Everything posted by grsjax
I have one like this but different brand name. Made in China but once the blade was sharpened it works really well. Think I paid $9.95 for it on eBay.
Looking good. What a great starter kit. Looking forward to seeing Model Shipways new series develop.
- 30 replies
- grand banks dory
- model shipways
Model ship stations identification help request
grsjax replied to highlanderburial's topic in Wood ship model kits
Both kits were manufactured by Corel. Don't think they are still in production but both are available on eBay. -
Lower cost (?) shiny metal parts
grsjax replied to Patrick Matthews's topic in Metal Work, Soldering and Metal Fittings
Copper can be plated directly on to non-conductive surfaces. The process is called electroless copper plating. It is a fairly simple process but does require the use of formaldehyde as a reducing agent. Using this process a thin layer of copper can be plated over almost any surface. Electroless copper plating is used to make printed circuit boards. The advantage is that the metal layer is uniform over uneven surfaces including inside holes. plated items can be used as is or as a base for electroplating with other metals like nickel. BTW brass electroplating is possible. Caswell sells a kit for it. EDIT Here is a PDF of a process for electroless copper plating. http://www.nmfrc.org/pdf/p0295g.pdf This process can be done with chemicals available on ebay and Amazon. WARNING Sodium Hydroxide and Formaldehyde are not chemicals you want to be careless with. Wear gloves, eye protection and a mask when handling them. Sodium Hydroxide is a powerful corrosive base that can cause a lot of damage to your body. Formaldehyde is a poison. Treat these chemicals with respect. Work carefully and always work in a well ventilated space. -
Recently picked up a Midwest Endeavour I kit. Great looking kit marked "Level 4". Did Midwest make any other level 4 kits? I have seen a few level 3 kits but this is the first time I have run into a level 4. I would be interested in hearing about any other level 4 kits that Midwest produced.
Hi Chris I have looked at the Bluejacket listings but apparently there are a lot of older designs that they do not have. Maybe someone has some old Laughing Whale or Midwest catalogs they can share.
I keep running across models made by Laughing Whale and Midwest that I never heard of before. An example is the square toed frigate kit on eBay. Is there a complete list somewhere of all the kits that were offered by these two companies (they seem to share a lot of designs)? There are the common ones that show up on eBay and are listed at Bluejacket of course but it seems there were a lot more of them produced then the ones you see.
No responses to my inquiry. I went ahead and bought a Bucktool scroll saw anyway as it had pretty good reviews on Amazon and had more features than other saws in my price range. Saw arrived today and first impressions are very good. Haven't cut anything with it yet but after setup and blade installation I gave it a dry run. Sitting loose on a concrete floor it ran very quite with very little vibration. The saw is rather heavy with a cast iron base and table. Table insert is steel and fits very well. Blade installation is easy and the air blower actually works but not sure if it will be up to clearing a lot of sawdust. So far so good. After cutting some wood for a model I am working on I will let you know the score.
Not mine, just saw it on eBay and thought someone might be looking for one. https://www.ebay.com/itm/The-Laughing-Whale-The-Square-Toed-Frigate-Wooden-Ship-Model-Kit-No-124-Boxed/392901137512?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Dfe97e1f9b7e440ea854e282df544f815%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D392900052305%26itm%3D392901137512%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A340f2f7f-d9e5-11ea-974e-5ef97f0ce4b3|parentrq%3Ad0f9de9f1730ad397f240289ffffcab6|iid%3A1
Interesting article. https://www.jpost.com/israel-news/christian-muslim-symbols-found-in-7th-century-shipwreck-in-israel-636389
Anyone have experience with Bucktool machines? I was researching scroll saws to fine one to replace the old and decrepit Dremel I have when I ran across this company. Specs on their 16" scroll saw look good and the price is within my budget. Reviews look ok. It isn't a top of line machine but has some very nice features like a foot switch and cast iron table that similar machines from Wen, Shopfox, etc do not have. Looking for some input from users. https://www.amazon.com/BUCKTOOL-16-inch-Variable-Scroll-Pinless/dp/B07T4N9L93
Great for working on ships in a bottle.
