Posts posted by LyleK1
5 hours ago, Trond said:
Your doing a great job Lylek. Hull planking is something I need to focus on my next build.
So walnut is your big love now? 😉
How much of the inside are you planning to show or put in another way, how big of a hole in the side are you removing/not installing?
Hey Trond,
Appreciate the compliment!
The walnut is looking really good but no, there is zero love between us! I can't imagine how far along I would be if I was using basswood (or something similar). However, I think the experience will make planking easier the next time.
The entire starboard side is open! See the pics below, the last one is obviously, not mine!:
Thanks for stopping by! I'm headed over to your log next!
- AJohnson and DARIVS ARCHITECTVS
- 1
- 1
On 4/5/2021 at 12:05 PM, TOM G said:
Looking good 👍
Thanks Tom.
Appreciate the feedback.
- AJohnson, TOM G and mort stoll
- 3
30 minutes ago, JOHN BLAKELY said:
Trying to get replacement both photo & instruction manuals for Artesania HMS BOUNTY.
Have you tried contacting them?
I understand they are back in business.
Once I had the planking belts worked out, I went in and marked every frame with the plank locations:
Each belt has 6 planks evenly distributed, at least in theory!
The next step for me was to map out the plank butt pattern. I decided on a 3 shift pattern. I used a piece of paper and laid out the entire side of the ship:
Not perfect but most ships weren't built perfect!
Let the planking begin:
Walnut is a real challenge but I'm working through it... slowly!
Next post when I've made some progress!
- mort stoll, CiscoH and TOM G
- 3
So, I'll jump in here too...
I'm building the Artesania Latina version of the Bounty and like both of you, the instructions are pretty useless after the first few steps!
I use several build logs (most AL logs) as my help.
Between us, we should be able to get through most issues. Feel free to following along with mine as well. I know that each version is a bit different but the end game is the same!
Good luck and I'll be watching intently!
Upon review, I decided to install the garboard... it's been a challenge!
At the stern, the garboard does a near 90 degree twist. You should try twisting10mm X 2mm planks! Not easy. After many ::SNAPS::, I finally did develop a good system and the key to it is patience! And a lot of it... Bends and twists can be made but only incrementally.
The port side garboard is in place. The starboard side is almost done... still shaping the bow plank... like I said, very slow work but it will get easier with the 5mm X 2mm planks.
Once glued down, I'll get the planking belts laid out.
Back with more when I make some progress.
- mort stoll and TOM G
- 2
First layer of the wales completed:
A little rough but nothing a sanding won't fix. The bonus is that I have developed a system for spiling the walnut planks that seems to be working pretty good and the more I use it the better the outcome.
On to laying out the planking belts!
There will be four planking belts of 6 planks each for a total of 24 planks and the garboard to the wales.
This part has to be PERFECT before moving to the actual laying of planks. I expect it will take me several sessions to get the lay-out right. Additionally, I have to figure out the butt pattern... probably a 3 or 4 shift pattern...
The picture above is the first step... Finding the center belt.
See you soon.
- TOM G and mort stoll
- 2
1 hour ago, Don Case said:
If you come across anything interesting please post it here. There is not much to go on. I'm hoping for a few gems from the book. I don't know if you're old enough but I was a big Capt Puget fan when I was a boy, 60 years ago.
I'll keep an eye out...
I am aware of Captain Puget but slightly before my time! I do remember Don McCune on "Exploration NW" though!
Whereabouts do you live on Vancouver Island? We boat up in that area every year... when there isn't a pandemic!
Look forward to watching you log.
4 hours ago, mort stoll said:
Hi Lyle,
Been meaning to ask - perhaps I missed it - did you post any photos on how you built your chairs? They're great.
Thanks,
Mort
I cheated!
I bought them as a kit. I got 10 chairs that had to be assembled. They were all laser cut on very thin basswood.
I thought they looked better than what I could build!
Not a lot of progress this week as life got in the way!
However, I did get a few planks laid for the wales.
