RGL
Everything posted by RGL
  1. The two part hull which does not match up is a pain, meaning I have to redo the hull plates, everything else will be paint and plant.
  2. Next should be a quick build of a resin 1/350 Bathurst class minesweeper by Pacific Crossroads. Nice PE, resin and this will be a OOB build.
  3. I’m seriously going to need a new cabinet soon and could not fit another carrier in there.
  4. So there we go, three USN Carriers done. Next I will have to decide on a few Aussie ships and a battleship later in the year.
  5. Getting the rigging done, the kit comes with an excellent rigging guide (best I’ve ever seen ) and research states her call sign is November kilo yankee tango so teh falga match.
  6. Truthfully no, I actually like the ability to move it if I have to, this stuff is paper thin and fragile
  7. A gloss coat works better. No idea why. Glue is problematic as it’s hard to get a good even spread so just put out spot fires where needed using a metal shim and CA
  8. Oh it’s popped up in several places, change in temperature here to the mid 30’s. I forgot to gloss coat the flight deck under it first. I’ve already re glued it
  9. I’m in the process of adding the life rafts. These sit along the gantries, the PE set gives you netting which runs purportedly along the railings but the reference photos show them at 45 degrees with a railing running along the top and the liferafts lashed to them. Also the ends of the flight decks are starting to lift as we have had a spate of unusual humidity.
  10. So I entered my first ever Model competition this weekend with Seydlitz & Zeppelin. Did OK. Best in show and best ship and best ‘what if’ for Graf Zeppelin
  11. I think they are the seam lines on the wings were painted maybe as a weatherproofing as did transport last it’s the only thing that makes sense to me
  12. Are you using acrylic or enamel? AK goes done excellent washes that will dull it down
