rwiederrich
  1. Yes he did..and it sold at auction recently........ Thanks for posting and the comment... Rob
  2. I have secured my ratlines to the shrouds with this technique for years and an extremely sharp surgical knife cuts off the ends nice and clean. A dab of flat black on the ends finishes off the job. Working on the same side of the vessel, with pre cut lengths of ratline you can rig these quite quickly actually. Good job. Rob
  3. I agree with some posts here. The shrouds are in of themselves(along with the backstays) a modeling project all by themselves. You can approach their installation in the same manner as you did with painting the fine scroll work or cannon work on your vessel. It's simply lacing lines to form semi-rigged structures. Work the lowers first or one mast at a time....what ever you do, establish a *Method* that works for you. Personally I rig the shrouds for a single mast first...then the next mast and so on. Then I tackle the ratlines...one mast at a time...in short..I compartmentalize my efforts..so the entirety of the shroud install process doesn't become to overwhelming. Good luck in the next faze of your build. Rob
  4. Thanks Dave...Capturing the *Mood* of the water in all its intricacies...with foam and sleets and to capture depth is a real trick. I started with a clean white pallet of dental plaster and created the deep blue/green troughs first then added lighter green to the caps....it took a while, I then added gloss white for the white caps and trickled some foaming details and there you go. Thanks for the fine comments. Rob
  5. Great job Ed. I made a steam cabinet to bend all my timbers. Kinda like a double boiler..with the timbers laying on a rack. 15 minutes and you could nearly tie them in a knot. Good luck
  6. This is why Elton John hired 50 proof readers for the *Yellow Brick Road* album....and they still left errors. It's tough keeping all the details in order..with such a complex system. Still it is a great book..... Rob
  7. Thanks for all the likes everyone and thanks Frank for the fine comments. Sometimes I'm questioned as to those techniques..since they deviate from typical scratch building. Some suppose that that means from all wood construction. I prefer to save time by re-engineering what others have toiled over..to gain my desired effect. In the ultimate end..it is the builder who is to be rewarded..and since a true scaled model is never truly accurate(Meaning: we don't actually build with oak, or use tree architecture for fashioning knees, or cast real iron for all the structural particulars, I don't know anyone who has access to muntz metal either...) I guess I'm lazy...just wanting an end result...for me. Again..thanks Rob
  8. Thanks Doug..after becoming a grandpa, again...I had taken a break on the Glory...but I hope to return to her to finish up her ratlines and begin the tedious work of rigging her yards and ironworks for them. Rob
  9. fine work Ed. Very Fine. Being in the dental Field..the lost wax cast method of reproducing quantity is a great direction if you have the oven and the casting machine. Many Dental supply houses have older/used equipment that can be had relatively inexpensively. But like you said...it's kinda tough asking folk to do that. I usually make/fashion a master and then duplicate it in silicone and then pour/cast plastic/acrylic replicates myself. I gave up on fashioning metal parts for my vessels a while ago(Unless it's a special part)......High impact acrylic is easier to work and finish and once painted is just as convincing. IMV I applaud your skill and application of it. Rob
  10. I'd be interested in your log and your approach. The Ferreira has a very rough life under the Portuguese..and her story is hardly known. To try to tell CS's story and to exclude the Ferreira saga would be to deny CS's history. Rob
  11. Clippers are the majestic *Bells* of the nautical world. Ed's contribution here, reinforces my own 45 year love affair with American clippers as well as inviting to those new to their elegant attractive lines. Their brief colorful history plays strongly into their overwhelming attraction. Personally..I love em to death. Rob
  12. Michael.......I had to lay-up the McKay in dry dock...while I pay a bit more attention to several other vessels whose keels had been laid prior to hers. I hope to soon return to her...because her theme as a diorama needs completion. Plus I found some deck damage that occurred after a move...so that needs to be repaired as well. Thanks for looking in I appreciate that. Rob
  13. No..this painting is not representative of what happened to the Ferreira aka Cutty Sark. As the Ferreira she was hit by a rogue wave, however her cargo was so poorly stowed that it shifted and it was this mishap that nearly capsized her. Causing her to lose her main and mizzen masts. Rob
  14. Hi Marcus...the stove came from images I have gathered through time of shipboard life and working on such vessels. I think the top of the stove chimney can be seen in one of the B/W images I posted. I also relied upon much artistic license...since the replication of the scene is not the real aim as much as is the fact the scene was true. Small omissions are acceptable so as long as the truthful presentation of an actual event is replicated. Like my Cutty Sark on the ways getting her jury rigged rudder repaired. Factual even wish artistic license to entice emotion. Thanks for your kind remarks. The model is near completion, however, I am working currently on 4 models at this time and I juggle between them. Rob
  15. Thanks Patrick....I want my builds to tell a story of not just the model, but what the actual ship was involved in. It lures in the viewer and if at all possible captures their attention to the beautiful sailing ship. Thanks again.....for following. Tob
  16. Thanks Marcus......I agree fully..what an adventure sailing around the horn in a Clipper...fast and furious..bitter cold and danger around every corner. Rob
  17. Big question....does it actually work? Is the slip ratchet mechanism really workable? Rob
  18. Excellent machining Ed....and at this scale. Rob
  19. Good job Nenad. I see you've decided to build her after the Portuguese modified her. Coming along nicely Rob
  20. Ed, do you have a mass production method created to produce your deck planking, or is it one at a time on the tablesaw? Rob
  21. Thanks David. The rigging is slow going. Unlike most scratch builds.. (Made entirely of wood), mine is of a composite nature. I use all medium to complete my ships. Rob
  22. Sometimes archived images are in private hands and are hard to gain access to. These last photographs are revealing.
