to being seized together at each end (more like the topmast stays)? I see this modeller installed chain futtocks whereas I depict solid bar. Wonder what they really were? Wonder how this modeller ultimately routed the lower braces to the winches? Speaking of which, look at the detail on those brace winches! I love the wire railings on the after storm gangway, and I see the auxiliary bridge lacks those mystery "buckets" Heller molded in. Perhaps I will just cut those edges off. This model's deck furniture is painted in the more sombre tones recommended by Heller, not "flashy" like mine 🙂 Are going to put a "Pamir" build log on the forum? I'd like to watch your progress. Speaking of which, does your kit have the same problematic ladders as mine? (See my earlier post).
  4. Welcome Miki to my large group of followers! 🙂 😉 And thanks for pointing out the differences between Pamir and Passat; interesting! Nice to have a flying-P expert at hand! I'd love to visit one of these museum ships someday, perhaps in a trip also including the Wasa. I know Viking is now a hotel in Gothenburg, and Moshulu is now a (shudder) restaurant in Philly. Have you read "The Last Grain Race" which is a first-hand account of Moshulu's participation in the 1939 grain race from Australia to UK? Very good read!
  5. Things are looking up! Marten has very kindly replied to my P.M. with the information that those little rails on deck were for the sailors to brace their feet instead of sliding into the scuppers when hauling ropes, and that the brace winches were definitely in front of the masts. No ropes are looped under the rails, that is a Heller-ism. Thank you Marten! So I will rig the braces according to Underhill, with the exception that lead blocks will have to be under the mast top in order to pass down to the brace winches in front of mast without interfering with course or its yard or truss. Also found nice shots of "Preussen" model for those interested: http://www.steelnavy.com/Preussen48.htm Some nice deck shots here. Heller badly mis-shaped the capstans but at this point I will just leave them.
  6. Speaking of those great photos, now that I am nearing completion of deck furniture and thinking ahead to prepare for rigging, I've suddenly noticed that the Jarvis brace winches on this model are placed in front of each mast, which is contrary to Underhill's brace routing diagram ("Masting and Rigging: Clipper Ship and Ocean Carrier". Note: the mizzen has a brace winch both in front and behind, to handle braces for the main and jigger. The "Passat" photos, and another I found of "Pommern", clearly show the brace winches abaft the masts, in agreement with Underhill. In my 1st or 2nd post I mentioned a site with Preussen's belaying plan; this shows the winches ahead of the masts, as on the model. Concern is that after the braces pass through leading blocks near the mast top above the winch, they pass more or less vertically down to the winch. Would they not interfere with the courses, if winch is ahead of mast? I don't know whether to modify the deck plan or not. Can anyone advise? More investigation/help required. Maybe I do need to buy that German book on "Preussen".
  7. Still don't know definitively about those rails in front of the pin rails. However, I did come across some nice pictures of Passat's rigging. She does not seem to have the rails. Was also interested to see the shot of the bows, showing the figurehead mostly white with Ferdinand Laeisz's initials in red. Heller instructs to just paint it gold. I may redo it but it would have been easier off the hull. Pictures of bowsprit guys are also helpful since Heller's "instructions" about them are a bit confusing Interesting to see such things as copper domes on navigation light housings, the ship's bell, which Heller does not mention. No evidence of steering cables running along decks but they may have been removed as a tripping hazard; lots of her rigging is omitted too now. I wonder if that's the Heller Passat model cased in the lounge? http://www.jans-sajt.se/contents/Navigation/Galleries/Germany_Passat.htm
  8. Another little update. I keep thinking of things I could do instead of attempting to solder some brass trusses. Talk about procrastination. I decided to use the same micro brass tubing and etched eyelets to form the futtocks and linkages for the topmast shrouds. The lower ends of the three futtocks have the same etched brass eyes, through which passes the copper eyebolt cemented into a hole drilled in the mast. I should have decided how to do these earlier; it would have been easier before gluing the copper eyes and/or the mast tops in place, but it worked out because this very small tube is easily cut and not so easily kinked. Just need to duplicate on the other four masts, and some sort of version for the topmast futtocks and topgallant shrouds. That will burn up another 88 etched eyes I hope I have enough for this model.
