Posts posted by iMustBeCrazy
2 hours ago, MBerg said:
If I do cut them all down, are there any sort of tips or tricks I should keep in mind?
43 minutes ago, Jaager said:Use a saw - a razor saw -
And
43 minutes ago, Jaager said:a miter box
Make your own, the skills needed for model making and tool making are the same.
See posts 261 through 271 in Tims 'Speedy' thread https://modelshipworld.com/topic/34769-hm-cutter-speedy-1828-by-oakheart-from-plans-drawn-by-bill-shoulders-in-1972/page/9/
You can make yours longer so you can set a stop for longer deck planks.
For getting things square, the corners (and sides) of (factory cut) MDF sheets are square and the sides are straight ( you might be able to get some scraps from a cabinet maker) as are the corners of copy paper, both can be used as squares.
By gluing sandpaper to the (factory cut) side of a piece of MDF you can sand things to 90°
2 hours ago, Greg Davis said:
I suspect the cross-wires are actually bicycle spokes so that they could be tensioned.
I suspect all the wires came off a roll of bicycle spoke wire, the hoops were essentially wooden bicycle rims and the tubing was bicycle frame tubing either flattened at the ends or rolled into an oval for streamlining.
- Greg Davis, AON, mtaylor and 1 other
4
Another enlargement:
It looks like the front foil (and I think the back) had suspension:
4 hours ago, Tomculb said:
But I have never taken the time to organize or catalog them
I'm extremely organised (HAH, heehee, hah heehee, mmmph. giggle, giggle) mine are
carefully fileddumped in a folder labelled 'Endurance'.4 hours ago, Tomculb said:I really appreciate what you have shared.
No problem, luckily I like puzzles.
https://digitaltmuseum.no/011024193055/modell-av-fartoy
This model looks like it got it right to me except they were later put over/outside the railing.
3 hours ago, Tomculb said:
it looks to me like the guys may be attached to the boat davits. Which makes no sense since the plans I have found
I thought they might be for a while but the davits are just in the wrong place and moving them would have been very difficult.
Anyway, this shot shows the aft starboard guy just wraps over the rail and attaches somewhere down the side of the cabin ??? Not a stanchion, not the davit. The forward one I think does the same but attaches to the chain plate. Maybe.
3 hours ago, Tomculb said:As I look at that photo, it is facing aft from just forward of the main mast
I would say further forward, starboard side of the forward binnacle?
3 hours ago, Tomculb said:the mainmast forward gaff
Crane jib? But yes.
Edit: This shot shows no sign of them running down the side so I guess they go to the top of the side of the cabin.
- clearway and theoracle09
2
55 minutes ago, thibaultron said:
Then print it at 100%
In Windows for the L121, when the print dialogue box comes up click on the 'more options' tab, select 'Reduce/Enlarge Document and set the 'Zoom to' percentage (jeeeeeze, whats with Epson, everybody else calls it the scale).
- mtaylor, thibaultron, Canute and 2 others
5
1 hour ago, Tomculb said:
when I’ll have a better idea where to attach the other ends of the cables
Tom, it looks like after the kennels were fitted the guys were attached to the top of stanchions so as to clear the kennels.
- BobG, theoracle09 and clearway
3
39 minutes ago, oakheart said:
In their dash to reach the Victorian goldfields in the quickest possible time, many ship's captains adopted the new 'Great Circle' route in the 1850s. Passing far south of the Cape of Good Hope, they sought the 'Roaring Forties' – the strong prevailing winds that blew from the west to the east between 40 and 50 degrees south.
This route involved enormous risks from drifting icebergs and the wild seas generated by frequent storms. It required exceptional navigational skills, as even the slightest error could lead to disaster. The large number of ships that were lost when navigating the narrow path between King Island and southern Victoria led to the West Coast of Victoria becoming known as the Shipwreck Coast.
The Roaring Forties was only the start, you could try your luck further south in the Raging Fifties or even the Screaming Sixties. Along the edge of the Roaring Forties was pretty much the standard route.
Fortunately for those aboard Lapwing she turned north to Adelaide long before reaching King Island or Victoria's south coast.
The Loch Ard is well remembered, the gorge she foundered off is name after her (it's the one with the big car park).
- GrandpaPhil, oakheart, CiscoH and 1 other
4
14 minutes ago, oakheart said:
From what I remember you saying they had loads of other people as passengers, how did they manage on the very long journey?
They finished up with only one paying passenger plus the owners family (wife and two daughters) and two servants (this is from newspaper articles and the servants may actually have been the daughters). They were heading out for the Gold Rush so possibly had a full (free?) crew.
32 minutes ago, oakheart said:Do you know which route they took?
