TOM G
About TOM G
  • Birthday 07/16/1952
  • Gender
  • Location
    Cleveland, Ohio U.S.A.
2,049 profile views
  1. Study the how-to planking articles on this site first................. This may take awhile, but you have to learn it..................And you'll be glad you did.🙂
  2. How about just making a horn that is in perspective of the structure.
  3. Melt & stretch plastic sprue from model kit........ like making a antenna for a model tank....... bingo you have your horn. the horn would look sweet on it.
  4. DON'T GIVE UP THE SHIP....... Take a long break, review things. And when you are no longer fustrated come back to the work bench, and it will all begin to fall into place.😉
  5. Go to you tube...... type in herbs to improve eyesight...... you can find these herbs on ebay. I use herbs and they work.
  6. Look's like what is happening is the air brush needle point tip is loading up. ( this reduces your volume output making a dryer coat ) This will realy hapen bad when you set the air brush to the side, waiting for flash time between coats. Take the front end apart clean it, and if your going to set the brush to the side for flash time.... spray Windex through it. Also make sure you have the right needle in the brush, you want the one for a high volume cause your covering a large area.
  7. You can use , Pledge floor care in a air brush and get a good shine.
  8. I always get amazed at how you can cut your stock at such high tolorences.👍
  9. I made a model back in my 30's.......... But she dump'd me for a rich guy. 😟
  10. Great looking build ! I have this kit, and the first thing i noticed was that life boat..... ( went in search of ) and found the prize. I think in time the vinyl strips will loose their grip and start to curl. I've built models where i had to drop the ball on...... But it haunts you, every time you look at the model you see that one area that is not in perspective. These life boat kits are plank on frame, they have the length you need. Get them at model expo type in life boats in the search box. 🙂
  11. spray slow dry lackuer thinner over it..... you might have to do it 2 to 4 times you will see it slowy disapear . don't flood it , one pass at a time, and wait between passes till the surface is dry to the touch.