  9. For anyone still reading, Heller provides these low metal rails along the deck in front of the pin rail sections where the shrouds and backstays exist, rather like the foot rail on a bar, or so I've heard. According to them ropes come from aloft and pass under these rails then up to their belaying pins. Is this accurate i.e. did these rails exist? I would think it would be hard to belay ropes on the pins with a wall of them going down to the deck just in front. I'll have a look through what books I have on windjammer rigging but if anyone knows definitively that would be great! Thanks, Ian
  10. Bill, I just used 0.6mm O.D. micro brass tube, available from Albion Alloys (MBT06). It comes in sets of three ~12" lengths in plastic tubes. Easily cut with an exacto knife. The etched brass eyelets are glued in to the ends. Available from various model suppliers, for example: https://www.model-dockyard.com/acatalog/Caldercraft_Period_Eyepins.html These eyes are immensely useful, for example I cut all those nubbies off the bowsprit and replaced with some of these eyes glued into drilled holes. I also used many to form the mast stay attachment points at caps etc. Note too the copper eyelets listed below the etched brass at M.D.; they can come in handy too and are almost exactly the same size as the plastic eyebolts supplied with Heller models like Victory, Soleil Royale, and our current efforts. Useful to avoid a plastic eye breaking as you are rigging!
  11. A quick update - I finished the 146 renditions of rigging screws for shrouds and backstays. This photo shows what they look like, passing down to the deck inside the bulwarks. A big improvement, I think, on Heller's suggested small loops of thread passed through the pinrail holes with knots trapped underneath. I'm getting close to some serious rigging. Just need to form brass yard trusses somehow and oh,... figure out what thread to use. I have three sizes of chain too with probable need to order more of whichever I choose. Probably the 42 link/inch at this scale.
  12. Bill, I already did but no reply yet. Maybe they're in a Covid shutdown. Maybe they just whisked a part into the mail without bothering to reply. I don't know. My French isn't up to phoning them. Since it is the stern railing, and accessible at any time, I suppose I can wait.
  13. It's taking less time than I thought to produce my "shroud turnbuckles". Tedious though. Cut 146 short lengths of 0.6mm OD brass tube and glued an etched brass eyelet into one end of each. There are two lengths - the shorter for the bridge and poop decks where they attach right to deck level, the longer for those which pass through a well deck pin rail and thence to deck. Photo below after most of the shorter ones are glued in. For the poop deck I added small strips of white-painted evergreen over Heller's original holes in the deck, because the tubing is undersized for the holes and I didn't want a glue mess flowing onto my deck. Photo below shows starboard side, unfortunately out of focus as my old camera couldn't zoom in well. You can see the brass with eyes, all at odd angles since they ascend to different locations up the jigger mast. I'll be painting them white. The ones on the bridge deck are secured and painted first coat of white. Again, sorry for the focus. I had a little trouble setting them all at the same height while wearing my headband magnifier. Again, all at individual angles which I set roughly by eye but I will be be bending them later which should not be a problem with these tiny tubes.
  14. Bill, that's a great idea! I will try to contact them about it although I only know the part number in the Preussen kit. I was thinking of asking my brother if he could 3-D print one for me; not sure of the capabilities of his printer, resolution-wise. I was also going to ask him about making me some "iron" sheet blocks......... Thanks again for your help! Looking forward to your "Potosi" log..... Best Regards, Ian
  15. Bill, thanks for your kind words and encouragement. I remember reading a thread, probably somewhere in model ship world, where the author advocated buying a "Cap Horn" (less popular and apparently much cheaper than Preussen on ebay or whatever) and simply converting the jigger mast to square rig and hey presto! - a Preussen. I was aware of Potosi but I thought it was the only 5M barque ever in the grain/nitrate fleets. Apparently as a barque much more manageable than Preussen. Since you have Cap Horn, perhaps you can help me on something. The photo below shows an auxiliary bridge attached to the after storm gangway. The square hole accommodates a ladder up from the after well deck. The central hole is for a second binnacle. Holes near the edges are for stanchions. Do you have any idea what those bucket-like objects along the two sides, outside of the railing, could be? One final comment: my model kit arrived with the curved stern railing twisted and broken. Broken I could patch, but twisted would be impossible to glue onto the stern properly. I figured if I could heat the plastic to soften it I might be able to undo the twist. Well I put it in hot water (I recall some of my old lego blocks getting distorted when I used to take "submarines" I had made into the tub with me). I put the railing in a pot on the stove. I kept pulling it out and it was never getting malleable then suddenly it just collapsed and melted/distorted. I sent a message to the Heller website for a part replacement but I have heard nothing. Anyone - does Heller still exist? Is there somewhere I can get a replacement part? Thanks, Ian
  16. Let's see, where was I?.......I have the bulwark pin rails attached and painted in the well decks. Here is the model with the lower parts of all five masts dropped in. I spent some time making notes about all the attachment points for mast stays...again....and I need to add yet more eyes for them at the lower and topmast caps. I dry attached the main topgallant mast to check the angles of some of the stays using a brass tube. I plan to cut these brass tubes into short lengths and glue in an etched eyelet to form rudimentary "turnbuckles", if rather one-ended. They'll pass through the pin rails and into holes drilled in the deck to emulate the attachments to hull plating not just bulwarks. For the pictures, I sat the top of the boiler house, which includes part of the forward storm gangway, in place. I actually added a piece of rigging, finally, on the anchor crane. Round the capstan three turns and coiled onto a bollard. I just stuck the hook on the railing. The shiny eyebolts will get some matt varnish later. Thanks to Marten's advice I also rigged the steering cables. I formed some guides from old Revell plastic blocks. I filed one face off a pair to form the guides at the rear of the bridge deck. Another two pairs were filed slightly shorter and attached to the after well deck using short lengths of brass rod. The steering cables pass through the after bulkhead. Here is the lettering at the stern. I added Ferdinand Laeisz's initials on the small shield at the centre for lack of a better idea. That's about it for now. I'll check in again when I have the "turnbuckles" completed. This could be a while; I'm busy working jobs and there are 146 shrouds and backstays on this ship.
