Posts posted by DenPink
Hi Mark
Nice planking well done.
Denis.
- edmay and marktiedens
2
Nice work Jesse well done.
Denis
- CaptainSteve, mtaylor, GLakie and 4 others
7
I remarked in a parallel thread on these gratings that heynare the wrong side up: the flat side is the inderside, the upper side is not flat.
If I remember correctly, Chris used these gratings as he was trying to get something in scale thickness. The lower decks are completely fitted out, and the deckopenings are the only real see- through option. Therefore in his own pics, the gratings are next to the openings. However, scale thickness required something slightly under a milimeter. Too thin to have them in wood. (Atleast, mass produced in a kit)
Jan
Hi Jan
The thickness of the photo etched ones are 1mm.
The wooden ones are just over 3mm.
If I sand down a bit on each side to get them down to just over 2mm I will be happy.
I can always make the frames a bit higher, I don't think any one will notice ( well they will now ha-ha ).
Denis.
- mtaylor, Canute and CaptainSteve
3
Brian good things are worth waiting for ha-ha.
Denis.
I am pretty sure that how well you paint them,, the metal gratings would not look as nice as the wooden ones. Where did you buy these? Caldercraft? How does their scale compare with the etched ones? The wooden gratings that you bought look much better than the majority of similar items found in kits, where the wooden strips are much too narrow compared with the space between them (example: the Artesania and Mamoli gratings). It would be fine, as a comparison, to see the etched gratings next to the wooden items on a picture.
Happy modelling.
Hi Jean-Pierre.
I agree with you no matter how you paint them they will not look that good.
The size are Ok, holes are 1mm sq in both the metal and the wooden ones, I will have to cut the wooden ones back a bit to make them fit, as they did not sell them in the same size as the metal ones.
I got them from Modeller Shipyard in Australia cost about $5.95au each.
I will take a photo with the both side by side soon.
Denis.
Hi Brian
I don't know yet.
If I use the brass ones then it will not be possible to paint them to look like wood with a good result.
Or I could use brass blackening like you use for the cannons ?.
May be better to use the wooden ones.
Denis.
Hi Clare
Thank you for your info and so sorry I posted in the wrong topic
I don't post much on MSW so how was I suppose to know.
Denis
Hi All
I need some help with the gratings on my 1577 Revenge.
The kit has brass grating but I did not like them so got some wooden ones.
Can anyone advise me if the gratings on the Revenge was Iron or wood.
Denis.
The MDF from Victory worked fine for me with another kit - but did I understand that the base plinth was MDF too - thats just weird if so.
Lots of rigging line as usual but not really great quality - but a tip - label the lines spools now - why they dont label them I have no idea !
Brass gratings "what a lovely idea" I think as I fight the normal wooden combs.
But they would need to be painted - does the kit suggest what colour - because in my book if painted it saves so much work !
But cannot see a paint job looking like wood. I shall be follwing progress with interest !
Hi SpyGlass
Yes the base is MDF also, Brian had a good idea he said plank the base, and that is what I will do.
I have used other rigging lines before ( most fell apart ) and ended up going back to Amati ones, I always label the spools.
I agree with you, you would think the kit people would label them.
Re gratings I have not read all the book yet so I don't know if they say paint them or not, but if they are I would paint them black.
May be the gratings were cast iron I don't know, may be some one out there can help me on that one ??.
Denis.
Hi Mark
Wait till you do the second planking
Denis.
- marktiedens and mtaylor
2
Hi Frank
Wow that is some rigging well done , nice work love it.
Denis.
- Dimitris71, riverboat, mtaylor and 1 other
4
Hi Visi
You are more than welcome my friend.
But I hope you are drinking a good red wine.
Denis.
Alert by riverboat - FINISHED - Krick - 1/25th scale
Hi Frank
Happy Birthday my friend
:D
:D
Denis.
