Everything posted by KORTES
	Here are some more elements, before final fitting and assembling. Topmast cross-trees and hoop heads, material - black hornbeam.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	I finished the hatchway lids. As the size of the elements is small I had to make a pattern out of nail.
- 306 replies
- schooner
 - la jacinthe
	The ring has to be set tight on the toothpick, so it wouldnt turn around. In this case the tootpick plays a role of a "holder". In the end the thimble may be refined with a help of broaching file. The smallest elements were made out of a wire with the 0.7 diameter.
	Greetings dear Michael. Concerning the making of the thimbles. The method is not much technological, it requires a certain skill. Firstly I made rings from the wire of the required diameter. After that, i put a ring on the toothpick and using the PROXXON, with this cap, I took away the excess. All the manipulation were made using a toothpick and a ring.
	Test assembling. Macro-filming. As usually showed some defects, which will be eliminated before the final assembling.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	Regarding the snake, my friends pointed out several mismatches. "Brother, the eyes are in the front part of the head:) and the are on the sides. It cant look directly ahead. the face doesnt get thiner in the upper and lower part. In general its just a thick triangle triangle. But the mouth is till the neck :D" I had to remake.
- 306 replies
- schooner
 - la jacinthe
	Thank you, my dear colleagues, for the evaluating my work.
- 306 replies
- schooner
 - la jacinthe
	Aft end carving. It seems it looks ok in a life-size, but when substantially enlarged one can see faults that were made by the “carver”.
- 306 replies
- schooner
 - la jacinthe
	I hope the carving work is done, being a dilettant - it was hard for me to carve at such a scale. Now I´ll have to oil-coat it, afterwards, probably cover it with bituminous varnish and install in place when the hull will have dried out.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	I decided to begin with what I considered the easiest element - the snake . I couldn’t find boxwood. I didn’t use lime tree due to its softness. So I have opted for a peartree, at least I’ll get some practice.I studied this part of work on the forum, of all my colleagues, found lots of useful information, for what I’m very grateful.
- 306 replies
- schooner
 - la jacinthe
	While the hull is drying out, I got around to the carving. For quite some time, I have had a feeling I would have troubles in this field. Scale… I started by making the instrument, using broach files, drills, jigsaw saw and big needles.
- 306 replies
- schooner
 - la jacinthe