  17. I admit it's a while since I posted, but the Canadian summer is too short also people finally became comfortable with having me in their home to renovate as long as I wear a mask. When not working, the cottage beckons: swimming, sailing my dinghy, biking, canoeing, wine, rye and ginger......... I have made some progress and I did get the new camera battery. More coming soon........
  18. I hope you get one rkwz! If you buy all of Daniel's etch sheets you will have a museum quality build. Just be sure to obtain a copy of "Anatomy of Nelson's Ships" by Longridge in order to rig properly.
  19. Dear B.E. --- Thank you so much for taking the time to reassure me on the mizzen gaff!!! On my model the throat lies just above the blocks for the davit lifts, as it does in your photos. So that's great. I found when trying to set the angle of the gaff that the limiting factor was the aftermost catharpin, as opposed to the mizzen top. Even in Geoff Hunt's painting the gaff peak lies significantly higher than mine. Now I'm wondering if I set the mizzen futtock staves too low; I made them equivalent to the length of the doubling as for the other masts. I don't need to think long and hard about changing the futtock shrouds - no way, no how! Thank you again!
  20. Alas! I have come to realize that my driver gaff is stepped too low on the mizzen mast! I recall at the time looking at pictures of how high the gaff peak reached compared to the mizzen topmast and wondering why mine could not go that high - I operated under the assumption that the gaff throat must be below the mizzen catharpins, in order for the gaff to be lowered if necessary. Now I think that it was stepped above the catharpins, just below the cro'jack yard and remained there when at sea unless damaged. If necessary the catharpin lashings could easily be cut to allow the gaff to be lowered temporarily. Fixing this would mean re-rigging the mizzen topgallant braces, the gaff peak and throat halyards, the gaff vangs, and more especially the gaff parral beads. It's easy to say but not very accessible to say the least; yet now that I've seen it I can't unsee it. What to do, what to do??
  21. Very nice! Love the sails - how did you get the sail artwork to be so crisp on the cloth?
  22. Hi Bill, my guess is these are water butts for the crew, up high out of the seas washing through the waist. (Sorry I couldn't figure out how to do one of those "quotes" so I just cut and pasted from your earlier post): "......Something I am curious about and someone may know. On the deck house in the back there are two elements that look like upside down baskets near the front. No idea what they are..........."
