Everything posted by bruce d
Hello Nils, I'm a little late but will try to keep up. A nice subject, it will be impressive at this scale. Bruce
- 330 replies
Archaeological Evidence for the Development of RN Gunnery
bruce d replied to Steve20's topic in Nautical/Naval History
Wicker? -
Thanks Steve, he has chosen some interesting examples. -
"Russian Nagant M1895 revolver with an attachment slot for an axe, developed in 1905 for the Russian Navy as a specialized revolver-axe combination for boarding enemy ships - the axe could be used as a shoulder stock for more accurate fire, or just as a regular axe." I'm glad I was never in a boarding party.
Report of the Commission Appointed to Examine the System of Constructing Boats by Machinery. 1859 The illustrations tell the story well but the tone of the text in the reports starting on page 88 is fun reading: they are almost embarrassed to admit that it works! Report of the Commission Appointed to Examine the System of Constructing Boats by Machinery.pdf
Hello Chris, Everybody should have a bandsaw. Well, that may be a little over the top but they are useful. Tools should be appropriate for the job. The big question is ... what do you want from your bandsaw? What are the model-related tasks you want from this tool? My bandsaw is a Metabo benchtop model (don't think Metabo is sold in North America but they may be wearing a different badge) and I use it all the time. It has a throat about 200mm so it not big but has adequate power. For modelling jobs I usually swap over to a 6mm (1/4 inch) blade and this gives good performance on curves. My point? I don't need a bigger throat, more power or a large table for modelling jobs. The wider blade I use for ripping, the metal cutting blade etc. have nothing to do with modelling tasks. I can, at a push, mill small logs using a fixture I built, and I also mill some modest size blanks to run through my thicknesser. I could do exactly the same tasks with exactly the same results on a larger bandsaw. If you choose a larger bandsaw for more versatility on other workshop projects you can and still use it for the small jobs if you are prepared to swap blades to suit; however you can't do bigger jobs on the smaller bandsaw. My advice is to focus on quality and spend time learning how to set it up properly for different tasks. In my opinion there are only a couple of features that are mandatory regardless of size: an accurate cast table and decent guides. Once you have these, setting it up correctly should be straightforward. Let us know what you decide on 👍. HTH, Bruce
I am doing things with Swiss pear that includes some thin sections, typically 2mm x 3mm. The grain is sometimes with me and sometimes not. Not surprisingly, the narrow pieces with cross-grain are fragile. Any thoughts on strengthening this wood? I am thinking of what flying model builders do when they smear CA across balsa and increase it's strength substantially but that isn't going to work: I need to apply a finish. And no, sadly I can't laminate pieces to create plywood. Thinking out loud here ... does shellac add any strength to wood? I'm stumped. Bruce
Just saw this so I am late to the game. I have seen documents in The National Archives UK where the handling of boats by capstan is advocated. Sounds simple to us now but apparently in the mid-late 18th century it was not standardised. One captain even requested a capstan for handling his longboat. This would keep the main capstan free for victualling, anchors, booms et al. A possibility?
