Everything posted by twintrow
I never understood why countries impose import taxes on products and/or services that are NOT AVAILABLE in that country. Obviously it is to make money for the government to waste, and to encourage buying in country made products when available, but seems unfair to the people of the country. Then to add insult to injury, not charging folks in other countries the VAT, such as Great Britain not charging VAT when Americans buy from companies in England. Not intended to cause any political arguments, just an observation.
Could be just an illusion, but she seems to be riding awfully low in the water (as in too low). Must have taken on enough stores for a long West Indies tour!!! But absolutely beautiful none the less.....and a great job of rendering. Tom
I don't mind drilling. I'd like a hundred to put in my supply bin. The when you get underway, get more. Come to think of it, that may not be a bad marketing method, few bucks less to drill your own?? And like ME sell in bulk as well. It seems there are never enough blocks when I need them. Tom
I'm ready to order Chuck as soon as you are ready to ship!! Tom
I've seen that description made before and instinctively feel it is misleading. The hole nearest the top would be used if the rope was come from below the block and returning downward from the block (as in 21 in the photo). Conversely, when the rope was coming from above and returning above the block the hole would be nearest the bottom of the block (as in 24 in the photo). Makes sense to me anyway. Tom
Here is a pic of the preventer stay, it represents how each of the stays would be served. Yes, the eye is also served. Sorry I missed that to begin with. Click on the pic to enlarge. You can se the eye, the mouse clearly, and the eye served. good luck Tom
Served. With a mouse stopper. PS A main point in serving a line, is to reduce the effects of abrasion against any nearby surface. So since the stays are looped over the masts they would be served all along the loop as well.
I never use the polishing grit meant for rocks and stones in the tumbler, just the sandpaper. I use the method for making the block blanks shown on Jerzy Bin's site (http://www.jbmodel.eu/). Then throw them in the tumbler. I also use the ones supplied with the kits sometimes, but they are so unrealistic sometimes that it is easier to make new blanks than spend the time cleaning up the kit ones. The kit ones usually are drilled off center as well, that can't be fixed unless you fill the holes with wood putty and redrill. I experimented with 80, 100 and 120 grit papers in the tumbler and the 100 seemed to do the best job in the shortest time. The 80 was too aggressive and the results were uneven (different densities in the wood I guess). Eric O., I've not used that kind of tumbler. It is true that when you run a batch of 2 or 3mm blocks, many of them can get under the sandpaper so it must be sealed tight against the tumbler walls. Tom
Overdale I use a rock tumbler from Harbor Freight $29, sometimes less on sale. I lined the barrel walls,and the top and bottoms with 100 grit, I let it run 24 to 48 hrs, while checking every few hours. Seems to do a good job for a large number at a time. I then usually end up finishing about 50% of them off by hand. Tom
When my wife suggested new draperies for the family room she wanted to throw away the old vertical blinds. Naturally I said no, there must be a use for that big aluminum bracket!! So after it laid around a few weeks (as new ideas often do), I decide to try and make it my "track" for the MS rope walk. I stripped off the mounting brackets but kept the plastic center mounting brackets. I drilled couple holes in them and mounted each end to the two brackets. I kept these because they slide freely in the aluminum angle. Th overall bracket is 10" long so I set each of the two MS rope walk parts a foot in at each end. Strung some crochet and made the first attempt. While counter winding (the first step in the MS instructions) the winding handle sliped and would no onger turn the eyes, So I went to the left side and counterclockwise rotated until the rope threds looked like rope ;o) I didn't wax the thread first which I think I should have done. And as you can see in the photo the rope is not evenly wrapped end to end, near the right hand side it was closer or tighter wrapped. I cut it off the device and tied the ends. It only unwrapped slightly. Any further suggestions on technique are welcome and solicited. My overall opinion is that it will work well and create 9' lengths of rope very nicely when mentioned bugs are fixed. I was disappointed that the MS crank did not perform as advertised, way too flimsy. Tom
Rich look at Hubert's site "Shipbuilding for Dummies" cost is $40 for life, worth every dime!! Here is link to "Zip Seizing" his technique. http://www.shipmodeling.ca/subs/aa123.html#1 Look for #9 tip. Any problems with viewing let me know. Hubert is very helpful and occasionally posts a video tip here on MSW for non members as well. Tom
Presenting Ropes on your Scale Model
twintrow replied to BANYAN's topic in Masting, rigging and sails
I was thinking the same thing John, thanks I'll try it out. Tom -
Excellent info Banyan, very helpful. One issue I have when coiling rope (lines) to attach to belaying pins, is that the coil tends to stick straight out, not hang loosely as in the photos of "real" lines. I've tried running the thread through a 50/50 dilution of white glue, getting it wet. Sometimes it forms a little better. Is it the type of thread being used that causes it to not lay realistically, or the technique?? Also, and maybe obviously, the larger the scale, the better the rope looks. thanks Tom -
Lanterns
twintrow replied to figuerres's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
figuerres Check out Cornwall Model Boats, the link below will take you to Amati accessories, they have lanterns. There are other mfg listed with accessories as well. http://www.cornwallmodelboats.co.uk/acatalog/amati_lanterns.html good luck Tom -
I really like the looks of a wood all over ship. At the same time I am trying to be as authentic as possible while building and to accomplish that some hulls have to be coppered to reflect the real ship. So I guess the way to solve the dilemma is if you want a completely wooden ship, and be authentic too, build one from that era. Having said that, there is (was) a model shown here before of the Constitution not coppered, an it was beautiful ;o) As has been said many times here, "it's your ship, build it the way yo want to". Tom
