dunnock
NRG Member-
Everything posted by dunnock
Jason, Not a great fan of Dunnock's tea cakes but I quite like their caramel wafers! Interesting to hear that the roof is original. It's pity the ship is only open at the weekend currently, but we were constrained by the Northlink Ferrries' timetable of boats from Aberdeen to Kirkwall. Rob Thanks for the link to the item from the BBC. It's good to see that at least there is a plan for restoration of the ship. It would be nice to think that it could be restored in a similar manner to Victory, Cutty Sark and other classic sailing ships. I'm sure that it won't be the last time that I'm passing Dundee but next time I'll make sure that it's open for visits. David
- 310 replies
- Diana
- Caldercraft
It's been a while since my last post because I’ve been on holiday in Scotland and The Orkneys for the last 3 weeks. On the way up we stopped off in Dundee and went to see HMS Unicorn, a Leda Class Frigate launched in 1824. Unfortunately it wasn’t open on the day we visited so were only able to look around from the dockside. The hull seems to be in a pretty poor state of repair as these shots show but then it is nearly 200 years old; and it's fitted with a strange-looking cover where the masts should be to keep out the Scottish weather. Back to Diana. Before I went away, I had made a start on building up the deadwood to match the thickness of the modified sternpost. Now finished and sanded back, I’m hoping that it will be OK when it is covered in copper. I have also made some of the fixed blocks for the tacks, sheets and main brace from boxwood strip. I've fitted the all but the main sheet block but I want to check its position. The AotS has it sited just forward and about halfway up the second carronade port on the quarter deck. I’m not building up the quarter deck sides as it is shown in the book, so I am assuming that this block would just sit lower down nearer deck. As well as the repair, the paintwork on the wale had taken a bit of a battering so I have applied another couple of coats of matt black. Marking the waterline caused me some trouble, which I finally realised was because the base of my homemade version had to made more stable. Once I had added a piece of scrap mdf, it was quite straightforward. I have added a beading strip at the waterline to give me a border to copper up to, using some black boxwood strip from Original Marquetry. It’s only 0.5 x0.7mm and very delicate a but with careful handling it went on OK. So that’s where I’m up to and with a vapour mask just delivered (thanks for the recommendation Rob) and a bottle of acetone, I guess I can’t put off the coppering any longer. I will be using the Caldercraft plates as replacing them with PE sheets of tiles would be just too expensive.
- 310 replies
- Diana
- Caldercraft
Well thought out solution and neatly done. David
- 286 replies
Hi Jason, I've started to do that on the port side just to try it out as a fix. I've also had to use a couple of layers in one area to build it up. I guess doing it on the first layer, it was easier to disguise. I'm pretty annoyed with myself as the second planking wasn't looking too bad overall. David
- 310 replies
- Diana
- Caldercraft
Thanks for your encouragement AJohnson . For me HMS Swan was quite an advance on my previous builds, and provided plenty of challenges and scope for adding extra detail. It makes a lovely model when finished. I think HMS Diana is a further step up with some new challenges, perhaps partly because the age of the kit means that the machining of parts is not so accurate as later kits but also coppering is something that I have not attempted before. I'm sure there will be plenty more 'learning opportunities' that will appear as the build develops. Having said that, your Bounty is looking great, so I'm sure that you could make Diana your next build if you wanted to. Cheers David
- 310 replies
- Diana
- Caldercraft
After planking, the keel/false keel should be 6mm deep and needs to be built up. I tried using four pieces of square section spruce joined with hooked scarf joints as shown in the AotS but couldn’t get a clean finish. In the end I abandoned the idea of authenticity as this area will be covered by copper plates and took the easy way out by using maple strip. I cut away part of the prow and built it back up to merge with the increased keel using 3 strips of 1mm thick maple. I also worked on the stern post which I had made earlier from 7mm boxwood and fixed it with carpenter's glue. However now that I look at it, I realise that earlier in the build, I cut back the deadwood area of the keel too far and the enlarged sternpost sits proud of the planking. I should have thought this through better at the beginning when I was preparing the keel and bulkheads. In my last model, HMS Fly, I needed to cut back the deadwood area to make the planking flush and almost automatically went the same way with Diana. Maybe it was later that I decided to cut off this plywood section of the keel to make way for a more authentic looking boxwood sternpost without thinking through the implications. Another lesson learnt. I’m going to have to have to decide on the best way of building this area up.
