CPDDET
Posts posted by CPDDET
  1. Unless, or untill, you reach the point of scratch building your models, the errors in the kit are just a fact of life.
    I have already accepted that my Bluenose, which is my first build, is more of a learning tool for future builds. I doubt anyone becomes an accomplished shiprwright untill they work their way through the first build.
    Stick with it and make each stage your best effort. You will be surprised at how much you skill improves as you progress through the build.
  2. I have found a light sanding with 800 grit paper does a pretty nice job.
    If paint is to be applied I sand as above, paint on a light coating of Delta Ceramcoat (sanding sealer), let dry and sand again. This gives a nice clean, fuzz free surface.
    After paint has dried I spray a matt finish of acrylic sealer.
    Both the Ceramcoat and acrylic sealer can be found at Hobby Lobby, or probably Michael's Crafts.
  3. Next up on the build list was the Jumbo Jib Boom Crutch. The top piece and knees are laser cut pieces but the uprights have to be cut from stock. The instructions call for 1/8 square stock but I found the thickness of the laser cut pieces closer to 3/32nds so that’s what I used for the uprights.
    I cut a scrap piece of wood to place between the uprights in order to keep them at a 90 degree angle while clamping. Using PVA glue I set up clamping on my MicroMark magnetic jig. I have found this 10 ¼ inch square metal tray very useful for clamping various items, especially when it comes to building deck furniture. The ends of the metal plate are bent up at a 90 degree angle which is a big help. In order to keep the glue from bonding to the plate I taped a piece of plastic wrap on it. Plastic wrap (Saran Wrap) seems to work well for PVA and wax paper for CA.
    After the glue dried I did some sanding and glued on the knees, again with PVA.
    Then mounted the assembly on a scrap piece of wood with double stick tape. Staying with my color scheme, I put on 3 coats of Varathane Poly Stain instead of painting it white as the plans call for.
    According to the plans and the instructions that came with the model, the hoisting mechanism attached to the crutch as well as the engine box on the port side of the crutch were removed for racing, so I will be skipping those and install the boom crutch without these parts.
    As best as I can tell the counter shaft assembly and stand remained on the ship for racing, along with the windlass. So next up will be the countershaft assembly and stand. Some of these parts look usable while others look very rough and will probably have to be remade.
    And so it continues……
  4. 19 hours ago, Snug Harbor Johnny said:
    I've reviewed your build thus far and am impressed by the care and craftsmanship you exhibit.  It is an inspiration for me to better my intermediate (at best) technique, yet in this line we all must chart our own course.  Doing the best we can , within practical limits, can be a source of satisfaction one can't put a price on.
    Thanks for the kind words!
  5. 20 hours ago, CPDDET said:
    What's more important at the very start is getting your keel pieces flat and straight. I took a tip from a great book to make mine and I'll pass that along to you ASAP.
    The Book
    The layout board for the keel
    It's simply a piece of shelving cut to length and a ledge board screwed down even with the bottom edge of the shelve piece.
    This allows one to rest the bottom edge of the keel pieces on the shelf and glue them together. Then I placed a second piece of wood on top of the keel and clamped all three layers ( shelf, keel and top board) together. You can use wax paper or index cards over the glued joints.
