Posts posted by Derek C
- scasey88, Tigersteve, mtaylor and 1 other
- 4
Great job B.E.
You built a beautiful boat !
- Blue Ensign and Martin W
- 2
I got the planking done . And with the huge hurricane only days away I thinking I should have built a bigger boat 😳 . So I figured I'd sit outside and sand the hull down and start cleaning up the inside of the hull and the inside is going to take some work so I will sit out here and do it and enjoy the weather while I can lol here's a few pics of the inside (I haven't started on yet ) and the outside that I have started sanding on
18th century longboat by Derek C - FINISHED - from Model Shipways plans
I got the windlass done ,I started with a piece of 1"x5/8" teak I cut out a 1/2" x1/2 " x 2" piece then cut that in half and then cut those in half to give me 4 -1/4"x1/4 x2" pieces I then sanded and file one of those pieces to form the windlass . I then used a1/32 drill bit to drill through the square parts near the ends for the handles.to square up the holes I used the end of my tweezers that I modified a bit . For the handles I split another 1/4 " piece again down both sides to give me 1/8" pieces to play with with a bit of sanding and filing I got a decent shape . I used a couple pieces of 22 gauge wire inserted in wholes drilled into the end of the windlass to hold the unit to the boat . The wire slides into. Corresponding wholes that I drilled into the risers.
