Everything posted by CPDDET
All the frames have now been installed. I didn’t feel like sanding or shimming the stiffening spacers between the frames that came with the kit and decided it was easier to make my own. I first cut a strip of scrap wood the same thickness and height as the kit pieces. Using my caliper I measured the distance between the frames at their base and locked it in place. After raising the blade on my saw, I rested the caliper on the fence and adjusted the distance to the saw blade. Then lowered the blade and cut the strip to the proper width. This gave me very accurate pieces and assured that the distance between the base and top of the frames was equal. Before gluing in the furthest forward and aft frames I held them in position and marked them at the rabbet / bearding line. Then sanded them, test fitting as I did so. Then glued them in. Now Ill trim the top of the frames using my Dremel with a cut off disk and start the faring of the frames. I’m going to take my time with this and not screw it up like I did on my first attempt. I figure this might take several days.
- 47 replies
Welcome aboard, from a fellow sailor.
Welcome aboard!
https://www.menards.com/main/tools/hand-tools/clamps-vises/bessey-reg-2-needle-nose-spring-clamp/xcl2/p-177023398174645-c-9135.htm
Welcome aboard!
Welcome aboard. Looking forward to your progress.
Welcome. Seems your build is coming along nicely.
Welcome!
Welcome aboard!
As long as one reads well ahead to avoid issues down the road. I have found when working on any step, I have to keep in mind the several upcoming steps.
- 47 replies
Thank you for the comment. I meant no disrespect toward you as the author of the practicum. This being my second attempt at this model, I just found it easier to change things up a bit. As stated, I'm not suggesting anyone else follow my lead. If it's ones first attempt at this build its probably best to follow the practicum as written. And thank you for your dedication to this craft and helping us all become better at it.
- 47 replies
I'm sorry that I'm not being very helpful. I reviewed my post on this process and have been banging my 73 year old head against the wall trying to recall the process I used and exactly why I posted what I did back on 3/29/22. But that's almost 2 years ago and I just cant seem to come up with anything. I hope the process goes well for you and please know I'm always available for questions. Dave
- 389 replies
- bluenose
- model shipways
I did a few things in a different order than shown in the practicum. Now I’m not suggesting anyone else do this, I just found it easier for myself. The practicum calls for deepening the slots for the bulkheads, tapering the deadwood, cutting a notch in aft portion of the keel and trimming the stemson in order to fit bulkhead 5A. I found these easier to do these before gluing anything permanently to the build board. It took a lot dry fitting and temp gluing of the keel, keelson, stem and stemson. I found that Elmer’s Rubber Cement worked well for me when temp gluing pieces. The rubber cement takes longer to dry but it’s easy to pop off the pieces and the cement can be easily removed from the build board without damaging the build plan or wood pieces. One can rub it off with their finger or, on the wood, used a bit of rubbing alcohol on a paper towel if needed. Below is a pic of all the finished pieces. My only mistake was made when trimming the stemson for bulkhead 5A. The cut piece should look like a backwards “L” with the lower part of the “L” supporting the bulkhead. I misread the instructions and cut the stemson all the way down creating the following: Lucky this was easy to fix. I just cut a small piece of scrap wood, which was the same thickness, and glued it in place. After the final gluing of the stem, stemson, keel, keelson, deadwood and sternpost, I glued in bulkheads “E” thru “4”. I found by using the Titebond Quick & Thick glue, I could glue in a bulkhead about every 30 minutes. I’ll let this dry overnight and move on to the spacers that go between the bulkheads. Moving on…….
- 47 replies
Welcome aboard! Nice model you have there.
These are the tools I used to remove the parts from the billet (think billet is the correct word) and to remove the char. The razor saw has been my favorite for quite some time to cut the pieces out. Others are sanding sticks, various grits of sand paper and buffing pad. The dowel and can were used to sand curved areas. I included a sanding disk because it was recommended by Toni although I had finished the chore before I got her message. The small piece of wood at the top cut with 45 degree angles was used to make the rabbet. By wrapping a small piece of sandpaper around the angel and sliding it along the keel, keelson, stem and stemson it’s pretty easy to achieve the correct angle; just sand to the drawn pencil line. The wood piece is narrow enough to handle the curves as well. After dry fitting the keel, stem, stemson and keelson pieces and making adjustments, I tacked them down with white glue (later switched to rubber cement) and double checked the joint alignments. Then removed them from the plan and drew the lines for the rabbet. After marking the deadwood portion of the keel, I took a deep breath and sanded the edges using the angle cut wood block and 220 sand paper. The “step” on the upper part of the stem was cut using a #11 blade and small chisels. While the transition of the rabbet as it rises up the stem and stemson isn’t perfect, it’s much better than my first attempt and I’m happy with it. Moving on…….
- 47 replies
Welcome aboard! Nice looking model.
Welcome aboard!
And so we begin again. The build plan is mounted to the foam board using spray adhesive, as suggested in the practicum. I added the tape around the edges because I found the adhesive was letting loose just as I decided to start over. If one finished this build in a reasonable amount of time I doubt that would be a problem. I had taken far too long and that’s what probably caused the issue. Before cutting out the various parts I wanted to do a bit of research into finding an easier way to remove the char. On the previous model I had used a sanding drum (shown below) with a rotary tool. But unless you’re very skillful or very experienced with this method it can cause problems by removing too much wood along with the char and cause deformities in the piece. Looking back, this was one of the first problems I caused myself. So I picked up some abrasive buff wheels and a 120 grit flapper wheel. While they all easily removed the char I found the 120 grit flapper wheel and the 180 grit buff to be too aggressive. The 320 grit buff wasn’t aggressive enough but the 280 grit buff was just right. This weekend I will cut out all the pieces, remove the char and store them away in a safe place.
- 47 replies
Welcome aboard! You've picked the right port to dock in. Great people here and much experience.
