RGL
Everything posted by RGL
  1. Her movements in the last 6 months of her life were non stop, thus the flogging it's getting. It's also nice to try some new techniques just takes lots of forward planning and components
  2. I'm thinking 1945 in constant action would beat it up a bit.
  3. There is method to my madness, some photos of what I'm trying to achieve (somewhere in between)
  4. Now, just add water. The ribs have come up OK, and a lot of it will be covered up anyway. I'll let it dry for a while then a matte coat and do the upper half. Once that's done I can start to add rust etc.
  5. Back to the hull. I have sprayed on some 'worn effects' fluid over the pre painted parts of the hull then about 4 shades of red trying to bring out the frames and hull plates. This photo from another ship of this class shows them up nicely. Ill give it it a few hours to dry then start rubbing back sections to reveal the undercoats. I have used some Mr Surfacer on the bottom which when oversprayed with black and grey may represent barnacles, then a bit of rust and alge.
  6. Nah, anyone could do this. The seriously good plastic modellers are usually Korean or Chinese and if I could find their blogs to learn something I couldn't read it. I just follow the instructions. Married a long time, that'll do it.
  7. thanks. The depth charge racks and mortar, will get a bit more weathering when finally fixed on.
  8. I'd rather leave a gap than bend the PE or leave great globs of glue. We've all got a skill level still to attain! Now, extra after market depth charge racks. The kit ones are atrocious and didn't bother with some bits and neither did Flyhawk. The kit depthcharge thrower is pretty pretty good but just not on the instructions as they provide multiple spruces for multiple kits for some reason. This stuff is nice... there is actually only one main rack, the first one is a practice fret that is .1mm out (my fault).
  9. Yes mate, a little gap, paint will bring them closer! Or maybe a tiny bit of mr surfacer, I'll see how it looks after the primer coat. Depth charge racks today.
  10. From experience the only way it works is to cut the very first spoke too close to the fret, and make a pilot hole for it, otherwise it just does not work. As there is a curve you can't guess where each hole goes and it looks like crap as they don't align or you use too much glue. They're horrible to install.
  11. Ah, that's why I do them poked onto a stick in a vise then! Sunday afternoon, and all three stacks complete and ready for paint. They are fairly fragile so I'm thinking the airbrush will knock bits off.
  12. Started on the funnels. The kit provides 3 pieces per funnel, so tossing one piece and stripping and sanding it down, started them again also using brass rod as the external steam vents.1/3 done.
  13. Thanks Mr Fly but I just glue stuff together and paint it. The advantage of a smaller kit is taking more time on the smaller details.
  14. I think I've still got a bit to go yet unfortunately. Yours should outstrip mine old boy!
  15. Rear mast and crane complete. I imagine this would be pretty grubby given it sits right behind the stacks.
  16. Thanks folks! Love your Endeavour Dave, it seems strange only having finished mine 2 years ago how you guys are catching up and so many improvements on mine.
  17. They're not MG stands/brackets? I agree on too small, sometimes it's just a bit too gimmicky to produce a .1mm x .1mm thing and even expect it to stand out yet alone be able to be glued.
  18. The gun platforms for the high angle 76mms and for the other triple 25mm's. I have dry fitted some sandbags around the flat platforms which house the 76mms. Also the amidships searchlight. Lots of small deck details to go.
  19. Weathering on the bridge is done, rust, grime and salt. I reckon I'll just leave it alone now as I'm tempting fate as I'll stuff it completely.
  20. There's some footage of one of this class of cruiser on Utube where the decks are covered in ice, that would be over rated with an open deck.
  21. Radio direction finder, tripod mast and mast placed. I have not glued it to the deck but it's the only way I can get it to align. A bit of touch up then weathering.
