Jdieck
About Jdieck
  • Birthday 04/04/1952
  • Gender
  • Location
    Maumee, OH US
  • Interests
    Building HMS Vanguard from Amati Kit.
    Previously built, San Francisco from AL and San Juan Nepomuceno from AL.
    Other interests: Reef and planted aquariums.
983 profile views
  1. I had the pleasure to build the Vanguard and just finished it about a year ago. Here some of my coments for what is worth. I built the model with sails but to keep scale I used a very thin high count thread swiss fabric called bearissima used mostly for hairloom clothing, great to work with. I replaced the carriages using pictures of the canons from the HMS Victory museum and as a basis for scale used the proportions given by the almiranty for the construction of those carriages based on the weight of the cannon. I used the provided canons although they needed detailing. Blackening the cannons did not work very well so I ended up priming and air brush painting them (as well as all photo etched parts) with very good results. I was not pleased with the riging blocks provided, I recomend replacing them using blocks from Siren, wonderfully made. For the windows glass I did not used the acetate provided but used the white liquid that after drying becomes transparent. It is used for plastic models and can be found on modeling stores or websites. It gives a more true to reality look. The PDF material is top quality and far superior to any plywood I have ever worked with before. In all respects it is better including resistance to warping, rigidity for a stright hull, sandeability (wear a mask), strenght and easy to glue. Liked it so much that I used some of the scraps to build some jigs to help in construction and alignment. Finally I want to mention that in the rigging plans there are some missing belaying point references. Chris published a drawing including them, if you canot find it shoot me and email (jdieck@diesyst.com) Also if you are interested I had a mahogany table and lighted case built for it and have some information about it if you need it. Enjoy your built but be patient. You have your path set for the next three to five years with this kit Jose
  2. Doing great Bob.. At least you did not break the dolphin striker like I did and had to replace it pins and all and of course its rigging too!! Bu the way. Count the parral beads for each yard. I ran out of them and had to order a bunch to complete only three I was short.
  3. Hi Bob: Arthur described the process to install the parrals very well and the final product is closer to scale. In any case there is a short cut that may not be pure scale but the difference may be barely noticeable. Get a thread of good lenght, the longer the easier. Thread one end through the bottom of the yard and the other throught the top of the yard on one side of the mast. Thread the parrals and ribs on both the bottom and the top threads. Pass the threads on top and bottom of the yard on the oposite side of the mast and tie both ends in front of the yard, apply some glue to the knot, cut the excess thread and you are done.
  4. Hi Bob. Be patient. It is looking very very good. For what is worth, I had to tie more than half the lines to the rail in front of the mast.. If you look at pics of the model prototype, it seems that Chris did it that way. Seems not to be other practical option. Also you can consider tieing the lines and add false coils later. Best regards and keep up the good work.
  5. Thanks Bob, the party was great, ate like a pig. Now on a diet to lower what I gained and get my sugar back to normal Enjoy your vacation as you have some threads waiting!!
  6. Thank you Bill. Arthur, your model is unsurpassable and Bob here is doing a great job! One thing I was not happy of how it ended up was the serving. I used very thin line and after taring the rope the serving is barely visible. You can only noticed on portions of the stays but not on the shrouds. Experience for the next one I guess.
  7. Best photos I could get with the ipad Sorry. As you can see, it was a nightmare getting all of them in there. Also As you can see I was very happy with the top quality of Chuck's blocks, smooth, two holes, properly rounded and grooved for the rope and ties.
  8. Crowded indeed. With sails it adds four or six more lines on each bit. I installed four belaying pins on each bit but more than half of the lines I had to belay just around the cross member of the bits. Install one, rip two... LOL ; -)
  9. I used Chuck's blocks so just now I realize the blocks on the kit have only one hole. More complicated having to watch for block orientation. Good you could correct it. Great work.
  10. Wow Bob. 45 inside the house is a lot. Hope you at least get a fan and pleanty of your favorite beer.
