Duanelaker
Everything posted by Duanelaker
  1. Looks like you are doing the Providence whale boat! Start a log I am sure someone can help 😊
  2. Putting together the engine room and all of the bottoms structures will be fun...I’m doing my best to read, check against the drawings, look at the pictures, think about it.... this pictures shows you how the slot is not nearly wide enough for the plywood...but I need to figure out how to make the structures the correct size and maximize glueing and strength, without creating interference. Fun!
  3. So this kit is different as the hull is created differently. Both sides cracked on me so I will have to brain storm and figure out how to replace it...
  4. So in laying the second planks I decided to do the port and starboard simultaneously and before I cut and glued them to the stem, it dawned on me that I hadn’t edge glued them to the previously placed plank. I had been using CA since it was in such small amounts but I don’t want to edge glue with the CA as I don’t want to over expose my self to it. I really want to be able to just put a clear coat on it when I am done. my question is what is the best way for me to edge glue the planks to one another? I would like to use PVA, I usually use TITEBOND, should I switch to elmers white glue?
  5. Quick note: DO NOT GLUE YOUR BOTTOM PLANK OR ANY PLANK TO THE FORMS, only the stems get glued to the building board. I didn’t make this mistake, but I almost did! I the glued the stem/bottom plank assembly onto the strong back and laid down my first plank. It went on fairly easy so fingers crossed. I am also lightly sanding each of the planks as I put them on in hopes to cut down on the basswood fuzz.
  6. Next up was setting up the building board with the forms. After gluing the forms onto the strong back I glued the stems to the bottom plank and marked it per the drawing. I ended up having to remove one of the stems and shorten the bottom plank. Once I compared it to the drawing it was about a half inch long.
  7. So I followed the very well written instructions and took the Forms and stems out of the kit. I used my Sand it from micro mark to cleanup the edges. I then marked out the building boards and center lines
  8. It was interesting to find out that “The Peterboro Canoe” was named due to the association with Peterborough, Ontario. There was a time almost any wooden canoe In the traditional Canadian style, that is, one basically having the appearance of the woodland bark canoe of the North American Indian, could be referred to as “a Peterboro” certainly a rich history with these canoes. So here is a kit I purchased on eBay for less than $50, well worth the hours of entertainment.
  9. I will be starting two logs actually 😝. Following In the wake of the ridiculous money I have spent on eBay, I will be starting a Peterboro Canoe which is a level 2 kit and one I am hoping to do a nice job on and also a Artesania Latina King of mississipi but this kit is probably 80’s...it’s also advertised as 1:50 scale which I don’t think it is, the newer ones are 1:80 I believe.
  10. Another one completed. Would definitely recommend any new modeler that wants to get his feet wet without diving in the deep end to pick up a Midwest kit. I believe even that hardest ones still have great plans, instructions and material.
  11. Welcome to the site Bob! Very interesting introduction, and I love your Indian Girl Canoe.
  12. I bought just about every type I could find lol...their are still quite a few at a good price on eBay. I even found a two seater Chesapeake bay kayak 😆
  13. I have one side of the boat mostly finished and I floor planking done...I need to add a semi gloss to them or not, haven’t decided. Should have this wrapped up if work goes well.
  14. I had a blue color I happened to like, it is a little darker then what the plans call out, but I like it. you can see the crack on the planking above 😳
  15. I ended up cracking the one side of the planking due to one of the frames being out of whack...it didn’t bother me enough to fix it lol
  16. I built the building board. I always do whatever I can in order not to have to put tacks through the bottom of the hull.
  17. So like always I follow the directions that are very straight forward. I try to think about painting and finish before I start. I enjoy these basic kits but I am certainly wanting to go big...
  18. Welcome to the site!
