Matt H
About Matt H
  • Birthday 04/10/1981
  • Gender
  • Location
    Seward, AK
  1. Thank you this worked, I'll remember this resource is here from now on!
  2. Thanks, but that doesn't work either, I get an XML error and it says access denied.
  3. Hello, and you're off to a good start, I look forward to seeing more. I too have a problem remembering to take photos along the way. I really like the idea of keeping a build log, but I almost never remember to get photos during a work session only once I'm done for the session. I haven't built much since my last one in my signature, planking is where I always got stuck. However, I'm giving it a go and despite having a collection of unbuilt kits I grabbed a couple of Vanguard kits recently and am waiting on the Sherbourne to arrive in a week or so. I'm looking forward to working on a kit like this with a great design and instructions I think I can really learn a lot from this kit.
  4. Good luck to you. It looks like it would be a great build. My son is into history and WW2, he'd enjoy seeing this when it's completed. I don't have the funds for it myself, but I hope you find a buyer soon, good luck.
  5. Thank you, it's on a shelf in my living room. I would like to move it into my classroom, I just haven't gotten around to transporting it. I also share the room, I teach from two different classrooms, hoping to stop teaching in one of them and move into my computer lab full time next year, if that happens I'll definitely move it into my room.
  6. Thanks Ric, it was a great kit and I too watched and just finished the Vikings series! Someone else had that question and I was tagged in their build log. Here is the link to my first response and a couple of posts down I provided a clearer image and an image of that part of the instruction book. I did NOT use the water/glue mixture before placing the planks, I just did a small bit of regular yellow wood glue on the part of the plank that overlapped. You can actually see a bit of glue that didn't get sanded before I applied the stain in the image in this link. If you have any more questions let me know.
  7. At the top of the forum is a navigation bar and a tab/button/link for Articles Database. In that Articles Database is sub categories, one of which is for framing and planking. In that framing and planking is the following article written by Chuck and it is a pdf which includes a fan. Hope that helps. This was my first kit I assembled, I enjoyed the challenge of the small size and the well written instructions. https://thenrg.org/resources/Documents/articles/LiningOffYourHullPlankingTutorialAndFan.pdf
  8. Are these the same plans that were printed when they were printing them? I purchased the full set of books and plans not too long ago.
  9. You're right the photos weren't very good so I snapped this one and the instructions. Here the number 1 is pointing to the seam where I cut partway through the plank so it could be folded along the cut. The number 2 indicates where the bottom edge of the plank is. Hope these help, the pictures portion of the instructions are in Italian, and a separate instruction sheet is printed in English. **Edit - Nope, no relation to James J as far as I am aware!
  10. Thanks Louie! If I recall, I did have that problem, but I believe the instructions said that as you got higher in the planking, you should cut partway through the plank horizontally along the length of the plank. Not along the entire plank but rather the middle section up to about 3 bulkheads from the bow and stern. Cutting partway through from the outside of the plank allows the plank to fold and the bottom half lies on the plank below it, and the top half is able to be folded up against the bulkhead. I just checked the instructions and this is demonstrated in figure 12 on page 3. If you look closely you may see that slice and fold/bend in my photos.
  11. Thank you very much, yes I did complete it in the time presented here in the build. Probably a bit shorter because it took a couple 2 or 3 weeks to get the final post and images uploaded. I am a teacher and so I had a lot of time at home after we closed down in March for Covid-19. In normal circumstances I would not have been able to get as much done so quickly. The Amati instructions are for what you see in my image in post #6 using the rope. The only modification I made was on the top of the rudder where the rope is wrapped around the rudder. The instructions were not clear on how to attach the rope on the top of that wrapping. So I drilled a hole through the rudder twice, once below the wrap where you can see the rope wrap go through the rudder and through the ship plank and another at the top of the wrap where it is just knotted behind the rudder where you can't see it. So I started the rope wrap at the top, knotted one end to keep it from going through with the knot positioned in the back of the rudder towards the plank where it is not visible. Then I wrapped it around and ran it through the bottom hole drilled through the rudder and through the plank and knotted on the back side of the plank. The lower attachment point is also rope that is knotted through the rudder where the blade is attached to the rudder in the front side where it is visible and it goes through that small button cap looking piece and through the plank and into the ship. It is under the deck planking and I did not think of it before I finished the deck so I attached a small wire shaped into an inverted V that when pressed through the hole would open up and prevent the rope from being pulled out since I could not knot it behind the plank due to the decking. The final small rope I believe is more for positioning and keeping the rudder in line with the ship and not drifting outwards to the waterway or inwards up against the ship. It too is just rope with knots on both ends. Hopefully that helps clear things up. I did not do any research into Viking ships, I relied on the Amati instructions. I did a bit of research into the paint colors of the shields and ultimately decided to go with colors I liked rather than the typical red, yellow, or black. I did try to keep the colors more natural looking as if they were able to make/find pigments in similar colors. I also did have to use a website to translate Italian to English because the prints were only in Italian for Amati. I also had a picture encyclopedia book for ships and used that to reference parts of the viking ship I was not familiar with. Otherwise all my info came from the provided instructions.
  12. Thank you very much. I am quite proud of her and I think she was an excellent 2nd model and I think I'm finally ready to move on to something bigger and with more masts and rigging. My next one is already on the table, plans hung up, and ready to go. HM Bomb Vessel Granado is in the shipyard.
