Everything posted by Keith Black
Hello! New to the forum, happy to be here :)
Keith Black replied to BuckyBoo's topic in New member Introductions
BB, welcome to MSW. Hoping your Bluenose goes well. Glad to have you aboard. -
Thank you, Paul. Thank you, Steve. Those photos in my last post were bugging me so I took what look a little better. I had also wanted to include a top down photo of the three cylinder model. When the engine is completed I'm going to ploy coat it due to machinery paint gloss, oil, and moisture. I think it will look more natural with poly coat than flat black.
- 457 replies
- sternwheeler
- Hard Coal Navy
Thank you to everyone for the comments and likes. There should be a steam engine in there somewhere. In the heat of battle. All that mess working on a piece less that an inch long. Cylinder heads and steam chest glued to plywood backing. I have a large work surface but invariably I work at the bottom edge of the table, that's why I have so many escapees. The top end is done. Horrible photo, no more taking photos on a white background. I'm pleased with the top end, hopefully I can get the bottom end to match. It took 31 pieces to make the top end. I was trying to hold the top end length to 0.70 inches but it came out to be 0.90 inches. This means the completed engine will be about 1.1 inches, to scale that makes the engine 11 feet in length. What a monster! Thank you for your support and for following along. Keith
- 457 replies
- sternwheeler
- Hard Coal Navy
Thank you, Roel The below photo is the best for showing the exhaust. As much as I tried talking myself into the engine being a triple expansion I couldn't because of this photo. Thank you, Phil. I have enough engine photos to move forward as they all look close to being the same. Finding mention of a special four cylinder marine non condensing engine allowed me to consider and make that engine. Good news, the engine build is going well. Hopefully I'll be able to post photos this evening.
- 457 replies
- sternwheeler
- Hard Coal Navy
To me that sounds the easiest and most accurate way to do it, Jacques.
- 139 replies
- ancre
- Bateau de Lanveoc
Regarding the steam engine. We know it was a non condensing steam engine because we see the exhaust being emitted directly into the atmosphere. We know it was vertical steam engine and not a horizontal engine. We know the height was no more than four feet high as the exhaust pipe from the engine can be seen through the engine room window viewed from the bow. If it was an expansion steam engine the exhaust would be water. The idea of a non condensing expanding engine is not a possibility according to what I've read and I've done a bunch of reading/research over the past two days trying to come up with an engine design I can make. The power of a two cylinder expanding engine was only suitable for a launch, so that eliminates a vertical two cylinder non condensing engine because of the lack of power and a vertical three cylinder non condensing engine also sounds like it wouldn't have also had the power to push barges. I did find a photo of a model of a vertical three cylinder non condensing reversing engine, see photo. They did make a special marine vertical four cylinder reversing non condensing steam engine but I can't find a model or better yet, historical photo of one.I did find a photo of a vertical four cylinder reciprocating (V-4) but that wouldn't work because there would have two exhaust pipes coming off the engine, not one. The vertical marine four cylinder reversing non condensing steam engine was powerful and smooth running engine. Because of the length of the drive shaft and the wheels being gear driven, minimizing the amount of vibration would have been a huge factor. What's a guy to do? The only thing I know to do is get creative and add a cylinder to the three cylinder engine shown. "Houston, disregard that last transmission" ....
- 457 replies
- sternwheeler
- Hard Coal Navy
Craig, John, thank you both so much for your kind comments. It's high praise coming from the builders of the beautiful Twilight and Klondike models.
- 457 replies
- sternwheeler
- Hard Coal Navy
Welcome to MSW. Do we need another....you bet! Glad to have you aboard.
Thank you to all for the comments and likes. Quick update... The knee braces and winches have been added and that completes the bow face except for the deckhand and he will be the last piece added to the model. With the exception of the water and steam pipes the boiler is done and glued in place Next on the list is the steam engine. Thank you for the support and for being part of the journey. Keith
- 457 replies
- sternwheeler
- Hard Coal Navy
Thank you, Keith. I just asked Mr Google how many homes in Britain are still heated with coal and the answer was 30,000. I then asked how many narrowboats and wide beam boats there are in Britain and the answer was 35,000. I watch several YouTube videos on canal boating and several use coal to heat their boats. I would think coal usage is declining but you and the canal boats seem to be hanging on.
- 457 replies
- sternwheeler
- Hard Coal Navy
Crank up some Pink Floyd for Mrs Knocklouder and see how she likes them apples.
- 254 replies
- Victory Models
- Pegasus
(and 3 more)
Thank you guys for your kind and informative comments and the likes. I appreciate your support so very much. The first time i saw the photos of this push boat I was smitten with the ugly, dirty, quirkiness of her but I had serious reservations when I started the build not knowing if I was going to be capable of doing her justice. It's only been in this last week that I've really warmed to the build as the work has finally developed a rhythm and flow and now I'm having a ton of fun, let the devil take the hind quarter. First off, I want to apologize for the following photos.......bad camera day. The steel plate is painted but not yet glued down. I looked at beads and a whole slew of other options for lightbulbs but nothing worked as well as the belaying pins. I did try filing and sanding the shape from egg to ball, they're now acceptable. I added coal to the coal crib and the auto stoker's conveyer belt. Coal has a slight gleam to it so I lightly patted poly on top of the coal to give it just a hint of shine. I also got the conveyer belt tail rigged through the blocks. The stern maintenance hatch is made and glued in place. The coal crib and stoker are glued to the steel plate but the boiler is not yet glued to the plate as I have more work to do on it which is next on the list. Thank you for following along and being part of the journey. Keith
- 457 replies
- sternwheeler
- Hard Coal Navy
Eric, thank you for sharing your insights.
- 457 replies
- sternwheeler
- Hard Coal Navy
Ken, thank you for the input. While railcars are supported at the ends, water's support is greatest in the middle of a sternwheeler's hull allowing the ends to sag. It's physics my wee brain at times has a hard time comprehending. Nautical engineering be hard.
- 457 replies
- sternwheeler
- Hard Coal Navy