- 310 replies
- Diana
- Caldercraft
The planking is finished at last. It looks a bit of a mish-mash using walnut below the waterline but boxwood is expensive and as the walnut will be covered up, it makes sense economically if not aesthetically … But using different wood from different sources has complicated the finishing because of the various thickness of the strips. I needed to remove quite a bit of walnut to get it to run into the boxwood so I decided to do some preliminary work with my electric detail sander. I thought that I was being careful not to damage the boxwood but obviously not careful enough because, at the stern, I sanded away some of it through to the lime below. Luckily, this area is below the waterline and will be covered. I don’t think that it has affected the overall symmetry. I also managed to damage the wale but the one affected top &butt plank was easily replaced. Lesson learned – forget the electric sander next time and even though it may take longer, better to sand the hull by hand. and repaired. A lot of painting and touching up is needed but I will leave that while I concentrate on getting the hull ready for coppering.
- 310 replies
- Diana
- Caldercraft
HMS Diana by ECK - Caldercraft - 1:64
dunnock replied to ECK's topic in - Kit build logs for subjects built from 1751 - 1800
Hi ECK, Good to see another Diana builder on the forum. DIana is a great kit with plenty of challenges: you have already identified one of them, but you'll find lots of help and ideas from previous Diana builders' logs on this site. You've made a great start, so keep going and enjoy! David -
Thanks everyone for your likes: always encouraging. Over the three weeks since I last posted, I have been working on the planking below the wale. I started by reading and re-reading the various articles on planking techniques in the hope that I might be able to make a better job than usual, even if most of the planks will be covered by copper plates. I am using boxwood in the area above the waterline which creates a bit of a problem. The nearest boxwood strip to the kit walnut I could find in the UK is 4.5 x 0.7mm. The kit walnut that I will use below the waterline is a nominal 5 x 1.0mm but is actually 1.1 to 1.2mm thick. It will mean quite a bit of cutting in and sanding is required during finishing but I’m sure it will be OK. The garboard strake was the first to go on, made from a strip of 8mm walnut shaping it fore and aft and finishing at 7.5mm in the centre. After measuring the distance between garboard and wale at each bulkhead, I divided them into 5 bands using vinyl tape. The first band was divided into 6 strakes of 4.5mm boxwood and the other four into 5 strakes of 5mm walnut. After a lot of re-adjustment, this was the nearest that I could get to fair lines. The AotS shows the first six strakes below the wale are in top & butt but I decided that this was a complication too far for me and went with butt joints. It was slow work as every plank at the bow needed to be shaped. A card template above and the first spiled strip of boxwood for the bow below Continuing with the boxwood Boxwood nearly completed on the starboard side. A bit more to add at the stern. Start of the walnut planking The spiled walnut planks at the bow are cut from a 1mm sheet - and another thickness to add to the mix. This is as far as I have got, with three bands of planking down from the wale nearly completed. As you can see a lot of sanding will be required to get the margins between walnut and boxwood level. For the final two bands I will work upwards from the keel. I find I can do 2 or 3 complete strakes per day so a couple of more weeks should see the planking complete, a milestone I am looking forward to. However that it means I will be moving on to coppering, something I have never done before but hope that it is easier than it looks. David
- 310 replies
- Diana
- Caldercraft
Those ropes look very good compared to those normally supplied in kits. I'm very tempted to get one - maybe I can drop a few hints to the boss for my birthday along with the complete set of blocks for my Diana that's also on the list. Is there import duty to pay into the UK? David
- 286 replies
I'm a long way off from doing the rigging on my Diana but the nail cutters I have been using are no longer very good so I have ordered some too while I the reference is freshin my mind. Thanks for the recomendation ... had to break off for a knock on the door - they have just arrived!
