Everything posted by mtbediz
mtbediz replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Actually, about a week ago, in my post number 467, I mentioned that I was making a model of the ship as it is today and that the bulwark and rails would be different from the MS kit. I even remember mentioning this in my previous posts also. I think you missed that. -
No, I won't add them because I'm making a model of the ship as it is today. -
Thank you so much Peter. Since I was not initially focused on making such a detailed model, there are some minor mistakes that is due to lack of planning and which the viewers may not notice however, overall I am happy with the appearance of the model. -
Since, at this scale, it was not within my abilities to make the equipment in the images sent by friends, I settled for making it as in the photo -
Thank you very much, friends. These are wonderful pictures and drawing. Everything looks very clear, it will be very helpful. -
The main rails at the front of the ship have been completed. (It is worth reminding again. Since I am making a model of the ship's current state, the rail system and bulwarks are different from the ship's MS kit). Breast knee and pin rail were fabricated but not installed yet. At this point I have a question for Jon and the other friends. In the internet images of the ship, the main stays appear to be connected to the breast knee via bullseyes, but the images are not clear and the details are not visible. My question is; How are bullseyes attached to the breast knee? If anyone has an image that clearly shows this detail and can share it here, I would be grateful. -
Thank you so much for your efforts, Jon. If I were to build the catheads according to these plans, I would have to cut the waterways. Since I didn't want to do this, I shaped the cathead according to the waterways. -
Thanks Greg and yes, to create the half-lap joint I used my mill. Once you start using your own mill, you will realize how much you can do with it. -
I'm glad I could contribute, Peter. In a boat building video I watched on YouTube, I saw boat builders making the stempost of a sailboat using this method. Since I experienced in my previous models that bending wide boards was very difficult or even impossible, I planned to try this method on this model. I am glad that I achieved a good result. -
I started the main rail. I'm making the curved rail in the bow section differently this time. In my previous models, I did it by cutting, but this time I am making it with a different method. I cut three 2x4 mm of baswood strips according to the size and kept them in hot water for 15 minutes. Then, I clamped the strips into the mold I prepared before and waited for it to dry. Then, I applied PVA glue between the strips and clamped again to the mold, waited for the glue to dry, and removed it from the mold. -
Thanks Greg. I made the large cleats with the Proxxon mill, the smaller ones were made by hand filing and sanding. -
In the bow section, I have almost completed the interior planking of the bulwarks and the accessories on the bulwarks. I first assembled the cleats and steps made from scratch onto the planks, then glued these planks into place. -
I don't know why you need an extra layer but If the issue is aesthetic requirement maybe instead of the 1.5 mm second layer, you might consider adding a 0.5 mm veneer, as many modelers do.
- 233 replies
- Model Shipways
- constitution
(and 5 more)
Thank you Peter. Yes, these details can be added on the model, but it is easier to do it beforehand. -
Thank you so much. -
Thanks Jon. Yes I can wait for the plans. -
Jon, Peter; Happy Thanksgiving to both of you!!
