Everything posted by grsjax
Thanks I think I will go ahead and order one. I will put up a review of the kit.
Any reasonably hard wood with a fine, straight grain can be used for most parts of a model. Best to pick out your own pieces if you can to get the best results. That said some woods are better for some purposes. For a general all around, low cost wood go with basswood. Poplar is also a low cost alternative that is a little harder than basswood. Not the best woods but pretty good. I like cherry for most purposes but it doesn't seem to be the best for steam bending. Apple and pear are good for just about anything. Black walnut is excellent if you can find good pieces with out wild grain or knots. Maple is good for the backbone of the model and decks but get wood with a fine grain, not the typical stuff you find at Home Depot. Boxwood is an excellent wood for everything especially carving but it is expensive. There are lots of woods that can be used in modeling and they don't have to be the ones found in kits or from wood suppliers. I find that aracantha, dogwood, gardenia, plum, lemon, lime and other woods I find available around here work just fine and are usually for free. You do have to season it and mill it yourself but it is easy to do with a little practice. One last thing. Don't buy wood from sources in China. What they label as cherry, walnut or boxwood has only a passing kinship with the real stuff.
- 28 replies
- construction
- models
(and 3 more)
New to ship modelling? But what do you build first?
grsjax replied to MSW's topic in Wood ship model kits
Just a suggested addition to the list of kits for people with a little experience, The Model Shipways kit the skipjack "Willie Bennett". Great kit that is not to hard to build and has really clear, easy to follow instructions. -
Yes but also later types up to the early part of the 20th century. I like small work boats as they really represent the majority of ship building and use during these periods. The large ships get all the attention but the small ones did most of the work.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Small fishing boats of the Baltic and north Atlantic and rivers associated with these areas would be great. Actually any small fishing boat would be great.
- 216 replies
- masterkorabel
- ships
(and 3 more)
I was thinking of ordering one of Falkonet's small boat kits. The pictures look good and the price is very reasonable but I have not seen any build logs or discussion of the kit quality. Anyone have any experience building one?
Lots of good kits available that meet your criteria but I would recommend that you go with one that is not to complicated as a first build. Model Shipways "Armed Virginia Sloop" might be one you would be interested in. Instructions are excellent and it builds into a very nice model. Here is a picture from the Model-Expo website of the finished model.
I bought this 2 1/2" vise from Harbor Freight that I really like. I know HF sells junk right?. Well this vise is a lot better than I had expected and for $20 is hard to beat. Very useful for working on parts that need to be turned a lot while in the vise. https://www.harborfreight.com/2-1-2-half-inch-table-swivel-vise-97160.html
1:64 Copper plating
grsjax replied to Peter Y.'s topic in Building, Framing, Planking and plating a ships hull and deck
Have to agree. If you look at ships in dry dock even in the close ups of the bottom the nail heads are hard to see. I would guess that at just about any scale that you want to build in the nail heads would be very hard to see. This is especially true if the ship is shown in service. The oxidation of the copper would tend to blend in the nail heads with the copper plates as far as the observer would see. This link goes to some pics of USS Constitution in dry dock. You can see the copper plating very clearly in some of them. http://gcaptain.com/ship-photos-of-the-day-uss-constitution-enters-dry-dock/?utm_source=feedblitz&utm_medium=FeedBlitzEmail&utm_campaign=0&utm_content=261222#.VYRYhkbz63M- 14 replies
- pickle
- caldercraft
You can use Google translate ( https://translate.google.com/ ) for the text. Copy and paste into the google app and select the language you want it translated to. Not always the best translation but you can usually figure out what the meaning is. This is what the paragraph next to the picture says in Swedish; i skala 1: 130 Samla dina egna händer en stor modell av denna magnifika yacht i en strikt svart uniform med en guldinredning som gick under den kejserliga standarden fram till utbrottet av första världskriget. I samarbete med FGBU "CENTRAL MILITÄR OCH MARITIMUSEUM" MINISTERIET FÖR FÖRSÄKRING AV DEN RUSSISKA FEDERATIONEN
You might try laying a piece of clear scotch tape over the area of the stealer on the hull and tracing the required shape. Lay the tape with the tracing on your .5mm strip and cut along the traced line to get your stealer. I always cut just a hair oversize and then use very fine sand paper with a block to get the final shape.
I have been looking at kits of cutters and have found two that are of the same vessel in the same scale and about the same price. One is the Soclaine 1:50 scale Le Renard and the other is the 1:50 scale Artesania Latina model of the same ship. First impression is both kits are about the same but I know that can be wrong so here goes. Question: Which of these models is the better choice? Quality, instructions, fittings, historical accuracy and general fit and finish? I found the build logs and gallery photos of both models but they were not real helpful in making a buying decision.
Hi Mark Your experience sounds a lot like the experience of a lot of first time wooden model builders. The difference is that you saw the problem and looked for solutions rather than quitting. That right there puts you ahead of a lot of people. Keep at it, ask questions and don't get discouraged.
My thoughts exactly. These look like excellent models but a larger size would be a great help to us with fat fingers. The deck boat in a larger scale like 1:64 or 1:48 would be just the right size. Will these kits have English instructions? The pictures are great but some explanation in English to go along with them would really improve understanding of the process.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Any of the the Midwest Products Level 2 or 3 apprentice kits would be a good choice. Midwest no longer makes them but they turn up on eBay regularly. The best are the Flattie, Sharpie Schooner and Skipjack IMHO. If you want to venture into POF their open boat kits (Peapod, Seabright dory and Boston Whitehall) are a good place to start. There are several other kits of varying difficulty to check out.
Who is selling this kit in the US? I found a place that sells it in the UK for 86Euro (minus VAT) plus shipping but I think shipping would probably be costly.
Billing Boats Marie Jeanne vs. Artesania Latina Marie Jeanne
grsjax replied to Redshirt's topic in Wood ship model kits
I don't have any experience with the Billings Marie Jeanne but I do have the AL one. My impression is that the kit is pretty decent. The laser cutting is very clean and sharp. Fittings look good and the strip wood is African Walnut, Ramin and sapele. Keel and frames are ply. Instructions could be better but arn't the worst I have seen. The illustrations are very helpful. -
Two things. First, what type of copper are you turning? There are many grades and alloys of copper and they have different properties. Second, if you use lard or bacon fat be sure to clean it up really well. When it starts to go rancid it can really stink up a place.