- 725 replies
- vanguard models
- speedy
Many thanks Rob for your feedback. Looking at your Diana, I take is a great compliment. I have no affiliation with Original Marquetry, but I must say that their service and quality of wood is excellent. Ordered on Sunday arrived on Tuesday so no delay in planking above the wale. Planking has proceeded slowly but after completing the first few strakes, I realised that I hadn’t allowed for setting back the edge of the planking around some of the sweep ports. Cutting half mm strips away from the edges was tricky but I think that they look ok. Cutting the ventilation scuttles at 4 x 2 mm was tricky too. These are also lidded but I haven’t lined them so I haven’t set back the planking from the edges. On reflection, this might be a mistake but if I change them, they will look too big. Some spiling of planks around the bow was necessary to get them to sit anything like flush. I continued planking up to the level of the waist on both the port and starboard sides before pausing to consider the quarter deck gun ports. The sheer strakes between the top of the gun ports and the gunwale at the waist are wider according to AotS and the one directly under the gunwale are joined with hooked scarf joints. This is the unfinished planking above the wale which is looking a bit rough but I hope will clean up well before I move on to planking the rest of the hull. Before then, I will be reading up on the many articles on planking techniques, particularly those by David Antscherl and an article called Simple Hull Planking Techniques for Beginners by Dirk De Bakker and Greg Brooker. The latter sums up my situation and needs pretty well.
- 310 replies
- Diana
- Caldercraft
The main wale is finished and I have started the second planking above the wale line. I used the kit walnut and first glued 6 strips of 3 mm wide, followed by two strips of 4 mm and 2 strips of 5 mm. My idea was to avoid having the joint lines correspond between the two layers but I applied the second layer in the sequence 5, 4, 4 and 5 mm thus ensuring that the centre joint line corresponded perfectly! Each layer was sanded in between and the top layer of 0.7 x 6 mm boxwood from Original Marquetry applied. The boxwood was applied as 115 mm planks cut top and butt in a pattern as close to that shown in the plank expansion in AotS as I could get. The wale was finally painted with Tamiya matt black. I needed 4 or 5 coats to get a good finish. It has a slight sheen, perhaps more of a satin then a dead matt. It’s the first time I have used Tamiya acrylic paints and I was surprised how thin it was although it did cover well. I assume the paint is designed to be spray applied but having no spray gun, I used a 1/2’’ Daler brush. First layer of the wale Second layer of kit walnut Top and butt in boxwood The finished main wale I have made a start on planking above the wale using 4 and 5 mm boxwood veneer. The thickstuff above the wale was first applied with a layer of 5 mm kit walnut followed by 5 mm boxwood. In the planking expansion, the lengths of plank varied considerably, perhaps based on the timber available at the time. I have cut planks to a nominal 115 mm but used other lengths where joints would come in an inconvenient place. The ventilation scuttles were fiddly and I hope that I have cut the planks around the lidded gunports correctly. I will continue planking above the wale before starting below. I notice that the first 6 strakes under the wale are in top and butt planking, although I think that they will only be mostly visible at bow and stern, the rest being covered by copper plates. Nevertheless I will probably have to order more boxwood.
- 310 replies
- Diana
- Caldercraft
Thanks to Theodosius and Black Viking for your likes and comment and to Rob for advice on the gun ports. I went ahead and the lidded ports are now also lined using 6mm wide lime strips. They are set back from the edge by the thickness of the lid plus second layer of planking. The lower counter has been planked with 3mm kit walnut. The ports are marked out to the sizing in the AotS rather than the kit plan. I’m not sure what these ports are for. I don’t think that they can be gun ports and in the AotS diagram B3/1 they are identified as false lights, (the key for 17 and 21 being transposed I assume). The picture of the model on page 16 shows them as open cut-outs but they are obviously meant to be lidded as photographs of other models in ‘The Sailing Frigate’ clearly show. The helm port has been cut out to accommodate the thicker sternpost and the rudder that I have still to make. The Main Wale… The position of the wale, as others have said, is critical to the look of the ship and how other elements, particularly the quarter gallery relate to it. I plan to start the second planking by completing the wale using 3mm kit wood to build up the thickness and then to finish off with 0.7mm boxwood veneer. I’m contemplating making the top veneer in top and butt although after painting black, it might all be hidden. I started by marking the waterline using a pretty crude rig of block of wood with a pencil clamped to it and then followed up with masking tape. The position of the top of the wale was marked using measurements taken from the centre of the lower edge of each gun port. I used the AotS drawing, although the measurements on the kit plan are similar. Once marked, I taped a strip of kit walnut to the hull to check the line and its position relative to the waterline. I feel pretty happy with the look and how it will sit with the quarter gallery so I can go ahead and plank the wale but I think first I will fix the boxwood knee of the head which I have marked off to simulate the pieces that make it up and cut a rabbet to take the planking. I am hoping that this will give me a neater finish than adding the stem after planking.
