Posts posted by Derek C
You can always go back and use a 11 blade to cut deep grooves in your planks and then use a wood burning pen to define the cuts if the full planking bothers you
Derek
Insert the nail into your dremel and use a good file and you can resize those nail heads with ease
Yup looking good , much better this time round .Slow and steady bud
- alde and Tigersteve
- 2
What a type of wood is it Ed?
I just finished a boat made out of teakwood and Had a heck of a time bending planks I found if I boiled them for 20-30 minutes and then let them sit in the water as it cools a bit the wood started to relax . The window of time was very limited once I pulled the wood from the water to get my bends . Not sure what wood your using but maybe this method will work for you
Derek
Sweet ,can’t wait to see the progress
Hi SaSi
i am new to this hobby, and planking can be a difficult task but there are plenty of tricks out there to help with the task I learned a bunch from the link below
check it out , and be patient, follow the plans and most importantly have fun
Derek
Hello
i will pull up a chair and follow along
Derek
Only a few more days until my wood order arrives and I can start building frames, but for now I started making the second cannon carriage today using the same technique except I printed a copy of the plan to cut out and use as a template this time .
Clamping the two pieces together to ensure the pieces wouldl be identical as I filed and sanded to match the template.
I also added wheels to the first cannon they are not complete yet but just trying to decide on the overall look .
guess it looks ok what do the masses think 🤔
Derek
Looks like your on a good track now
Brilliant !!!! I will be making one of those. Thanks for the Tip
- Canute, thibaultron and mtaylor
- 3
HMS Triton Cross Section by Derek C - FINISHED
in Cross Section Build Logs for HMS TRITON
When I got home from work today I was excited to see my wood had arrived I unpacked it and got It sorted .
tomorrow when I get home I will start gluing down the templates for the frames and start on my keel, keelson and false keel.
I found UWEKs log , and I found some great info .thanks again for the tip .
Derek
