iMustBeCrazy
Posts posted by iMustBeCrazy
  1. 33 minutes ago, Louie da fly said:
    "sie haffen stund (something) vor Modon sagt man (something something) argt hundert (something something) so al von den turken skafft(?)
    Sounds like me trying to decipher my great great great uncle's journal of his voyage from Gravesend to Adelaide in 1853.
    April 18th The weather now very calm, had the awning up and established a ???? society for the ???? of bad language, G L ??????? secretary. ???? ???? for a week in succession every time one who said a bad word was fined 1/4d which the secretary collected & paid to me every Sunday afternoon, this has proved an admirable affair.
    April 30th ???? the trade winds, crossed the Tropic of Cancer.
    April 23rd Saw Cape de Verde Islands, at least two of them, vis ???? and Brava.
    April 24th ???? all day, one of the forward passengers shot a duck but could not get it, saw three flying fish.
    Back on topic, I think I've cleaned it up some.
  2. Yay, I get to say "No worries mate". :)
    39 minutes ago, vaddoc said:
    Also, another thing I missed is that if we accept that all the drawings of the original plans are to same scale
    Careful with that. If a different scale is used it is usually specified, but not always.
    Another thing, no way is that boat on page 35 'about 21 feet', with only 3 thwarts it's most likely 16, maybe 18.
  3. 49 minutes ago, LucienL said:
    Crazy to think they managed to fit 19 people in there
    Originally Bligh was going to be sent 'ashore' in the 'small cutter' with two or three others but it was 'wormed' or 'stove in' and couldn't be kept afloat (what sort of ship was Bligh running?). So then the large cutter was to be used but that was changed to the Launch. So all three boats were aboard for the voyage.
    The large cutter and the launch seem to have been stowed with all thwarts removed and the 'knees and bolts' kept in the carpenters and carpenters mates chests.
    This comes from the trial transcripts at https://www.famous-trials.com/bounty/399-transcript
    Bligh didn't say much about the launch in his log except 'In the afternoon I got fitted a pair of shrouds for each mast and contrived a canvass weather cloth round the boat, and raised the quarters about nine inches, by nailing on the seats of the stern sheets, which proved of great benefit to us.'
    which may imply that no shrouds were normally fitted (therefore no deadeyes) and with the short masts that may be true.
  4. G'day Lucien, good job, you've left me for dead. I keep getting stuck on making it right and therefore not making it at all since there is no actual information of what right is.
    I've come to the conclusion that this model is based on the replica 'Child of Bounty' built for the documentary 'The Voyage of Bounty's Child (1984)' even though the manual suggests it's based on the drawing on page 3.
    And your information on the blackening solution is priceless.
  5. 1 hour ago, Cabbie said:
    BUT no need to explain
    No problem, when you haul the flag up one side of the line (the one you pulled on) will be under tension. If the side under tension presses on the sail it will deform the sail or chafe or both. In the Mermaid example, if you hauled the flag up the starboard side of the sail the line to port would be the line under tension but it would be clear of the sail. However if you tacked the sail would then press against it.
    Meanwhile, my diagram only shows that when the boom is swung out the point where the line is tied off is still accessible from the deck. If as I suggested above, it was tied off above the mainsheet you would have to crawl out the boom to reach it.
  6. 22 minutes ago, Cabbie said:
    The cutters are meant to be whaleboats as per this which is taken from
    Yeah, just skimmed 'Narrative of a Survey Volume 1'. He mostly just refers to 'the boat', sometimes 'the whale boat' or 'the jolly-boat' and once 'the small whale boat' (which implies two sizes). When he refers to 'the cutter' he is talking about the Mermaid. One of the boats was lost while being towed and a new one built from the spare frames.
    27 minutes ago, Cabbie said:
    Do those measurements look to be for one type of boat or the other?
    I doubt it, on length alone the three big boats could be Launches, Cutters, Yawls, Gigs, Life boats or Wherries but a breadth of around 5 feet would rule out all of those except Wherries.
    And King's sketches seem to be double ended. Given King's remarks, go with Whale boats.
    52 minutes ago, Cabbie said:
    i just don't know enough
    Who does?
  7. 46 minutes ago, Cabbie said:
    Paul
    I assume you mean me, I've been called a lot of names before but that's a first ;)
    48 minutes ago, Cabbie said:
    are they calling the boats cutters on this page?
    Not they, that was written by the man himself. It seems that boat naming conventions can be a bit loose.
    He gives 1st cutter, 2nd cutter, Jolly (or is it Joley) and cutter in frames. So you have to build four then take one apart.
  8. 17 minutes ago, Cabbie said:
    What do you think
    Chris, what I think is mostly guesses, same as everybody else.
    Based on the painting, I wouldn't go over 12' for the Jolly boat and I wouldn't be surprised if it was actually 10' but in CAD I get about 10' 10".
    Cradle of some sorts certainly but perhaps wedges. Those boats must have been securely lashed down. Hard to do on a flat surface without crushing them.
    The last drawing is supposedly to scale, measuring the whaleboat in CAD I get 20' 6" but there must be a margin for error.
  9. More info:
    Perhaps 15 to 29 of these around!
    http://www.cerberus.com.au/reenactors/68_pounder_slideshow.html  gives:
    Ballarat 4 (Eureka Park) 10280, 10284, 10334, 10481 (from another site, perhaps more at View Point, Lake Wendouree attributed to the Nelson but....)
    Bonegilla 1 10350
    Brighton 1 10504
    Daylesford 1 10491
    Drysdale 1 10276
    Moonee Ponds 2 10496, 10498
    Port Fairy 2 10502, 10509 7261, 7271 (numbers off barrel not trunnion?)
    Portland 2 10339, 10302
    Warrnambool 1 10310 7045 (number off barrel not trunnion?)
    This site https://victoriancollections.net.au/items/55b77c242162f119c85679d4 gives "There are only seven 32 Pounder SB made by Carron and fifteen 68 Pounder SB made at Low Moor known to exist in the State of Victoria" with (Reference; Victorian Guns and Cannons, South Western Victoria Assessment, May 2008, item W/B/01; Flagstaff Hill Maritime Village datasheets and archives). But I can't find that document.
  10. Looks like there's a few around, 2 at Port Fairy, 2 at Portland, 1 at Warrnambool, 1 at Moonee Ponds plus yours. I noted there was a recommendation to purchase 19 so there might be some more somewhere.
    This one is at Port Fairy, I took it back in 2015:
    This  is a link to the Moonee Ponds one:
    https://commons.wikimedia.org/wiki/File:Cannon_located_at_Queens_Park_at_Moonee_Ponds.jpg
    EDIT, looks like there are two in Moonee Ponds (Queens Park) 10496 and 10498.
  11. 2 hours ago, Hank said:
    I've also discovered the Edgestar brand (U.S. Manufacture)
    Hank, compare these two. Their cheapest portable with their second cheapest (by $6.00) wall unit.
    https://www.edgestar.com/koldfront-portable-air-conditioners/PAC802W.html
    https://www.edgestar.com/koldfront-through-wall-air-conditioners/WTC8001W.html
    Although they are both 8000 BTU of cooling the portable only claims to cool 150 square feet  whereas the wall unit claims 350. The wall unit also heats, the portable doesn't.
    The portable also uses slightly more power to cool less than 1/2 the area.
    Hope this helps.
