Ondras71
Everything posted by Ondras71
  1. Thank you very much Steven and Bossman!! I appreciate the favor of you all. Front gratings and front mast holder.. Deck boards will follow ..
  2. Thank you very much Chuck, Patrick and Tom!! Continuation of gratings. Absolutely accurate system.. Preparation of deck beams for forecastle..
  3. The whole hull waxed outside.. I'm making new gratings for the front deck. I tried a new style of production with a 1 mm cutter on one side, it works and it's more accurate than a saw.. Comparison with old gratings..
  4. Thank you very much for like .. Door and window fittings .. waxed ..
  5. Thank you very much archjofo and Sea Hoss.. Front body wall .. Medical needle 0.7 mm made pins 0.5 mm .. Stairs worked glued temporarily with glue..
  6. Deck ground 240 grit.. An edge cutter made of waste.. Deck ready for wax ..
  7. Thank you Barbossa. Maple strips were overhead .. I finished the deck planks. I'm just sorry half will be hidden, including hooking.. Next will be grinding .. Main deck..
  8. Hello Barbossa. Maple wood has an ideal hardness, it is well cut and sanded, it holds the edge.💣
  9. Other boards with hooks.. Center of deck .. The last boards at the waterway ..
  10. I slowly continue to lay the planks of the deck. So far, whole boards without hooking .. O. Beautiful photos from the Duyfken deck exchange..💣
  11. Absolutely honest work archjofo !! I'm taking off my hat..!!💣O.
  12. I create "binding strake" boards from linden wood, the deck will be made of maple.. The boards are pinned and provided with paper before laying.. Binding strake laid .. Other boards will be narrowed..
  13. Very beautiful work YankeeD !! I admire your work with gratings, now I also create them, I can appreciate it. Your grooving system on one side is great, I will use it next time as well.
  14. I created frames gratings for the main deck.. I'm starting to lay the deck. There are thicker "binding strake" boards around the gratings. I want to make these from wood contrasting with the deck. I took the liberty of addressing Ab Hoving with the question: May I use the layout of strake boards on the main deck according to his reconstruction of the "WITSEN" pinase? The boards in question are the ones on the sides of the gratings and also the boards closer to the center of the deck around the masts and equipment? Laying the planks of the main deck I will do according to the replica Duyfken ..
  15. Basics of gratings done. They will now be placed in frames..🧐 O.
  16. I did not find a 1 mm saw blade at Proxxon. I got a saw blade from a friend, probably in the former DDR .. Its center is 16 mm, filled with ring 10/16. The preparation is made of waste, the work took a very short time. Ondras Thank you, Patrick
  17. Thank you very much mtaylor, thanks everyone for like.. Continuation of work on gretings with 1 mm thick saw blade ..💣💥
  18. The foundation of all hinges .. Halyard knighthead..
  19. Thank you Tigersteve. I used a 1.1 mm Proxxon blade, but it is thick. Waiting for 1 mm. So far it has been a system test.⚒️ O.
  20. Thank you Ccoyle!! I continue on the waterway, I changed the width of 5 mm to 4 mm in the width of the deck boards.. Waterway with pins and glued .. and cleaned drain holes .. Production of hinges for doors and gun gates .. New toy to study ..
  21. Glued deck base.. Drain in waterway.. Tack block.. The exact lower diameters of the masts were measured according to the book History Ship Model - WzM..
  22. After closing the main deck I found out that some equipment could be seen through the cannon openings. Made pumps and chimney. Capstan will be made later.. Furthermore, holes have been created for the Halyard knighthead.. Rowking on waterway ..
  23. Thank you all, I am grateful for your feedback.. Ondras Already glued lower cannons.. Next will be the main deck, preparing frames gratings.. Mainly cannons stored, blackened and placed at the end of construction ..
