jfhealey
Everything posted by jfhealey
  1. Perhaps a 1/48 HMS Victory or something equally daft. The deadeyes are brilliant. Speedwell is a triumph. You know all of this Chuck. But get well first.
  2. Remember, Chuck, what happened to Admiral Byng when he failed to follow orders to press home an attack on Minorca with all possible vigour. Orders form those in command are meant to be obeyed to the letter. Dose yourself up with something really powerful probably topped off with a scotch or two and let your creative thoughts run riot. Something very good will come of it.
  3. Reilly - I'm sorry I overloooked your question. I have no idea what the answer is I'm afraid! Fred
  4. I am very nearly done! Here are some pictures of the present state of play. Pretty much all I have left is to make rope coils and hanks so its a Tom Lauria video for me and then give it a go. So, by the end of the week, I might be done. And then I'm going to have to think seriously about Old Winnie an what to do given that I feel a more confident and able modeller (with a better tool kit too) than when I started her 3 or 4 years ago. Thank you for looking in. Fred
  5. I'm looking hard to find some fault here Glenn with a view to offering some restrained and constructive criticism but you've got me beat this time. Still there is always your next post. I'm watching. Fred
  6. Wow! I think between all of us following your extraordinary log we have exhausted all the superatives available - so just a simple "wow". Fred
  7. Thank you Tony. That is very useful to know. I had thought the part was only available in Oz. I shall see if I can get hold of it. Coupled with your steady it would I think transform the usefulness of the DB250. Fred
  8. Thank you Tony. That is an interesting addition to a Proxxon DB250. I have one. The principal limitation, from my perspective, is the length of the bed. The hole through the motor section allows for turning longer sections than the bed length but the limitation there is the relatively small diameter of the hole - 11mm or so. I could not, for example, turn the main mast for my Cheerful on the DB250. I ended up sticking it in the chuck of a power drill but precision goes to a degree by the wayside. Have you thought, I wonder, about extending your device so as to extend the bed length? I know that some Australian users of the DB250 can purchase an extra aluminium extrusion (Proxxon?) that presumably bolts on to the Proxxon bed (not authorised by Proxxon!) but the part does not appear to be available in the UK. In the meantime I may have a go at your version of Johann's rest which as you say does not require Johann's ability to machine metal - something way beyond my skill level. All the best Fred
  9. You are doing a wonderful job JJ. I should think you must be very proud of what you have achieved. A fantastic representation of the Winnie. All the best Fred
  10. CaptnBirdseye - I shall follow your build log with interest. By the way - if you have not ordered wood from Vahur (Hobbymill EU) before then you have a treat in store. Its beautiful stuff. Good luck Fred
  11. Thank you gentlemen for your very kind thoughts which I greatly appreciate. Glenn - I have not heard of liquitex until your post above. I see it is available in the UK (unlike wipe on poly which I seems to be the go-to finish on your side of the Atlantic) so I shall give it a try. Does it have adhesive qualities as well as providing a matt finish? At the moment I paint a little matt varnish on to the knots after CA-ing them but it does not completely rescue the mess CA can make.
  12. Thanks chaps for your kind remarks. Here is an update on my Cheerful build. The end is in sight for a much enjoyed project. I hoped the sheer pole would enable me to pull my wonky deadeyes into facing front. Here are the outer two: And here all four. I'm pleased with the outcome. The sheer pole looks a bit curved in the picture but it is straight enough on the model. Looking at the picture I shouls perhaps have worked a little harder on the Syren deadeyes with fine paper. And here the lanyards tied off. A bit scruffy but the best I could do. Starting work on the ratlines. Chuch's instructions say use .12 rope. I tried it and thought .18 looked better. Big mistake and one I cannot undoe without destroying all the rigging done to date and that is a bridge too far for me. Not only do the lines look too thick but the wider diameter rope significantly increases the size of the knots. Irritating - but, oh well, live and learn! I also dragged in one of the outside shrouds (aft starboard - see below). Not quite kiss of death territory but practice required. Starting on the backstays I struggle a bit with seizing lines together/to blocks. Cotton thread seems sometimes to take on a determination to go its own way rather than where its wanted. That or just getting too much CA so the knot is a little disfigured. Again more practice required. Here using the cathead for temporary tightening a line. A lot of this section of rigging requires careful tensioning in particular to keep the yard arm where it shoud be. Thats all for now. Not much to do and I shall be done. I heartily recommend Cheerful to anyone contemplating a semi scratch build. All the best Fred
  13. Cheerful is a great choice. Good luck Rick. I will follow with interest. Fred
  14. I'll second "take lots (and lots) of pics". That way folks like me will indeed see how its made. I don't aspire to build at anything like your level, Mike, but I'd love to see how you make things.
  15. Thank you both. All advice very graefully received! I shall follow this build with great interest, Mike. Please post as many photos of making parts as you feel able to share. Fred
  16. By way of example of the above: Mike wrote "I added the gammoning knee". How on earth did you make it? Sorry to be a pain. Fred
  17. Greg - you are a case in point. Another master craftsman with so much knowledge to impart. I have your book "Building the Swan Class Sloop Pegasus" (I didn't realise who DVM 27 was for a long time) and I have read it from cover to cover but there are limitations to the printed page - not least that you can't ask. What I'd love to see is someone walk a beginner like me through each stage of making a part - for example Mike's stem above - with lots of photos. I may never be that good but I'd like to have a go! Best wishes Fred
  18. Hi Mike. I'm certain this will be a wonderful and fascinating build. Are you, I wonder, prepared to share lots of pictures of your construction work? I'm not asking about the finished product - for example the stem pictured above - but rather how you made it. That's what I'd love to see. I can see photos of a scroll saw and a milling machine (in action - which is great) but I still cannot see how you achieved such an outcome. I get that you paste bits of paper onto wood and cut them out - but, self evidently there is a heck of a lot more to it than that. How , for example, did you achieve such close joints on the curved sections - an oscillating sander perhaps? I appreciate there is a lot of skill involved but there is a lot of learning in there too. Will you share it? I'd love to follow if you will. Best wishes Fred Healey
  19. Here is a short update on my Cheerful as a very enjoyable build comes towards its conclusion. I have some touching up and tidying up to do and the boom crutches. Otherwise its just the rigging which is well underway. These pictures were taken a couple of weeks ago. These are where I am now. No matter what I do I canot persuade the deadeyes to face front. I'm hoping I can force them to shape up with the sheer pole. In the picture below you can see there is a mistake. The bottom ring on the mast to which the block for the throat halyard is attached should not be attachedflush to the mast as the four above it are. It should stick out a bit to clear the trees and ropework. Its shown on the plans. I either missed it or did not appreciate the significance. But I can live with it. The real difficulty I have found with the rigging is in seizing blocks when I can't hold the block in a third hands device eg when the block has to be seized to the mast or a line. I guess its a matter of practice and experience but I need to work on it. Ratlines today. Otherwise all is well. Fred
  20. I'm looking out of the window here on a bitterly cold late winter morning with the ground white with frost and then looking at the backdrop to your pictures above. Is that for real!!! Oh, and by the way, the boat in the foreground looks pretty good too. Best wishes Fred
  21. Yout hard work was certainly worth it Jean-Paul. The deck is looking lovely. All the best Fred
