Everything posted by RGL
Apparently on her way back from the middle east to Singapore she nearly lost it (mast) It’s aluminium so I can’t cover the sins with Rust like I usually do.
I thought that I may as well keep buildings as opposed to painting yet. Lots of PE. The main mast is going to be stripped again as it’s not aligned properly I did manage to buy a VLS for the fore deck from a discontinued set second hand
Lower hull pretty much done. I’ll eventually give it a bit more salt streaks once the hull is completely done. I gave it a wash of enamel green slime
There are lots and lots of gaps. The plastic does not quite align. Now I’ve gotten all the main bits of PE down, I can fill cracks and gaps, smooth it off and fix the bits that invariably fall off, give it a primer coat then make a start on proper painting
So I painted the interior of the hangar, now I’m in the process of sticking it all together. Painful gaps .
So this is as far as I can go before starting to throw this but together. I need to paint the interior of the hangar, mask it off then stick to together. the bow supports are three little strips of PE. No other details will be added until the deck is painted
Port and starboard side of the superstructure done up (lots more details but this is as far as I need for painting, and the roof with lots of cut and sand to go.
They’ve got some nice(ish) stuff but the shipping is horrendous from the US to Oz ($25 USD for a very very small parcel) which you cannot track (they say you can but you can’t) and I will be finished by the time it gets here as it’s over six weeks. I ordered the Duck months in advance from shapeways and the product is poor (actually rubbish) and slow.
Starboard side superstructure base half way end lots of holes that need to be made where ventilation shafts exit the hull
So checking my references I need to add another ladder as well (only Sydney had an extra)
