Rossi46
Posts posted by Rossi46
trying to balance time between a home improvement project and the boat, but managed to get some more of the detailing done and starting on the top deck cannons. I chose to use a loop and hook to connect the blocks to the inside of the boat, looks nice and I was having a heck of a time twisting the little metal loops around the block. Also, I came upon my first situation with missing parts. The brass posts for the railing were missing 4, so i repositioned what I did have and evenly spaced them. No problem.
I live in windsor ontario. I'm leaning towards kit bashing, but could easily see myself ending up scratch building and really getting into carving. I had no idea what the possibilities were until I started digging into the posts on this site. But I don't want to get ahead of myself with the scratch build stuff, which is why I'm looking at kits that get you on your way. I'm looking more and more at smaller boats done in larger scales ie. greater than 1:40, to get that authentic look. so much to sift through its overwhelming. My dad just got the Chaperon, and that looks like a blast to build.
Im so new to this im not sure how to source wood for a scratch build. Do you buy sheets and cut your own planks, buy prefabricated planks in the size you need. I ask because i have a dremel, file and a knife and thats about it lol
- Eddie, Ryland Craze, EJ_L and 1 other
- 4
Great work! I can even hear Jack Aubrey playing his violin.
Im an avid audiobook listener and plan on getting the aubrey books. I havent read them before
- mtaylor, HIPEXEC and billocrates
- 3
Thanks. I expected it to take much longer to get to this point to be honest, but doing an hour or two here and there and its really going quite quickly considering.
- russ, coxswain, billocrates and 7 others
- 10
Hey folks,
Im currently mid way through building the HMS Surprise and would like to start researching for a future build. I was hoping to hear your opinions on what is the ultimate kit out there in terms of detail, quality of wood and parts, instructions and sheer presence.
What are some of the very highly regarded kits out there... Royal william, SOS, Victory etc... Or any large scale models of smaller boats. Im looking for something very stunning or with a really cool story behind it. Or a high quality large scale viking boat. Any guidance would be appreciated.
Hey neptune. Much appreciated, i will be refencing your build log extensively, especially for masts, rigging and sails. Very informative and quite intimidating lol. The flickering effect is great in person, and multiple lights in series all flicker independently.G'day Rossi, very, very nice build, and your first as well, she looks fabulous, I like he candle touch, look forward to the rest of the build,
best regards John.
PS my friend gave me one of those flickering LEDs to go in the furnace of my steam launch, but I hav'nt got round to setting it up yet, if it comes out as good as yours I will be well pleased.
Quick question, is there a build log on the royal william, it dwarfs the
She's looking great and that led candle looks amazing but the electronic engineer in me is concerned with if you have a resistor in series with the led looks like you are using a 9v battery which is far to much for an led, or does the led have a built in resistor.
Cheers Rexy
Great point rexy. The led's do have a resistor built in to the line. The guy sells them as kits with required resistance depending on power source, but a very good point to note. I got the 9v setup.
- billocrates and mtaylor
- 2
I also settle on a colour scheme for the launch and inside planking, cannon ports. Happy with that. This pretty well catches up the build to where I'm at now, so updated will come much slower, but I will do my best to keep the info and pics coming. I wish I could add a video of the light effect, it just so hard for the phone still pic to capture it well.
- maddog33, shipcarpenter, GemmaJF and 11 others
- 14
Happy with mast alignment. Had a little trouble with drilling mast holes when using a bigger drill it. Had some tearout that required surgery, but that is the great thing about wood! Besides, I try to be thorough and calculating, but I'm not too worried about making a mistake, its part of the learning process. The way the ended up working for me was to drill a rough outline(smaller that required) of the mast hole with a tiny micro bit and dremel, then cut the rest out and file to size.
- Landlubber Mike, maddog33, coxswain and 2 others
- 5
Now on to the some deck accessories and cannon rigging. I went with something different for the rigging, as I was having a very hard time twisting wire to make loops for the little blocks. So I used the loop attached to the side of the boat as a makeshift block because it can't really be seen. On the upper deck I will use a different approach that will use a little hook attached to the block.
Here is the rough layout, with a phishing wire run through the table leg, for pulling through the LED when it came in. For the LED, I chose a 1.8mm flickering yellow LED from Evan Designs Shipworks. He has tons of stuff and different colours for different applications. The flickering effect is awesome and completely random.
To create the candle, I ran the LED through the leg and shaved down what I could to get as small a profile as possible. This is also why the table legs were so thick, to accommodate the wire and hole I had to drill. Then I wrapped dental was around the LED assembly right up to the very tip. I painted the whole thing white, with varying thickness of paint, to give the glowing effect of a candle with the wick burning down into it. Worked great, and pictures really don't do it justice. Very pleased.
I had to grab the book so I could call of the parts by the right name lol. Next I planked the captains quarters and built the wall. I screwed up the planking by coming up short, which was partially due to an illusion in the manual pics. But I should've caught that. I fixed it by adding a couple of strips of sapele laminate as an "entry transition". This provided the space I needed for the furniture plans. I also laminated the edges of the door so you couldn't see the layers of plywood and added knobs/mortise. Again, it was fun so I did it
- maddog33, russ, billocrates and 2 others
- 5
- maddog33, mtaylor, Bishophobbies and 3 others
- 6
The book is a replica of Darwins famous book, not period correct but I don't care about that stuff as much. Its fun, and that is what this build is all about. Scale wise, I just tried to make stuff close, as long as it passed the eye test it was good for me. As you may notice, I used a mini dremel bit to drill through the leg of the table, which is where i plan to run the LED wiring for the candle.
- coxswain, GemmaJF, Bishophobbies and 8 others
- 11
What is the most EPIC kit available???
in Wood ship model kits
I've heard from a few people about this kit, noone seems clear when it is getting released, but its on the to do list. I think I'll be able to finish the surprise and then do one more before tackling that beast. I'm leaning towards the billings boats Oseberg Boat. Not as detailed and appointed, but I am really interested in its story and have always loved the lines of the old viking boats. Plus a smaller project will put me in the right frame of mind for the monster Victory:)