I don't actually have any info from my Great grandfather but again from newspaper reports (passing ships took mail and messages and reported sightings, whoever reached port first let them know who was coming and vaguely when to expect them) it was London to Cape Verde then probably Cape Town via the Brazilian coast, then on to Adelaide or Adelaide direct (I think Cape Town). Roughly 14,500 nautical miles in a boat that fits comfortably in my cousins front yard ( a 1 acre block, ~100' wide).
31 minutes ago, oakheart said:Was the weather with them or did they have bad storms?
No idea but probably.
50 minutes ago, oakheart said:I remember seeing film of a sailing ship going round the 'Horn' it was a not a comfortable thing to do.
Supposedly Bramble just going in to Brisbane:
- mtaylor, davyboy, GrandpaPhil and 1 other
4
22 hours ago, oakheart said:
the problem is I wanted to make the model look like the painting which just grabbed me as an exciting image.
Yes it's an exciting image, probably more so for me as I can (and did this morning) visualise my Great grandfather on board.
I don't remember why I thought she was the 1778 Kite, perhaps I mixed up dates in my head, but that extra row of planking above the gun ports makes her more likely to be post the very early 1800s. Given the painting is dates ca1850 it is possible the artist as a boy knew Lapwings sister and remembered her fondly. There are discrepancies, the companionway faces aft and the wc and pantry are missing but she carries the right number of guns (well gun ports, she probably didn't carry a full compliment of guns) in the right places. He may have used Lapwing as a model as she was still around at the time of the painting but made changes based on boyhood memories, who knows.
Looking at the painting itself, she's running downwind with both the main and square sail set, that would be wrong, she would be unbalanced with the main trying to turn her to port. Look at the helmsman, he's heaving on the tiller trying to keep her on course. The artist understands, this is a chase, every fraction of a knot counts. As you said, an exciting picture.
So, yes this could be Lapwings sister, Speedys aunt.
- CiscoH, davyboy, GrandpaPhil and 1 other
4
21 minutes ago, oakheart said:
I also realised that when I add the skylights to the deck, the boat will need to sit much higher off the deck, I will have to revise the cradle.
Tim, don't forget the pumps.
I had a little play with ideas when you first posted your little cutters little cutter. I came up with ZAZ6347 (Vigilant) which has light pencil lines representing boats each side of the main hatch. Now Vigilant was a little larger making this more practical but I drew 18' (port) and 16' (stb) cutters on Lapwing:
On 4/9/2024 at 3:59 AM, theoracle09 said:
The port side is odd, the sides extend well passed the mizzen deck.
1 hour ago, Tomculb said:I too pondered over the photo you posted and decided that the port ladder was probably a portable one they moved around from place to place.
As they decked over the bridge deck openings the four forward ladders became redundant. It would appear one was cut down and used to get over the top of the kennels, another had a couple of upper treads removed and used port side aft probably because the amount of stores along the centreline prevented previous access from the starboard ladder unless you went all the way up to the mainmast and back. Just a guess.
- Tomculb and theoracle09
2
- theoracle09, mtaylor, Keith Black and 1 other
4
On 3/27/2024 at 5:22 AM, Sanjith_D said:
so I would like to hear your guy’s experiences with whether something like this Would work. I'd also love any tips for any aspect of this project, especially transcribing the Frigate's plan into CAD
Well, you can follow my bumbling path through the links in my sig with the Lapwing drawings and build (to date) but I seriously suggest you start with something simpler than a Frigate, say a dinghy, skiff, dory etc. in 1:24 or 1:16
Meanwhile look for Frigate drawings you like in the best quality you can find, perhaps the Enterprize class, many nice big drawings:
1 hour ago, Mike Shea said:
I really want to capture that beatup weathered as well as that scrap lumber look that ships carpenter, Harry McNish, seemed to use in their construction based on the photographs I've seen.
Mike, I've always seen the dog kennels as recycled packing crates, pretty rough and ready. Built in sections of 3 and 4 dogs, sometimes the gap between two sections is roofed over for an extra dog. Probably 1/2 inch planks roughly sawn to length, butt jointed (I think that shingled look is just warped planks). Those forward seem rougher than the rest, possibly they used the best material aft?
The 'Bovril' shot probably the best guide to their construction.
1 hour ago, allanyed said:
Are you asking about the drawing Craig posted or ??
I think he's asking you. Hope you don't mind, here's some enlargements:
I had been thinking that it needed a sill under the doors otherwise the inboard ones wouldn't open properly.
Santos Dumont No. 18 Hydroplane 1907 by Greg Davis - Scale 1:16
I think it's fine, it looks like the pointy bit is a metal cap with flanges for the wires.
Overall I think your model looks a little too good, better than the original.