Before I show pictures of my miniscule progress(!), here is a bit on the process of bending a plank.
First, here is my bending station:
I have 8"X1" board that I'm using as a base. The center clamp is holding down the bending form and a piece of stock to keep the planks from raising up when being bent. The two outer clamps hold the shape while I use my sealing iron to "steam" the water that I either wiped onto the plank or that I soaked the plank in.
This set up works good for the bow and stern planks that need lots of "curve". I don't bend them in the most often seen method. Rather I bend them across their width. When placed on the frames, this method proves to work for the two axis that planks at the bow and stern need to be bent in order to sit flat on the frame over the course of the full plank width. It is a much longer process but the fit is better in my opinion.
I can attest that it works better with softer woods than walnut!
Walnut has proven to be very difficult to bend. And even when bent, they tend to want to return to their straight original shape! Also, walnut is much more brittle and I've already broken several pieces by not going slow enough on the bending! This model will definitely test my patience!
Fortunately, these first few pieces gives me time to work through a process with a little forgiveness since the wale is double planked:
Once the wale is done on the port side, I'll do the small sections on the starboard side before lining of the planking belts and working from the keel up, begin planking...
More when progress is made!
- TOM G, Duanelaker, CiscoH and 1 other
- 4
So, the stern lanterns don't get installed until much later in the build but I had to figure out how to get the LED to the lanterns. By looking at the plans and some pictures, I determined where the lanterns would be on the stern plate. I marked and drilled holes for the wiring:
And ran the wires to port side stern stanchion. I used a very small brass tube as conduit to run the wires through the deck and into the frames:
I'll just paint the brass when the time comes. I also had to cut and fashion the tubes the lanterns will be mounted. Since the LED won't fit in the tube, I have threaded and tape to keep from moving around too much:
The wiring is now complete for the model except the switch and battery which will be in the mount base.
I finished planking the stern plate:
The keel is installed and the first thing I like to do is lay-out the position of the wales:
And so it begins!
I plank the wales first. I use the wales as a reference for the planking and since the wales is a double layer, I don't need to worry about butt patterns and length of planks:
- 2
Sitting at my computer watching snow accumulate... 8 inches and counting!
I'll get lots of work done today... Can't do much of anything else!
So far this week I've continued cutting the rabbet into the keel pieces. The walnut is a difficult to work with but am making good progress and a portion of the keel is now in place. Additionally, I got the stern post built up to properly accept the planks:
This last picture is of one of the keel pieces as I prep it for the rabbet cut.
I installed the stern plate and began planking the outer section:
Still need to do some blending and sanding.
Also installed the lower bow rails:
Hope to have the keel installed today and start planking! Also, will be getting the light and wires in place for the stern lanterns before planking the inner surface of the stern plate.
Another quick update tomorrow or Monday.
Thought I would mention for anyone interested in the HMS Bounty’s history.
I just finished reading “Mutiny on the Bounty” by Peter FitzSimmons. Written in 2018, it is a historically accurate account of the time right before she left England (actually, including Bligh’s previous service) to nearly 30 years after that fateful trip. It’s based on journals, notes and letters from all involved. A lot of interesting info that you won’t find in any other retelling of the story... very factual.
I found it to be an excellent book and enjoyed it thoroughly!
11 hours ago, Tim Moore said:
Thanks Lyle! Im just about to finish a large Spitfire model I built out of wood, just needs painting. Just bought an airbrush so my plan is to learn how to use that and paint the Spit as a bit of a break project. I’ve done a short log on it in the non ship section here. My next nautical project is the Fifie Scottish fishing boat - a lovely kit I got last year.
Don’t hesitate to message me if you need to discuss anything on your excellent Bounty build.i do remember seeing that in a previous post. Good luck! Another love of mine... planes, but specifically WWII era planes!
The pictures of your Bounty are stunning! Absolutely beautiful piece of art!
Hope to accomplish something close to what you've done!
