jose_b
  • Gender
  • Location
    Jerez, Spain
1,634 profile views
  1. Your work from the beginning to now is truly a masterpiece. In view of the accuracy and neatness of your work, I'm starting to believe that perfection exists.
  2. I agree with Giampiero, this rigging work is the best, considering the time you're dedicating to this section and the level of detail. You are a true reference in this field.
  3. Splendid work as usual. What rope-making machine do you use? Could you put any photos of the process of making ropes? Thanks in advance. Splendido lavoro come al solito. Che macchina per la produzione di corde usi? Potresti mettere qualche foto del processo di creazione delle corde? Grazie in anticipo. (Google translator)
  4. The sheep pen ("Redil" in Spanish; "pare à moutons" in French) is just put in place, not glued.
  5. Another little update: Bitts ("Guindaste de gavia" in Spanish; "Grand sep d'écouter in French):
  6. After a long period of inactivity due to job matters, here you are a small update including the main capstan.
  7. That's right, it's a wood filler. In Spanish is called "tapaporos" (a compound word formed by the verb cover -tapar- and the noun pores -poros-).
  8. Precious and neat work as usual. It's a pleasure to watch your progress.
  9. Amalio, if you have the opportunity, it would be a great idea to show us the making process of those clamps. Thanks in advance.
  10. A repetitive and accurate work! It's fantastic!
  11. I've used knives, mainly one (with which I felt more confident), and a rotary tool for "wider" areas. Thanks.
  12. I appreciate all the suggestions. I'll try to fix some irregularities on the third wale. Hubac, Druxey, thank you very much for your help.
  13. After a long time, some updates: I've installed the upper wales and then I've cut all upper parts of frames. I've also finished the upper part of the stern.
