CPDDET
Everything posted by CPDDET
  1. Sherline recommends Super Lube for its lathe and mill.
  2. Things shouldn't be this difficult. Might take some trial and error. Keep us posted.
  3. I have a Sherline chuck and Sherline does have instructions on tear down, cleaning and maintenance of it. This may be of assistance to you. Simply Google "Sherline 3 jaw chuck maintenance" and you will find a youtube video on the process.
  4. Welcome! You might consider the beginner series from Model Shipways.
  5. Perhaps not the best but a small investment to see if using planes is your thing. https://www.harborfreight.com/hand-tools/planes-sanders-files/planes/mini.html
  6. I know he was famous for building clipper ships, the most famous being the Flying Cloud. But these types of models are far beyond the skills of a beginner, in my opinion. Still, I did start my ship building with the schooner Bluenose and managed a decent model. I would think he must have started designing small craft and worked his way up to the big clippers so a deep dive into his life will probably be necessary. Good luck in your research.
  7. Welcome aboard! Keep us posted on your progress with a build log.
  8. Welcome aboard! While I can't answer your question, I'm sure someone here can.
  9. I would also think that branding on the side would "dedicate" that barrel for certain uses. Whereas the top of a branded barrel could be easily changed so the barrel could be reused for different items.
  10. A touch of CA would cure that.
  11. You could also check braided fishing line like FireWire by Berkley.
  12. Great job!
  13. I believe Vanda-Lay makes a better version.
  14. You might want to think about a mount for your dremel to convert it into a drill press.
  15. Welcome aboard! All the help you need can be found here.
  16. Welcome aboard!
  17. I've had good success with Delta Ceramcoat All Purpose Sealer. Any art and craft store should carry it. I get mine at Hobby Lobby.
  18. Can't help you but that's an interesting piece.
  19. Welcome aboard! I'm sure you will find the help you need here.
  20. Welcome back! You're not the first to "leave things for awhile" and surely not the last. Mistakes are learning events. Dave
  21. I too have the Starrett set. Not cheap but bought it and never looked back. Quality tool.
  22. Thin brass shims to narrow the slot? . Wide variety of thicknesses available. CA glue to bond the shim to the standoff.
  23. Welcome to the Zen of model shipbuilding
