I have secured my ratlines to the shrouds with this technique for years and an extremely sharp surgical knife cuts off the ends nice and clean. A dab of flat black on the ends finishes off the job. Working on the same side of the vessel, with pre cut lengths of ratline you can rig these quite quickly actually. Good job. Rob
Fantastic progress Nils....... Rob
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
I agree with some posts here. The shrouds are in of themselves(along with the backstays) a modeling project all by themselves. You can approach their installation in the same manner as you did with painting the fine scroll work or cannon work on your vessel. It's simply lacing lines to form semi-rigged structures. Work the lowers first or one mast at a time....what ever you do, establish a *Method* that works for you. Personally I rig the shrouds for a single mast first...then the next mast and so on. Then I tackle the ratlines...one mast at a time...in short..I compartmentalize my efforts..so the entirety of the shroud install process doesn't become to overwhelming. Good luck in the next faze of your build. Rob
Thanks Dave...Capturing the *Mood* of the water in all its intricacies...with foam and sleets and to capture depth is a real trick. I started with a clean white pallet of dental plaster and created the deep blue/green troughs first then added lighter green to the caps....it took a while, I then added gloss white for the white caps and trickled some foaming details and there you go. Thanks for the fine comments. Rob
Great job Ed. I made a steam cabinet to bend all my timbers. Kinda like a double boiler..with the timbers laying on a rack. 15 minutes and you could nearly tie them in a knot. Good luck
- 3,618 replies
- young america
- clipper
Thanks for all the likes everyone and thanks Frank for the fine comments. Sometimes I'm questioned as to those techniques..since they deviate from typical scratch building. Some suppose that that means from all wood construction. I prefer to save time by re-engineering what others have toiled over..to gain my desired effect. In the ultimate end..it is the builder who is to be rewarded..and since a true scaled model is never truly accurate(Meaning: we don't actually build with oak, or use tree architecture for fashioning knees, or cast real iron for all the structural particulars, I don't know anyone who has access to muntz metal either...) I guess I'm lazy...just wanting an end result...for me. Again..thanks Rob
fine work Ed. Very Fine. Being in the dental Field..the lost wax cast method of reproducing quantity is a great direction if you have the oven and the casting machine. Many Dental supply houses have older/used equipment that can be had relatively inexpensively. But like you said...it's kinda tough asking folk to do that. I usually make/fashion a master and then duplicate it in silicone and then pour/cast plastic/acrylic replicates myself. I gave up on fashioning metal parts for my vessels a while ago(Unless it's a special part)......High impact acrylic is easier to work and finish and once painted is just as convincing. IMV I applaud your skill and application of it. Rob
- 3,618 replies
- young america
- clipper
- 31 replies
- ferreira
- cutty sark
I'd be interested in your log and your approach. The Ferreira has a very rough life under the Portuguese..and her story is hardly known. To try to tell CS's story and to exclude the Ferreira saga would be to deny CS's history. Rob
- 31 replies
- ferreira
- cutty sark
Clippers are the majestic *Bells* of the nautical world. Ed's contribution here, reinforces my own 45 year love affair with American clippers as well as inviting to those new to their elegant attractive lines. Their brief colorful history plays strongly into their overwhelming attraction. Personally..I love em to death. Rob
- 3,618 replies
- young america
- clipper
Michael.......I had to lay-up the McKay in dry dock...while I pay a bit more attention to several other vessels whose keels had been laid prior to hers. I hope to soon return to her...because her theme as a diorama needs completion. Plus I found some deck damage that occurred after a move...so that needs to be repaired as well. Thanks for looking in I appreciate that. Rob
Hi Marcus...the stove came from images I have gathered through time of shipboard life and working on such vessels. I think the top of the stove chimney can be seen in one of the B/W images I posted. I also relied upon much artistic license...since the replication of the scene is not the real aim as much as is the fact the scene was true. Small omissions are acceptable so as long as the truthful presentation of an actual event is replicated. Like my Cutty Sark on the ways getting her jury rigged rudder repaired. Factual even wish artistic license to entice emotion. Thanks for your kind remarks. The model is near completion, however, I am working currently on 4 models at this time and I juggle between them. Rob
- 31 replies
- ferreira
- cutty sark
Thanks Patrick....I want my builds to tell a story of not just the model, but what the actual ship was involved in. It lures in the viewer and if at all possible captures their attention to the beautiful sailing ship. Thanks again.....for following. Tob
- 31 replies
- ferreira
- cutty sark
Big question....does it actually work? Is the slip ratchet mechanism really workable? Rob
- 3,618 replies
- young america
- clipper
Excellent machining Ed....and at this scale. Rob
- 3,618 replies
- young america
- clipper
Cutty Sark by NenadM
rwiederrich replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Good job Nenad. I see you've decided to build her after the Portuguese modified her. Coming along nicely Rob- 4,152 replies
- cutty sark
- tehnodidakta
Ed, do you have a mass production method created to produce your deck planking, or is it one at a time on the tablesaw? Rob
- 191 replies
- young america
- clipper