- 310 replies
- Diana
- Caldercraft
A bit of an update and later a question… I completed lining the gun ports without lids as per the instructions. The 10mm strips left plenty of overhang to allow for trimming and sanding back and they are now painted to the same red as the internal walls. I have used a mix of Humbrol red 60 and brown 70 which was recommended in the Victory kit of HMS Fly and was left over from my build. After sanding and repainting the inner walls, I realised that I had not considered the sweep ports. These are not mentioned in the instructions until much later and then are only addressed by sticking on bits of 4x4 to the outside of the hull. I wanted a better representation since they might just be visible from the inside. There are 5 of these along each side. From the photo below you can see how many attempts I made at measuring. AotS shows 3mm ports but I went with the kit sizing at 4mm which were difficult enough to make. I lined the first couple of ports with 1mm thick walnut strip but this was tricky to get right and looked too thick, so I stripped them out and used 0.5mm which looks in better proportion. These too were sanded back and the inner walls touched up again. Now the question. Why leave lining the lidded ports until after the second planking is completed? I can see that the lids should fit flush with the hull on the outside, which means leaving the second planking short around the ports by 1mm each side. However, the lids provided in the kit fit inside the 16x14 ports, so after covering with the second planking, they will have a 1mm lip of thin planking all round. Last October I went down to Chichester for a few days of bird watching and to look around Victory and Warrior. As can be seen in the photo, the whole of gun port lid on Victory fits inside the gun port and there is no lip. I'm planning to line the lidded gunports now allowing for the thickness of the lid. They could then be finished and painted without risk of paint bleeding onto the second planking. The second planking should then run up to the edge of the gunports. Maybe this is all a statement of the obvious and I am overthinking it but I would be interested in any comments. David
- 310 replies
- Diana
- Caldercraft
Don't be so hard on yourself. That deck looks very good and the top and butt planking is very neat. Well done David
- 16 replies
- Swan Class Sloop
- fly
Those gunports.. The positioning of the gunports is as problematic as everyone says. I started by using the side profile from the AotS as a template but found it didn’t work out that well. In the end I placed the upper line of the gunport along the second layer of planking as per the kit instruction and measured the placements from bulkhead 16. All are spaced at 30mm except 7 & 8 which are 35mm apart and 3& 4 which are at 28mm. I found that this avoided the problem of cutting through bulkheads but overall the line and spacings still looked OK to me. I drilled around the edges of the ports using a 1mm drill bit beginning at the stern. After drilling 5 ports, I stopped to check from inboard and thought they looked too low. I cut out port 14 and made up a single 18lb cannon just quickly to see how it would look. You can see from the photo that the gun wasn't sitting centrally as it should. My idea was to site the barrel between spirketting and string, so if I’d thought about it properly, I could have avoided this mess by making sure that happened when I marked the up the gunports. So now I had to cut out the ports that I had drilled and add a filler to lift the sills to the correct height. Having done that, I think that the test gun now looks much better placed within its port. Just a word on the cannon. The barrels must have been changed since earlier kits where builders complained of over-sized cascabels and of being generally the wrong shape. I’m quite happy with the ones supplied, being pretty similar to the AotS drawing. The carriages though are a bit rough and will need some work and I will probably at least replace the trucks. I don’t like the walnut ones at all. To make sure I got the port at the right level, I used a hand drill to make reference holes at the top of the gunport position from the inside of the hull and then measured and marked the outside of the hull accordingly. I was much more careful now, checking as I went along that the ports were sitting correctly, first down the port side and then followed the same marking system along the starboard side. I sanded the ports to leave some room for final finishing at the next stage when the linings are added.