Your build log continues to provide inspiration and guidance! Appreciate the opportunity to get some help from time to time! Overall, I like the kit but the instructions are not the best and out of order. Fortunately, build logs have helped and I'm really enjoying the challenge and the detail.
Congratulations!
Looking forward to the pictures!
A little early as I usually like to take a short break but what's up next?
So, where to start with this update...!
A lot accomplished but not necessarily visible work.
Let me show you the main deck first:
I am not 100% happy with the outcome! Although, I am not going to change it either.
I am at a complete loss as to why the color turned out different from my tests. I followed the exact same method and got a light brown color instead of the gray-brown I was looking to attain. However, it does look good.
After much internal debate and research, I have chosen to forgo the treenails. In actuality, I discovered that on ships with wood decks, the treenails are plugged and very hard to see. I looked at several pictures and found that 1:1 scale, they are visible but just barely. Now take into account that at 1:48 scale, the average treenail is only .5mm across! I just could not see the point of putting them on the deck... even though I did do it on the lower decks!
Please render your opinions below, I'd love to know how others feel about the deck and treenails.
Moving on, on my last update I showed a problem with the stern area that had to be fixed:
I had to do some shaving on the middle support and on the port side and had to reinforce the side brace. Everything is re-glued and sanded smooth, ready for the stern plate and stanchions.
Also been working on the fairing and as promised, some pictures of the method I use to check for good surfaces to glue planks to:
The string is pulled tight and lays approximately in line with the planks.
Obviously, high and low spots are easy to spot and address too. During this process, I discovered another issue that needs some attention. The model design is just not right in my mind at the stern post. The planks should butt into the post. The kit looks to be designed to just have planks end at the post... I don't like it!
There are a couple options:
1. Reduce the size of the frames and false keel to allow the planks to butt in to the stern post. Probably the best option, if you don't have wiring running through the area... I do!
2. (and the option I've chosen) Increase the stern post thickness by adding walnut strips to both sides. I'm still working out the details of this change but it will increase the thickness by 4mm (2mm on each side) to accommodate the planks.
I'll be working on this next, feathering added strips toward the rudder.
In the meantime, I'm getting ready to add the stern plate and stanchions:
And, working on the rabbet on the bow keel section:
This requires that a 2mm wide notch is cut on both sides to allow the planks to fit right into the keel. This has to be done the entire length of the boat... not easy work with Walnut!
Have a great week!
- 2
Thanks Tim
I don't have the option of going as thin as you have, the wiring for the lighting would have to be re-routed... not gonna happen!
Your method is otherwise the perfect choice.
I'm moving forward with a heavier stern post and I'll make it work just fine!
Thanks for the pictures!
3 hours ago, Tim Moore said:
Hi Lyle - I do recall struggling with the lower part of the stern a bit to make a proper transition. I’m pretty sure I did most of the fairing, installed the stern post and keel, and then used my Dremel to pare down the structure further on the lower section abutting the stern post so that the face of planking could lay close to flush with the face of the post. Then I sanded it all flush after planking. There wasn’t a lot of backing timber left in that area.
Thanks...
was considering building up the stern post on both sides as an an alternative too.
A 5x2mm walnut strip on both sides feathered toward the stern may work.
Hey Tim,
A question for you...
l’m in the process of fairing the hull, in particular the stern. At the stern post I expected the plank ends to butt right into it. However there is so much material from the stern keel stiffeners that you almost need to sand or file them completely out!
How did you handle this particular area?
Appreciate any advise!
HMS Bounty by Trond - Billing Boats - 1:50
Hi Trond,
Your build is looking great!
I have an electronic copy of the Armed Transport: Bounty. Been a huge help for me too.
I recently finished reading a book about the HMS Bounty. It's based on the logs, diaries and letters of Bligh and the crew. It's call Mutiny on the Bounty and was written about 3 years ago by Peter FitzSimmons. Might be of interest to you... I found it an excellent read!
I'll be keeping an eye on your progress. Keep up the great work!