  23. Hi Marten - Yes I understood you were joking about the 21 strands LOL 🙂 Couldn't find an english version of your magnificently titled German tome on "Preussen", but I did come across "Last of the Wind Ships" by Alan Villiers featuring many many photos aboard large windjammers so I ordered a copy out of interest. Here are a couple more photos of the build. Unfortunately the Li battery for my old camera is on its last legs - now a single flash photo per charge cycle!! - so pictures are limited. I've ordered a new battery. This shows the evergreen stubs I added to prevent the well deck from falling into the hull when mounting. You can also see a wood mounting block for the stand, and the re-purposed part for the supplied stand acting as a support for the rather flimsy mast step My lettering arrived and looks great. There's more in gold on the stern but a picture will have to wait. Next steps are to add the forecastle railings and anchors. Then I will reeve the steering cables as you explained (thanks again) before adding the final deck at the poop. EDIT: Doh! Just noticed the gold letter "N" fell off! Will replace and this time brush over with matt varnish. Speaking of varnish, my old can was a little gummy and tinted; the whitish marks you see all over the black are brush strokes. Any touching of the hull shows up starkly on the black portion. Will another coat with a nice new can of varnish conceal this mess? I could always pass it off as salt stains 😉 I also painted the #63 colour on the bulwark rails. A fiddly job when four coats are needed for coverage. Some touch-ups required. Next I will paint the matte white on the lower part of the inner bulwarks (just below the pin rails) then glue the pin rails in solidly with model glue with no paint intervening, then paint the pin rails and bulwark sides above them. It's looking nice with railings being added. Will replace this blurred photo later. I ran into a problem with the ladders, specifically, the ends are mitered in the wrong direction so if you have the nicely molded steps on the visible side then the bottoms are teetering on just the miter points. If you orient the miters flat against the deck and bulkheads then the rather ugly what-was-meant-to-be-the-back-side-of-the-ladder is visible. Not sure how to fix this; would be awfully fiddly trying to add little pieces at four ends of nine ladders. Buy after market? A second annoying problem is the two pumps. Each is set just aft of a mast, and the mast's bitts enclose both the mast and pump with no belaying pins on the portion of the bitts beside the pump handles. I noticed that the pump shafts touched the bitts before the pump touched the deck. I added tiny slivers of evergreen to make it touch the deck. But now I noticed in a test fit that the pump interferes with the stays running from cleats at the mast foot to the next mast aft. What- really?! You'll notice I have yet to add a single piece of rigging. Once I have the well deck pin rails installed, I will have to manufacture about 160 "turnbuckles" for the shrouds and backstays from micro brass tube and etched eyelets. Then the rigging work can begin. I improved the bowsprit considerably by cutting off all the chunky-looking plastic "cleats" to tie on martingales, shrouds, foremast stays etc and adding etched eyelets in small drilled holes. That was another thing betraying the age of this kit. Unfortunately I forgot to take a "before" photo but it was mighty clumsy looking. Also, the supplied martingale was a flimsy little thing, which was to be butt-glued to the bowsprit. Yeah, that'll hold! I made a martingale from micro brass tube with an etched eyelet in the bottom end, and glued it into a hole drilled in the bowsprit.
  24. Nice looking kit. Good job on the planking. I bought a Billings Wasa in the 70's as a teenager. It too was single-planked, with cheap printed decks including hatches, far less nice than yours, and what did I know about it anyway? My planking was so-so. I remember cursing trying to pin them into the balsa blocks at the bow. There was no internet then with advice and examples. When I got to the point where the next step was "Use the two balsa blocks provided to carve two lions" I decided I was out of my league. I threw the hull out years ago but I STILL have the fittings kit! I've never dared try another wooden kit, although I did make several RC kits and a couple of scratch builds. Then off to University and never touched a ship model for 35+ years. Looking forward to seeing your progress!
  25. Yes, my hull halves were both twisted from being crammed across the box diagonal. If you held the stem and keel together, they both flared out at the stern. If you clamped the stem and stern, then the keel flared apart mid-hull. And it is a very small keel to clamp onto. This long-ish hull is made of very thin plastic, far thinner than the reassuringly thick and solid hulls of "Victory" and "Soleil Royale", and there are very few alignment pins to help you. If you sight along the keel line of each half, the thin plastic ripples up and down a bit as opposed to being a straight line. I decided on a multi-step gluing process. First I glued the stem and 2-3" of keel. After that dried, I glued the stern and 2-3" of keel. When that was dry, with the ends fixed, it was relatively easy to glue the remaining keel, aligning as I went, and clamp with small paper clamps. I added some wood inside to straighten the keel; a bit tricky when there are five mast steps inside the hull. After gluing, when I dry-fitted the forward well deck it did not align properly with both hull sides - there are little molded-in vertical "stops" in the hulls to locate the midship end of the deck, as well as the horizontal support tabs. There was about a 1/8" offset(!), which could be corrected by twisting the hull slightly. When gluing I sat and held the hull securely with the deck aligned until the glue set up. Same observation and procedure with the after well deck. Even the bridge deck required some hull flexing to align! But in the end it all turned out, although I'm not absolutely convinced that there isn't a very slight remaining hull twist. Hard to tell by eye. A final note on adding the bridge and well decks: there are small "ledges" provided inside the hull to locate the bottom face of the decking, but they stick out LESS than the molded triangular "webs" reinforcing the bulwarks above deck level. So every time you press the deck past the bulwark webs, it falls into the hull past the ledges!! VERY frustrating! I added a few bits of evergreen projecting further out, below the decks, and it became child's play to slide the well decks in from midships due to their taper. This also avoided smearing model glue on the bulwarks.
