RGL
Everything posted by RGL
  1. Dandyfunk, this photo from the Gambier bay book, shows extra fire hose in a carrier. The Flyhawk set provides this in a silly 2d piece and a rack. I used some offcut PE folded over and over.
  2. Now so it does not look like a bathtub toy, some weathering, a simple grey filter, some grunge and rust.
  3. So starboard side in 1944, quick check on the reference photo and its a tad different to the plans near the stern.
  4. The great unmasking. I’m going to need to sharpen a few lines on the starboard side but pre filter and weathering I’m happy so far
  5. Painting time, next few hours of masking to get the gantries covered.
  6. Thanks, the Hasegawa PE give you an option for a cover on the bridge that was unique to the Gambier bay or for all other types that Flyhawk doesn’t. Essentially the Hasegawa set is very limited but nicer with tighter tolerances. The Infini radar comes with turned brass pedestals and is hands down nicer. Both Flyhawk and Hasegawa continue with manufacturers making disjointed and confusing instructions which means using three sets took me three days and I’m still confused.
  7. Ready for paint, the bridge done. Bloody hard work, I used the best parts of the Flyhawk and Hasegawa PE sets and swapped out three different radar sets for Infini radars
  8. So for safety I painted and masked up the lower hull, gantries have been glued on, there are support trusses and some other stuff that I’ll glue on it tomorrow.
  9. All 4 parts of the gantries detailed up. Lots of railings etc to go but for ease of painting and weathering I’ll leave them open for now.
  10. Hard corners where things would rub or bump, such as the anchors hitting the hull, plates that would have paint worn away, that would be the chipped bits then the rust would run from them. Have a look at my Borodino or Graf Zeppelin’s rust.
  11. Added a bit more detail, added fuel hoses and folded up fire hoses from offcut PE
  12. These gantries are very very busy, lots of Details to add, fuel, fire and other stuff.
  13. A full day cutting out the flight deck gantries and adding what limited PE there is. I won’t add the railings for nets until painted but lots of super detailing to go. apparently the fueling plans and barrier controls and catapault controls were the same as the Essex carriers
  14. I need to move onto the dazzle pattern soon. Thing is, the colours (from the chart above) are different to the kit plans as well as the masks and dazzle design are different between the Gambier bay and Thetis Bay
  15. Lower gantries, the PE is supposed to sit on top of the plastic, so I’ve retained the sponsons and cut away the rest of the plastic. No such luck with the ones that run along the flight deck and nowhere as near as good as a Pontos set.
  16. Hull joined up, comes together very nicely, I’ve put the fuel lines on the side of the ship,
  17. I make all mine so they can be removed at any time from the base. You’ve got lots of ‘handling’ to do yet. Don’t be in a rush to put the deck down or stick her in. Once you get the bootstrap and lower hull painted I’d mask it off (acrylics do scratch easily) then put her on as you don’t need to rotate it as much.
