grsjax
Everything posted by grsjax
  1. Easy way is to google Master Korabel and hit the translate button on the google citation for there website.
  2. If you are interested in a Skipjack model look at the Model Shipways "Willie Bennett". Best Skipjack model available and a great first build.
  3. Hi Yes I paint the end grain of all my green wood. The strawberry guava just doesn't do well when it is drying. I have been looking for a tree that died standing hoping that drying out like that will make the wood more usable.
  4. Hi I have some quava drying now. What type of quava are you using. Here in Hawaii we have several varieties of quava some with very different qualities. What I have now is white quava which looks to be very good. There is also yellow, red and strawberry quava. The last is really hard to season. Seems no matter what I try it splits badly.
  5. Great looking rope. I hope you do decide to produce it as it looks so good.
  6. Another good site for finding books is bookfinder.com . I have found some very good deals on rare/out of print books there.
  7. How fast are you running the wood through the saw? If you are moving to fast it can result in poor results. Try moving the piece forward at a slow pace, experiment until you find the speed that works best. A dull blade could also be the culprit.
  8. Another thing you can do to make the Dremel drill stand better is to fill the column with something to stiffen it. A wood dowel of the right size or poring in epoxy thickened with sawdust will do the trick.
  9. I find the Dremel drill press stand adequate for 90% of the drilling I need. Bolting it down to a solid surface helps. For the more precise work a small bench top drill press is the way to go.
  10. I would go along with the suggestion of using poplar. It is usually available from the big box stores, is fairly cheap, harder than bass wood but still works easily and looks good. As for slicing up the wood you might want to invest in a hollow ground planer blade for your table saw. With care you can get very thin sections using a planer blade.
  11. Was looking at Loctite GO2 glue today at Wally World and was wondering if anyone is using it. From the description on the package it looks pretty good and it works with wood, plastic and metal.
  12. One sold other three are still available. I will ship plans to international destinations but costs may be higher.
  13. This is a startup that isn't on the market yet. Claims it can cut soft material like leather. This is a link to their Kickstarter page.
  14. For a kit like the MSW Bluenose you wouldn't need a lot of tools. Bare bones would be an xacto knife with a No.11 blade (get extra blades), a razor saw, large and small tweezers and sandpaper do most of what you need to do. A few other tools are nice to have like a couple of needle files and maybe a miter box but arn't necessary to complete the model. Look over each step in the process and determine before hand what tools are going to required. Have fun.
  15. I have the US Navy boat book and it is a very worthwhile addition to any library.
  16. Don't know what kind of wood it is but would be surprised if it was boxwood. Anyway if you need boxwood get it from Chuck on this forum. He has high quality stuff at reasonable prices.
  17. There is, or was a company called Woodkrafter that makes simple model ships for kids. Don't know if they are still in business.
  18. Brass spacers used in lamps can make good ship stands. They already have a hole through them so simply running a screw up through the base board, spacer and into the keel makes a solid stand. These are links to a couple of lamp part supplier that sells them. You can usually find good ones for about $5 a pair. https://www.grandbrass.com/category/necks-cast_brass_necks/necks/ https://www.antiquelampsupply.com/lamp-parts/couplings-loops-hooks-swivels/couplings-armbacks-necks-swivels-spindles
  19. Thanks for the kind thoughts. Luckly we are in a spot that doesn't flood and can last for several days if the roads get cut. Biggest problem is going to be power outages. If a lot of lines go down we could be using candles for a week or more. Makes doing fine work very difficult.
  20. I would sand it to fit. Others may have different advice.
  21. It is actually easier working on large timbers if you have the right tools. But as was said above you can't just glue your planks on.
  22. I have been looking at the Master Korabel kits. Just wanted to try a simple small scale boat first and the Falkonet 6 oar boat looked like a good bet. Already ordered the Falkonet kit. Figured if Model-expo was selling them they must be legit. Live and learn.
  23. If they are not to delicate they can be polished in a tumbler. A kids rock tumbler is perfect for this. Use a fine medium like ground walnut shell or corn cob with a shot of liquid polish like Brasso. The finer the medium the better the result will be. Add a shot of Brasso or other liquid polish to the medium. Don't use the grit sold with the tumber, much to harsh for brass. Put everything in the tumbler barrel and let run for 30 minutes or so. Take out one of the parts and check the state of the polish. If it needs more time do it in increments of 10 minutes or so. After it looks good rinse with acetone and let dry.
  24. Good advice. A make do alternative is a hot attic. Don't know what your weather is like there but if attics get hot then you can sticker the boards there and get some dry wood. Down side is you can't really control the moisture levels very well.
  25. These are Model Shipwright plans published by Conway Marine. $10 each including 1st Class mail shipping in the U.S. All Three for $25. Sorry about the poor quality pics. Haven't quite got digital photograph figured out. TSMV Lochfyne MV Ilala "X" Lighter
