Posts posted by DenPink
Hi Denis
Only one bulwark was cut off, that was remade and is under the forecastle deck.
You have to make another one to support the quarterdeck.
Denis.
Hi all
I have done one cannon to see how it looks.
Washed it in Hydrochloric Acid 50% water 50% acid, washed in water for half an hour.
I then dried it off.
Got a cotton bud and applied the Brass Black.
After 10 minute's I washed it in clean water.
Dried it off, then a second coat of brass black.
I am not that happy with what I have got,
I think I should have used fine wire wool before the first coat of brass black.
Will have to work on this one before I do more.
Denis.
- riverboat, Visi, Landlubber Mike and 8 others
- 11
Hi Cristi & Brian
Re cannon barrels.
Yes I am going to use Casey's Brass Black on them all.
I am now cutting out the main deck cannon ports.
Denis.
- popeye the sailor, Visi, kiwiron and 10 others
- 13
Hi Nenad
It is the same thing I was thinking of.
BTW I love your build very nice workmanship well done my friend.
Keep up the good work.
Denis.
- Piet, CaptainSteve, NenadM and 1 other
- 4
Hi Max
You are doing a fantastic build my friend.
Just very, very good workmanship at it's best well done.
You don't need me to build your stairs, going on what I have seen .
But most of all I am so pleased your dog is A-Ok that is more important , 14.50 years is a good age for a dog treasure the time you will have with him as I know you will.
Denis.
Hi Malcolm
Thank you for dropping in on the RW build you are more than welcome.
Sorry I don't keep my hours worked on the build.
And sorry again the SoS has no case well not yet (no time to make one).
Denis.
Hi Max
Thank you.
Just send me the airfare :D .
Denis
- janos, UpstateNY, CaptainSteve and 11 others
- 14
Hi Keith
Thank you for your kind words.
Denis.
Hi Brian
I tried a small window some months back and it is still on the back.
All I did was sand the back down to get rid of any surface film so it is nice and bright finish.
Sanding also puts scratch marks on the surface so the liquid glass has something to key to.
Denis.
Royal William by Denis R - Euromodel - Scale 1:72
Hi Timmo
Thank you for them words.
I was worried about the caulking lines but I think they are Ok.
Denis.
