Everything posted by RGL
Fairey Gannet by RGL - FINISHED - Trumpeter - 1/72
RGL posted a topic in Non-ship/categorised builds
I needed a break. Opened the box and so few parts! No aftermarket For this one as it’ll be pretty crap but I need a cleanser. Luckily I bought up on Infini models sanding paper. I also seem to have lost a propeller! Just missing completely . -
- 35 replies
- 35 replies
- 35 replies
- 35 replies
- 35 replies
The deck, dark grey base then two lighter shades to represent paint fade. Then a brown overspray to represent worn down to metal. I have a tan overspray on the wooden deck. My plan is to do some filters and some paint chips and washes. as you can see pretty much everything else is the paint cue, which will make it easy to finish.
- 35 replies
The hull is a pain to fix at the waterline. I’ve scribed in the hull plates and I think I’ll grunge up the lower hull below the boot strap.
- 35 replies
The two part hull which does not match up is a pain, meaning I have to redo the hull plates, everything else will be paint and plant.
- 35 replies
Next should be a quick build of a resin 1/350 Bathurst class minesweeper by Pacific Crossroads. Nice PE, resin and this will be a OOB build.
- 35 replies
I’m seriously going to need a new cabinet soon and could not fit another carrier in there.
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
So there we go, three USN Carriers done. Next I will have to decide on a few Aussie ships and a battleship later in the year.
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
Getting the rigging done, the kit comes with an excellent rigging guide (best I’ve ever seen ) and research states her call sign is November kilo yankee tango so teh falga match.
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
Truthfully no, I actually like the ability to move it if I have to, this stuff is paper thin and fragile
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
A gloss coat works better. No idea why. Glue is problematic as it’s hard to get a good even spread so just put out spot fires where needed using a metal shim and CA
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
Oh it’s popped up in several places, change in temperature here to the mid 30’s. I forgot to gloss coat the flight deck under it first. I’ve already re glued it
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
I’m in the process of adding the life rafts. These sit along the gantries, the PE set gives you netting which runs purportedly along the railings but the reference photos show them at 45 degrees with a railing running along the top and the liferafts lashed to them. Also the ends of the flight decks are starting to lift as we have had a spate of unusual humidity.
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
So I entered my first ever Model competition this weekend with Seydlitz & Zeppelin. Did OK. Best in show and best ship and best ‘what if’ for Graf Zeppelin