- 310 replies
- Diana
- Caldercraft
The filling and sanding of the hull after first planking is now completed, so the next task was to complete the fo’csle and q’deck walls. I made a couple of temporary balsa wood filler blocks for the bow where there was no longer any support for the planking, having earlier removed the plywood stem. A single limewood strip was soaked and bent around the bow, left to dry for it to take on the shape and finally cut the scrolls to shape before gluing to the hull. The q’deck was a little more complicated. I looked at various drawings from the NMM archive and in the AotS . ‘The Sailing Frigate’ by Robert Gardiner, which has several pictures of Diana as-built was also usefu,l as well as previous logs of Diana builds. Finally I drew up a template. It’s a bit of a chimera but following Jason’s view above that there were many configurations of q’deck at the time of the Diana, I opted for a carronade and cannon layout similar to Rob Durant’s Ethalion. It may not be historically accurate but I wanted to include both open rails and carronades, so I'm happy with this compromise Lining up the template with the stern gallery The walls were made off model with three strips of limewood glued together, then shaped before glueing to the hull. The gun ports were marked out and scored for later cutting. I also previously cut back the bulkhead struts to the level of the q’deck walls. Template and above the q'deck walls glued up I will next mark up the lower deck gun ports and cut them out. In preparation, I have printed out at 1:64, the planking expansion drawing in AotS to help with the alignment. David
- 310 replies
- Diana
- Caldercraft
Thanks Rob and Jason for the advice and encouragement. I've spent the last two afternoons sanding and filling and sanding and filling and... A little more to do but as you say Rob good preparation will make the second planking go more smoothly. David
- 310 replies
- Diana
- Caldercraft
The first planking of most of the hull is now completed. It threw up a few challenges to avoid the worst of the clinkering at the bow and has meant a few pointy planks and small fillers. I have tried before the idea of splitting the hull into sections and marking out each with tick strips but was never able to get on with it. Probably because my starting points and measuring were not precise enough. Maybe I will have another try on the second layer. Just the quarterdeck and fo’csle walls to complete. At the bow, I am grateful to Jason for his solution to the problem of providing support for the planking where modifications for the bowsprit and the stem have taken it away. At the quarterdeck, I like the more open appearance of the configuration as built but I would also like to include the carronades in the build. Was there ever a time when carronades were present before the rails were filled in ? David
- 310 replies
- Diana
- Caldercraft
Looks like a well put together kit and should be a very enjoyable project. The hull certainly looks very sturdy. I'll be following progress with intrest. David
- 286 replies
I realised why my deck was so flexible, having forgotten to fix the deck beams beforehand. Stupid error but it won’t be the last I’m sure. I fitted beams 7a and 10a and cut them around the hatch openings but I left the others off as they went right under the hatches. The coamings should add some rigidity once fitted. The inner walls went quite well. The 5mm strips of limewood from CMB were nicely finished and didn’t require much cleaning up. Two runs of 5mm which I painted first, followed by 3 of 4.5mm Tanganyika and a final row of 6mm limewood. I am hoping that all this will make it easier to cut and line up the gun ports, the bottom edge of which should sit along the top of the 5mm planks. I planked the entire run of inner walls having first thinned down the inner front bulkhead struts to give a more even run. Sanded down and painted red and the area behind the forward cabin bulkhead white. It’s a pity that the cabin area can’t be opened up more to be seen through the gallery windows but that would involve a lot of cutting away of bulkheads. Without modification I know that this area will not be seen easily, if at all, but I want to add the cabin partitions again like I did with Fly, hopefully making some improvements this time. I have now started on the first layer of planking. The 6mm strips provided in the kit are really good. The first plank at upper deck level. There are some irregularities in the height of the supports but I will level these out later. The first two planks went on straight followed by the next tapered at the bow. I am chamfering each plank on the bottom edge to try to get a tight fit edge to edge but I still have difficulty get them to mate together in places. The irregularities will be taken care of with plenty of sanding and filler later. So far I have been fitting a plank each side to keep things even. I’ve got to the tight bend at the stern section. is a struggle and I am also wondering whether I have tapered the planks at the bow by too much. Anyway, I’ll keep going…
- 310 replies
- Diana
- Caldercraft
Hi Tim, Only just caught up with your log so apologies for my lateness! Your ship is looking really good. I used the kit pivot guns but wished I had made an attempt to replace them with barrels and new brackets. I did replace the posts though with 3mm boxwood because the kit supplied walnut ones were not very nice and I couldn't get them to fix firmly. David
- 164 replies
- fly
- Victory Models
(and 4 more)
